Question about Motorola MU21CV (1 Channel) 2-Way Radio
Motorola GM300 Base Station
We have a Motorola GM300 radio base station that is giving us problems with interference issues. Sometimes when we transmit from the base station the communication comes through garbled to some radios and ok to others, and other times the people at the base station cannot get a clear transmisson they can understand. We were told by our local rep. for Motorola that we have another user on our freq., but they are located at least 40 miles away so there should be no interference. Can you please help?
Thank you,
Caleb Van ****
    New Friend:
  • 109 Answers
It could also be another user that is +/- 12.5kc from your frequency. this would explain why you can here other people but not understand them.
pat N5SLI
Posted on Sep 05, 2008
Check your power supply,antenna,antenna cable........
for good range better you provide Reapeter
sadhik
Posted on Aug 02, 2008
  • Motorola Master
  • 1,654 Answers
Try lowering your antenna slightly. Height and placement of antenna determines range, the higher your antenna the further your radio will talk and listen. By lowering your antenna you can determine if the user 40 mi away is interfering or not.
I also agree with dobhan, check your power supply.
Posted on Jun 24, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 105 Answers
Pls check your power supply it can cause a garbled audio once the power supply is not regulated or constant voltage so your transmission also is defective,check also the connector it should be tighten,if not do change your microphone for temporary......
Posted on May 23, 2008
Panasonic KX-TCD25AX cordless phone. Why can't it find the base station?
several reasons
too far away from the base station
too much interference between the phone and the base station ( buildings, iron sheeting etc)
the phone is not programmed into the base station memory-- re do the system program where the base station recognizes each phone and sets it's number for identification
May 14, 2015 | Panasonic Lands Phones
I have a KX-TG6700 base station and 4 Handsets. When I have been calling on the handsets I have recently found that there is static on the line. Later I realized that there is problem with the DTMF being...
The KX-TG6700 manual at: http://www.panasonic.ca/PDP/OperatingInstructions/kxtg6700-oi-eng.pdfhttp://www.panasonic.ca/PDP/OperatingInstructions/kxtg6700-oi-eng.pdf
States:
For best performance
Base unit location/avoiding noise
The base unit and other compatible
Panasonic units use radio waves to
communicate with each other.
For maximum distance and noise-free
operation, we recommend the following:
LPlacing the product away from electrical
appliances.
LPlacing the base unit in a HIGH and
CENTRAL location with no obstructions
such as walls.
LRaising the antennas vertically.
LIf you use the handset near a microwave
oven which is being used, noise may be
heard. Move away from the microwave
oven and closer to the base unit.
LIf you use the handset near another
cordless phone’s base unit, noise may
be heard. Move away from the other
cordless phone’s base unit and closer to
your base unit.
Have you considered all these points?
Is there a way you can move the base station to another location in your house to see if the problem get better? I don't beleive your base station is faulty, I suspect interference from something.
I don't think the 2.4GHz set is causing any issues, but you never know, try unplugged it for a while to investigate.
If you do determine that the base station is faulty there probably isn't many options to get it repair other than sending it to Panasonic. May be cheaper to buy a new base station to go with your extra handsets.
Good Luck!
Mar 14, 2008 | Lands Phones
Handset says "Out of Range". What does that mean; how do I fix it.
out of range means it can't receive a signal from the base station. The most likely problem lies with the base station. Special when 2 or even more handsets are giving this message.
Try to reset (unplug the power cord and reinsert it) the base station. When it does not come back after half a minute, the station must have a major problem.
Feb 01, 2015 | Motorola Mobility 5.8GHz Digital Cordless...
I have a cm200 base station and need to sync it with my cp 200 radios
hi Raymond, we're a Motorola /Vertex Dealer and have the software and cables to program everything to match. as long as they are all on the same frequency range (meaning the new Portables are not VHF and the base is UHF, if both are the same, we can take care of programming for you, $35 each unit programmed. shoot an email over to us metrocom2 @ yahoo (dot) com - jenny
www.metrocomdc.com
Mar 20, 2014 | Motorola Radio Communications
Phones always searching for base.
Is the base station too close to another electrical appliance as it could interfere with the signals. Try moving the base station to another location to see if that solves your problem.
Aug 04, 2010 | AT&T 5.8GHz Cordless Phone System with...
Range out
You don't give much information to go on here; it would have been a great help if you'd added details of the make and model and whether the problem occurs some or all of the time.
Assuming it's a cordless home telephone then your phone is telling you that it cannot communicate with the base station. Typically this will be when you're too far away (out of range, hence "range out"). Too far away simply means that either the phone or base station antennas are not fully extended (not all models have external antennas though), or it can mean that there's too many solid walls/obstructions between the phone and the base station; these kinds of phones can also have problems with certain types of building construction. It can also be if there's interference on the carrier waveband, so try switching the base station and all phones to an alternative band if available. Other causes will be that the phone battery has been recharged to the point that it cannot hold sufficient power any more or that there's a fault with the base station. Any large metal objects close to the base station will also cause a weaker signal than normal.
I hope that I've helped, if so then please rate my answer. if not then please supply additional details and I or another expert will be able to provide a more relevant answer.
Mar 04, 2010 | Lands Phones
Base phone not charging even when phone left in phone base overninght
take a volt meter and check the contacts the phone sits on in the base station, there should be around 5 volts DC there, if there is I would replace the batteries in the phone, if there is no voltage at the charging contacts in the base then the base station is defective, another quick way to determine the cause of the problem is take the phone out of the base station and put it into one of the other phones chargers, then if the phone does charge up the base station charger is defective, u will need to replace the phone or not use the base station for charging. these are not repaired except under factory warranty.
Feb 23, 2010 | Panasonic KX-TG1033S Cordless Phone
CB Base Station picking up electrical interference
i dont know what AC DC adator your using. you should look into a 12V power supply. or plugging that into a RF canceling power strip, like a monster power strip. TV's that are on or other appliances may cause high noise levels on the CB, make sure your coax is good, your antennas good, and all jumpers are good. its hard to tell with out looking at it, but do a quick once over of the system.... you are using a base antenna right? if not you need to create radials for a mobile you plan on using for a base.
Make sure the connectors on the coax are all on right, this causes problems a lot of the time. sometimes even brand new coax have bad connectors installed.
Jan 02, 2009 | Cobra 29 LTD CB Radio
Interference using maxon pm100 2 way radio
Hello susannebrown. There is a problem with the base station or repeater station. If your mobiles can communicate ok, you have problem with the base, check the antenna & coax connections. #2 Swap out a mobile with the base & test operation. If you can do this & found the culprate care it to the repair shop(less cost). #3 Swap has no effect or you can't, you have a repeater problem. Sorry, call a repair shop.
Sep 08, 2008 | Radio Communications
My Motorola MA580 sometimes work and others don´t
It sounds as if the channel that the phone and base has selected during that session is bad, or being used by another system in the area. When that happens, try selecting another channel. You should be able to do this by depressing a button on the handset. Normally labeled "Channel". Please post further questions or comments. Please rate this solution through fix-it. Thank you
Jun 28, 2007 | Motorola Mobility MA580 (612572111116)...
Motorola MU21CV (1 Channel) 2-Way Radio Logo
728 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
