Question about Xerox WorkCentre M128 Copier
Xerox WorkCentre M128 - 016 - 782
Hello experts
I have a problem at work with my Xerox Work Centre M128 when I try to scan into a specific folder.
The error code is 016- 782
Can anyone help me please?
Thanks
Rika .
  • Anonymous Mar 14, 2014
    work centre m128 chip reset
  • Anonymous Mar 30, 2014
    xerox work centre 5020how can i print my excel file to workcentre 5020 i already installed but if i try to pint in excel there is a prompt error msg. "Print driver host for 32 bit applications has stopped working" kindly give me an instruction to solve this problem. thanks... :)
    President:
  • 2,072 Answers
There is an error in the in the server password or a template setting.
Here is the documentation. Pretty straight forward
Login to the Server was not possible during Scan to Server file transfer.
Xerox WorkCentre M128  - 016 - 782 - arrwup.gifInitial Action Refer to BSD 16.1.
Power OFF/ON
arrwup.gif Procedure Set the login name and password in the destination server.
Set the attributes of the Job Template file correctly.
From a client PC, set the same account as the above as a resource using CW.
Posted on May 19, 2008
  • Rick Kasper May 19, 2008
    I sent you the step by step procedure as best I could in the next post. Should have the detailed way of doing that.
    Setting up a scanning template using CentreWare Internet Services (CWIS) will fail if the user login name is a domain user, for example, ADSdomain\testadmin.
    1. Open an Internet web browser.
    2. Enter the IP Address of the machine in the Address field, and then press [Enter] on the keyboard. The CWIS home page will be displayed.
    3. Click on the [Services] tab.
    4. Click on the [Job Templates] link.
    5. Click on the [Display Job Templates Screen] button. The Device Template window will be displayed.
    6. Click on the [File Repository Setup] radio button. The File Repository Setup window will be displayed.
    7. Select the required File Repository from the File Repository Setup pull-down menu.
    8. Enter a username that only exists on the SMB server in the Login Name field.
    9. Click on the [Apply] button. A 'Settings have been updated' message will be displayed.
    10. Click on the [Back] button. The File Repository Setup window will be displayed.
    11. Click on the [Template] radio button. The Device Template window will be displayed.
    12. Click on the [Create New] button, and then setup the template again.
    13. Click on the [X] in the upper, right corner to close the Internet browser window and return to the desktop.
Need info on scan drivers for work centre pro m20i downloads
go to xerox.com you will find the drivers there for this machine.
Dec 15, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Xerox WorkCentre 7232 will not Scan to PC
Your error code usually means: Scanner can not find the specified folder/storage location
-wrong document path
May 21, 2009 | Xerox Office Equipment & Supplies
Can I use Xerox Work centre XK50cx with Sony FS550?
Hi Jaci,
Copy and paste the link below into you browser and type in the word "scanning". With all Xerox machines there are many ways to setup scanning. Hopefully you can pick out the best way for you!
Best of luck!
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=x_rpss_en,Company={683D76C8-B5C5-416E-9754-DD015FDB4F2E},ts=x_main_en,ques=ref(Country):str(USA),ques=ref(Prod_MFIJ_XK50cx):str(XK50cx),question=ref(ProdFamily):str(Prod_MFIJ_XK50cx),varset=Xcntry:USA,varset=Xlang:en_US,varset=prodID:XK50cx,varset=prodName:%20WorkCentre%20XK50cx
Mar 30, 2009 | Xerox WorkCentre XK50cx InkJet Printer
Xerox M20i scan to e-mail
You can not scan with a M20i with an Ethernet cat 5 cable. It can ONLY be done via a USB or parallel cable.
If you don't believe me, which many on here wont accept the truth, here is the note from the Xerox documentation..
The WorkCentre can scan a document via Direct Scanning using a USB or Parallel Port connection only.
Jan 11, 2009 | Xerox WorkCentre M20i All-In-One Laser...
I can not scan in xerox pe 220
I found the solution today. First you go to Autralia Fuji Xerox website at http://www.fujixeroxprinters.com.au then select Driver - Xerox WorkCentre PE220. Download the Control Centre and Scan to PC together with WHQL_PE220_2K_Vista_SCAN (scan Driver) and WHQL_PE220_2K_Vista_GDI.zip (GDI Driver). Setup files are in Control Centre and Scan to PC folder. The rest will pop up new hardware found and browse to two other files dor perfect driver.
Hope this help because it's help me today. Thanks to Miss Chin from Pineaple Computer Store One Utama Malaysia.
Nov 01, 2008 | Office Equipment & Supplies
RE : Xerox WorkCentre M128 016-782
May 19, 2008 | Xerox WorkCentre M128 Copier
RE : Xerox Work Centre M128 016-782
Workcentre c2424 Scan - Won't find me so I can scan to personal images
It seems somehow your address was deleted. Recreate the box on the machine and it should be ok.
Mar 29, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox WorkCentre M128 Copier Logo
11,736 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
