Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Having Trouble With Flyback
I am trying to change out my flyback transformer on my Sony KP-51WS510. Do I have to remove my D-board to change this out, also will there be any soldering involved, and I am having trouble pulling out the HV cord from the old flyback.
  • ece123 Jun 23, 2008
    What are the symtoms that make you think you have to change the Flyback transformer? I replaced the stk ics and still having convergence issues...
  • Sony Master
  • 8,617 Answers
Yes you will need to unsolder the old flyback and solder in the new however its very basic soldering required. Yes the d board will have to be removed just remove the screws and then press the plastic tabs in that secure the board to the plastic frame. Then the HV lead has to be rotated 90 degress and then removed they come out quite roughly. Its best to grab onto theHV lead with insulsted pliers and then rotate and pull with a twisting motion to get it to release.
Posted on May 19, 2008
MY SONY KP-51WS510 LOOKS LIKE 3D AND THE IMAGE IS CURVED
The flyback as you discovered does not effect convergence. The convergence repair is different. This video should explain it further.
Nov 26, 2011 | Sony KP-51WS510 51" Rear Projection...
Need to replace the flyback (transformer) is it
good morning friend. it is not very complicated to fix, but it is far more better to allow someone with experience to solve this problem. there will be excess solder on the bottom of the circuit board the connects the flyback. you must desolder this in order to remove it. you need to have a mesh desolder wick in order to completely remove the solder. go over each eyelet( pins from flyback) as many times it take to completely clean it. follow the cords to their different destination and unplug them. write down each location and what you did and go into the reverse order. thank you and pleasew rate my solution.
Nov 19, 2009 | Sony KP-53HS10 TV
KP-46WT510 is blinking 8 times repeatedly on standby what is the problem?
Replace the Flyback transformer your correct flyback which is used in the WS510 and WT510 models is available at the following link.
http://servicemanuals.vstore.ca/product_info.php/pName/sony-flyback-145328551/cName/flybacks
Oct 28, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Red stand by light blinks 8 or 9 times and no picture or sound
hello Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
shaun
Oct 18, 2009 | Sony KP-51WS510 51" Rear Projection...
Sony 5 projection tv kp-51ws510 no pic, light flashs 8 times
I have the same model TV and have had that same problem (*8 flashes) The FLYBACK TRANSFORMER on the D circut board is the most likely cause and will need replaced) the part is around $70.00 USD!
Please rate my response
THANK YOU!
Jan 22, 2009 | Sony KP-51WS510 51" Rear Projection...
Sony projection tv
8 blinks is usually the error for a bad flyback. you can get a replacement at the following link and if your not sure which one your model uses click on the sony flybacks one at a time and it will tell which model they fit. Heres the link.
Sep 30, 2008 | Sony KP-51WS510 51" Rear Projection...
Will not power up, light flashing
you are probably experiencing a bad flyback transformer
Feb 12, 2008 | Sony KP-51WS510 51" Rear Projection...
Arcing inside no picture
Most times arcing like this is from the Horiz. output transformer (flyback). The insulation has a break down and up to 30 KV will find the nearest path to ground. This would require a tech. to repair the unit. This repair will most likely cost around 250.00.
May 09, 2007 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
146 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
