Question about Gevalia 35411 / 50433 Coffee Maker
Won't brew, but turns on briefly before shutting off
Maker worked until 4/1/08 and was in storage until 5/13/08. When I went to use it, I pressed the on button, saw the indicator light come on briefly and then go out. If I hold the button in for 7-10 seconds, water is sprayed into the basket, but as soon as I stop holding button, it goes off again. Is this repairable?
Switch problem.
Posted on May 20, 2008
Wont finish its loading process
You may have to reset it. let if charge for about 24hrs, 10hrs may work fine too and With the device turned off, press and hold the volume down button, and then briefly press the power button. - Wait for the screen with the three Android images to appear, and then release the volume down button. - Press volume down to select clear storage, and then press power. - Press volume up to start the factory reset.
Feb 06, 2014 | RCA Tablets & eReaders
It goes to the rca loding logo and keeps loadin until dead
do you have the correct charger, because if it doesn't and you are charging using usb, it may not be charging it enough, if you have the correct charger You may have to reset it. let if charge for about 24hrs, 10hrs may work fine too and With the device turned off, press and hold the volume down button, and then briefly press the power button. - Wait for the screen with the three Android images to appear, and then release the volume down button. - Press volume down to select clear storage, and then press power. - Press volume up to start the factory reset.
Lost codes, need a code for directv
Here is the Manual for the Remote with all codes. I couldn't find exactly what you needed, but I hope this helps :)
Mar 02, 2011 | Innovage Jumbo Remote Control
How do you set the time as well as the timer? I have looked but can not find the manual.
Good Afternoon,
Programming Your Coffee Machine
• Plug in your appliance: the display will light up briefly in blue, blink "8888" and then remain
fixed.
• Press the O/I button if you wish to make coffee without using the programmable mode.
• The display will light up in blue and alternately show "ON" and the current time.
• Press the O/I button to shut off the coffee machine. The display will no longer be lit.
Setting and Adjusting the Clock
• The machine must be "off".
• Press and hold the prog button (o) for 3 seconds: the hours will blink "88 _ _".
• Adjust the hours in steps by pressing the h/min button (n).
• Press the prog button : the minutes will blink" XX 88".
• Adjust the minutes in steps by pressing the h/min button.
• Confirm the setting by pressing the prog button.
Setting Auto On
This programs the coffee machine to start automatically at the set time each day.
• Press the prog button (o) briefly : the display will blink "prog" for about 1 second, followed
by "8888".
• Press the prog button briefly: the hours will blink "88 _ _".
• Press the prog button briefly: the minutes will blink "XX 88".
• Adjust the minutes in steps by pressing the h/min button .
• Confirm the setting by pressing the prog button briefly:
• The display (q) will show the time and a " ".
• Press the h/min button to cancel the programming.
Click the link below for the maunal:
http://www.krupsusa.com/NR/rdonlyres/A50B1840-2CD9-44C1-87E8-260B92D96D3A/7244/FME124_FMF345_usa.pdf
Hope this helps!
zeppelinx12
Feb 23, 2011 | Krups FME2 Coffee Maker
How to reset the change oil light on my 2002 bmw x5
Try this procedure and let me know if it does not work.
1. Ignition key in the "Off" or "0" position.
2. Press and hold the odometer button and turn the ignition key to the "Accessory" or "1" position.
3. Keep the odometer button pressed in until you see the following words in the display, "oil service", or "inspection" with "reset" or "re".
4. Press and hold down the odometer button again until "reset" or "re" flash.
5. While the display is flashing, press the odometer button again briefly but do not hold it down this time to reset the service interval indicator. After the display has shown a new service interval then "END SIA" should appear in the display for two seconds.
If the procedure fails the first time then repeat the procedure and it should clear the service interval indicator.
Sep 16, 2010 | 2002 BMW 5 Series
Reset the service engine indicator on a 2002 bmw x5
1. Key in 0 or off position.
2. Press and hold odometer button and turn key to 1 or acc. position.
3. Keep button pressed until any of the following words appear in display: "oil service" or "inspection", with "reset" or "re". For vehicles with "high cluster", the fuel amount remaining until next service is displayed.
4. Press and hold button again until "reset" or "re" flash. If there is no "flash", minimum consumption value has not been met.
5. While display is flashing, press button briefly to reset service interval indicator. After display has shown new interval, the following will appear in display for approx. 2 seconds:"END SIA"
Jan 16, 2010 | 2002 BMW 5 Series
Power went out briefly. Refrigerator control
Press the Power Freeze and the Power Cool button at the same time. Hold for 10 seconds and the digital panel reset.
Aug 14, 2009 | Samsung Refrigerators
How do i switch off service now light on my vw golf 53 plate
Courtesy www.synthetic-direct.ca:
To reset the message displays, turn the ignition switch on. Press and hold the odometer reset button “A” located below the speedometer. Turn off the ignition while holding the button. “OEL” will display on the indicator. Press and hold the lower digital clock reset button or the analog clock reset button “B” until five dashes appear in the display.
If needed, next press the odometer reset button until IN 01 is displayed and then press the clock reset button until five dashes appear. If needed, next press the odometer reset button until IN 02 is displayed and then press the clock reset button until five dashes appear.
To exit reset mode, turn ignition switch on and when IN 01 appears, turn ignition off.
Jul 24, 2009 | Volkswagen Golf Cars & Trucks
Saeco Talkeo Giro
indicates that descaling needs to be carried out. To cancel Press and hold the hot water button until indicator light goes off (about 6 seconds)
Mar 01, 2009 | Saeco Talea Giro Espresso Maker -...
UNIVERSAL REMOTES
I have the book (list) that comes with the remote. It explains how to do a "code identification". It's pretty simple. Press and hold the Codesearch button until the light stays on ... then press and release the "Mode" button (the button that represents your TV or DVD or whichever device you are starting with, in your search for a code). It will blink briefly once and then stay lit. Now press and release the Codesearch button again (the indicator light will briefly blink). Now, to find the first digit of your code, start at "0" and enter slowly, one at a time, 0 thru 9 until the indicator light blinks off. THAT was the FIRST number of your code. Write it down. Now, repeat the process to find your second number of your code - starting over at "0" and enter slowly, one at a time, 0 thru 9 until the indicator light blinks off. THAT will be the second number of your code. Continue until you have all 4 numbers. Repeat for each device, until you have all codes desired.
Nov 28, 2008 | Televison & Video
Gevalia 35411 / 50433 Coffee Maker Logo
282 people viewed this question
Top Gevalia Coffee Makers & Espresso Machines Experts
Andrew Taylor
Andrew Taylor
Kolbrun...
Are you a Gevalia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
