Yellow circle, with triangle and exclamation mark – The Electronic Stability Program (ESP) dashboard light flashes if the ESP or traction control is activated whilst driving. If ESP or traction control has been switched off, it will light up continuously. If ESP or traction control is not turned off and the warning light illuminates continuously, it indicates a problem and malfunction with either ESP or traction control.
Brake ware warning light.
Brake pads have sensors , when pads worn out to the point when it needs to be replaced , sensor gets cut by brake disc and light goes on.
It's the low coolant light. Just find the overflow bottle ( it'll be marked coolant). If it's not low then the sensor that goes to the bottle is bad and may need replacing.
If there is an exclamation mark in the middle, then:
"Your brake pads need to be replaced. There is actually a sensor wire that breaks when the pad is ground down too far, interrupting a circuit to warn you of imminent pad failure. Found an answer here:" (source: http://wiki.answers.com)
A circle with lines around it - depends where it is -
If its a top left light, then it should be a circle with an exclamation mark in the middle, and two lines running part way round the outside (1 to 5pm and 7 - 11pm). Thats the handbrake and brake fluid light which comes on for about 3 seconds when you start the engine ... if it comes on at any other time - seek help.
If its top centre, and has ABS in the middle, then its the anti lock braking light. Similar to above, lights up for a few seconds at start.
Muffler with lines coming off it - are they pointing outwards from the circle, (with a thermometer in the middle = transmission oil temperature guage), or are they on the left and all parallel (which would be main beam indicator, which lights up blue when on)
