Question about Brother IntelliFAX 4100 Laser Fax
Fuser & Scanner are not the problem
I have replaced the scanner and the fuser in a IntelliFax 4100 but it still has an issue where it print nothing in the middle of the page.. Its about 2-3 inches wide.. ANy suggestions what to try replacing next??
  • 1 more comment
  • schon731 May 20, 2008
    What is the laser unit?? I have replaced the drum so that is not it either.. THanks..
  • Admin Lady Jun 09, 2008
    We've searched under the drum and can't seem to locate any 'window' that needs cleaning as suggested by Guru. We've replaced both drum and toner and are still experiencing the same problem. We've removed the toner saver option as well but nothing has changed.
  • bill1956 Jun 26, 2008
    we receive a fax with two blank area down the center.
    President:
  • 2,072 Answers
Either the laser unit is dirty or blocked. Or the drum cartridge.
Posted on May 19, 2008
  • Rick Kasper May 20, 2008
    The laser is the unit that scans the drum to put the proper image on the drum.
    You should be able to remove the drum and look around for a small door that covers the last opening.
    There will be an opening probably about 4 inches wide and less than 1/2 inch high. There will be a glass "window" which may just need cleaning.
    That sounds like your most likely cause, either dirty or needs replaced.
Recieve the fax and print the pages well. But, when I send the fax to other fax it prints two black lines on the right side.
The problem should be from the printer fuser assembly, the other party will need to replace there fuser assembly on there printer, once that is done, the problem should be fix.
Take care.
Sep 24, 2010 | Brother IntelliFAX 4100 Laser Fax
Brother Intellifax 4100 horizontal lines
This is an indication the scanner is dirty. Try cleaning the scanner. There are products that have cleaner in them where you simply have to send the treated paper through the scanner.
Aug 20, 2009 | Office Equipment & Supplies
Black pages
Try to copy a document. If the copy comes out black then the the scanner is dirty. Clean the scanner glass (products on the market that clean by sending through the scanner) and try to copy again. If after cleaning the scanner, the copy is still black you have a scanner issue and the laser/scanner unit will need replacement. Best of luck and please post back with any questions or just to rate the solution.
Greg
Aug 10, 2009 | Brother IntelliFAX 4100 Laser Fax
After paper jam, prints total smudge on Intellifax 2800...please
This is the test to determine toner/drum or fuser issue.
Print a test page
When you hear the paper feed into the machine open the top to stop the machine
Remove the toner/drum cart.
You should be able to see the page with printing on it. (This is before the page hits the fuser)
If you can see the smudge or marks on the page the problem is most likely the cartridge but NOT the fuser.
If the page is clean the problem is most likely the fuser.
Mar 13, 2009 | Brother IntelliFAX 2800 Laser Fax
Brother intellifax 4100 squeaks when printing faxes
THIS IS A HARD ONE, THE BEST THING THAT CAN TELL YOU IS TO LUBRICATE ALL THE GEARS IN THE MACHINE, THERE IS A SLIGHT POSIABLITY THAT IT IS COMING FROM THE FUSER MODULE
Jan 07, 2009 | Brother IntelliFAX 4100 Laser Fax
Rebuilding the brother fuser for the intellifax 4100
Although it fit the broken fuser, it does not mean it's ok.
1-they must have the same number of teeth ( diif. gears have diff. amounts of teeth)
2-it must be the same diameter ( so they can mesh together, otherwise it's touching the tip of hte teeth and may be skipping.
But I'm not sure the double image is coming from there, it would jam the paper because the timing is off.
Anyway you need to eliminate the obvious then see what happens, I think you said you had another tonertry putting that in, if it doesn't work then change the gear for the correct one.
try precisionroller.com
Sep 08, 2008 | Brother IntelliFAX 4100 Laser Fax
Fuser unit
dont. the whole machine has to be taken apart. not worth the time and the fuser is 85.00 wholesale.
May 24, 2008 | Brother IntelliFAX 4100 Laser Fax
FUSER REPLACEMENT
A real big job. Completely remove all covers, doc feeder asm. Best to let a qualified tech do it for you. I charge $50.00 plus parts and will allow you to watch me do it. But i am in Florida.
Dark toner streaks
can only be toner, drum or fuser, pull out drum and look at surface are you streaks present? usually drum.
Stop a print half way threw machine and then remove drum and look at print, pre hot bit (fuser) are you marks there? If so it is drum, if not fuser.
Nov 21, 2007 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
113 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
