Question about HP Color LaserJet 2600n Printer
HP2600 LAser printer wont print red
It prints the other colors fine but it wont print red. Is it worth having fixed or is it something I could fix
  • blondie79 Jun 05, 2008
    our HP2600n laser printer won't print red all other colours fine, new cartridges too. Help - has anyone else had same problem??
  • addar Jun 09, 2008
    Sergeant:
    Champion:
  • 317 Answers
Here is the link to the step by step procedure, it requires a little skill to do so... enjoy!
http://forums11.itrc.hp.com/service/forums/bizsupport/getattachment.do?attachmentId=296504&ext=.pdf
Posted on Oct 15, 2008
Follow the link by CoolDragon.
Do exactly as the step by step procedure tells you. It is spot on.
Once you get down to the mirrors etc - use a cotton bud to clean the lense and mirrors. I had a very poor print before I cleaned them. Red had just about gone. Now its back as new. Its worth the effort.
If anyone needs help - email me on neilj@phineline.co.uk
Posted on Nov 07, 2008
This can happen if the laser scanner window gets toner on it most common on the magenta window as its the lowest
solution strip printer remove laser scanner unit and clean the lenses mirrors and windows
not a quick easy and simple solution but it works
only alternative is to replace printer
Posted on Jun 11, 2008
It dosnt work any othr way
Posted on Jun 09, 2008
    Sorry Any one can help i have the same problem . itry clean change magenter toner nothing happend aslo.
  • 300 Answers
Clean the magenter toner cartridge contacts in the printer with a dry cloth, this may help.
Posted on May 19, 2008
When I open the toolbox for the LaserJet 2600n printer, it tells the website is not available. I need to clean the jets etc.
You need not to clean laser printer cartridges,it may color or mono. Print cartridges them selves having cleaning blade to clean the surface of the OPC drum every time when its initializing or printing. If you found any vertical tracks on print outs replace the particular cartridge.. If you have any kind of print quality issue,perform calibrate process through printer menu..quality..calibrating.. even if you found quality issue clean the Laser scanner assm.(professionals only can do)
Oct 28, 2011 | HP Color LaserJet 2600n Printer
My Canon Pixma MP258 printer can't print the red color but other colors are okay.When I print out any words or pictures that needs red color,it becomes green color.I don't know what's wrong...
Solution
1. Press START - Devices and Printers
2. Right-click the Canon MP258 series - select Printing preferences
3. Click Maintenance - Cleaning
4. Select All Colors BK, C, M, Y - Execute
5. Wait until the process is finished (Do not start another operation until the cleaning has finished).
6. Click Print Check Pattern OK
If the results print out like this, there are two possibilities:
1. Red ink in the cartridge runs out. Solution: injecting with red ink
2. If the red ink has been filled, and check pattern is still not out, meaning the color cartridge error.
Solution: replace the cartridges
Oct 15, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Printing to much red. the picture in print shop looks fine but actual print is to red or pinkish.
you'll need to install a color management profile matching your printer, or use manual settings in Photoshop (if that's what you're using) so that the software will issue a lesser red image to compensate for the overly red printouts of your printer.
Another point to consider is that printshops may be using a lot more sophisticated print machines than our everyday laser printers. Also, from what I've read sofar, most color laser printers are optimized for charts, tables and text printouts. Image printing isnt their favorite thing to do.
Dec 21, 2010 | OKI C3400n Laser Printer
Black print fading in & out . I replaced the black drum with a brand new one, but the problem still exists. I followed the instructon about rolling the drum before installing but its still the same....
If your printer prints like this:
The problem is with the developer in the imaging unit. The problem can be fixed by either replacing the imaging unit for $100+ or you can fix it yourself by cleaning the imaging unit. You will need simple hand tools and if you are careful restore the print quality of your printer. I have a link to instructions that should help you http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300 Hope this helps you.
Nov 30, 2010 | Samsung CLP 300 Laser Printer
Red does not print on one side of the page
I have bad news :( when that happen on this model its because one of the lasers its contaminaded. Dust or toner get inside the unit and block the light of the laser for the magenta causing issues with color that uses red. If you print a configuration report the red look faded in the sides. Changing the cartridge wont fix it. it can be repaired but its expensive. I suggest to get a new model. or if you call HP they can exange it for about $200
Sep 06, 2010 | HP Color LaserJet 2600n Printer
I have an HL-4040CDN Brother printer that prints too red. We just purchased it and need how to fix this problem. It also prints colored text too light.
Many people are having problems with this machine. If you are dissatisfied with the quality I would return it and try something else. Your most economical solution is going to be a factory refurbished (with warranty) HP color laserjet. Staples usually has some good deals.
Jan 18, 2010 | Brother HL 1440 Laser Printer
HP Laser Jet 4700n-Light printing on right side of paper. Removed all cartridges and toner, cleaned and recalibrated after start up. Still light printing on right side. Any suggestions??
Is the light printing the same for black and white vs color? Light printing on a side is not uncommon for these printers. It is usually caused by the laser optics getting dirty. But this usually shows up more in one color than the other. Such as something printed in yellow is fine while red is faded on one side. If the light on the right side printing is the same on all colors including black then I would suspect something with your transfer unit.
If you do notice that it us just on black or another color then it is definately time to get the laser optics cleaned.
Dec 18, 2009 | HP LaserJet 4700N Printer
Canon LBP5000 lack of Red (magenta)
Searched on web for same problem on HP2600 printer and found a sight that explained how to fix it. It is caused by the mirrors getting dirty. Magenta is the first one affected because it is on the bottom and points upwards. Requires printer to be pulled apart and mirrors cleaned. takes about 1 to 2 hours. HP2600 printer seems to be the same as Canon LBP5000.
Jul 07, 2009 | Canon Office Equipment & Supplies
Prints "blue" on a document that supposed to be "red"
the red color contains the blue and magenta colors so your problem is not printing blue insted of red , your red laser miror is dirty from inside you should open the back of the printer then open the laser scaner then clean it then replace it
Jun 19, 2009 | HP COLOR LASERJET CP 3505 N PRINTER
First of all clean the contacts in the printer for the magenta cartridge, if there is no improvement replace the magenta cartridge, if that doesn't work come back to me
Jun 12, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
972 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
