Question about Kenmore Oasis HE 27082 Top Load Washer
UL Code I have this washer and I got a UL code on the screen. I tried unplugging the washer overnight and in the morning I plugged it back in just to get the same code. The washer has been empty this whole time and yet the error code is still on the screen. I called Sears (since that's where I purchased it) and I'm out of warranty for this one. Can you help me out?
  • 868 Answers
You are going to experience endless problems with this.Please take my advise and go out and buy a used 10 year old Maytag,even if you replaced every part on it you then would have the best machine ever made.
Posted on May 26, 2008
I can't wash a load of clothes without it getting off balance. What can I do to fix this problem ? Shows code ul in display screen.
Hello, if you have tryed unplugging the washer from the 110v plug and let set for 30 mins, if that doesn't work you have electronics or sensor problem will have to be serviced.
Dec 05, 2015 | Whirlpool Washing Machines
I have a Kenmore Elite Oasis top load washer and keep having the UL code pop up. I have leveled and re-leveled the machine with no avail. I have also ensured that my level is still in working order. If...
You can try to clear the Error Codes;
  • Unplug the washer for 1 to 2 minutes.
  • Disconnect the U.I. (touch pad).
  • Plug the washer back in for 1 to 2 minutes.
  • Unplug the washer.
  • Plug the U.I. back in and then plug the washer back in. Codes should then be cleared
  • if that doesn't work that indicates a problem with the software in the machines control board replace board with this part number 26-110-8564393R and this should resolve the problem part cost about 114.16 if you like go sears parts direct .com or call parts directly at 800-573-6456
Jul 15, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Maytag washer Neptune flashes ul code
Well most probably its FL error code it means failure to lock. Try unplugging the unit for 60 seconds to reset the control board and then plug it back in and see if it will reset. If not, then you will need to replace the door latch assembly. Try pressing STOP/CANCEL to clear the display. If further you have the same problem then you need to change the door latch assembly.
Good Luck!!
Thanks for using FixYa!!
Jan 25, 2011 | Maytag Washing Machines
The ul keeps coming whether it be one small sock or filled with bedsheets. I put a new pump on thinking the old was not pumping all the water out causing it to ul. Nothing has changed. Please advise
this is usually a main control circuit board problem...you can try and clear the board by unplugging washer and get access to board area.. unplug the touch pad and wait two minutes..now leaving touchpad off..plug washer in for tw minutes...now unplug the washer and install the touchpad and put together and plug washer back in...this should clear codes..if it works ok Great..if not, order main ccu board
Jan 21, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Cabrio washer with uL code. Will not operate properly after resetting & not even with small load.
if it went thru the mini-cycle to redistribute the lad of clothes and it continues to flash uL then open the lid and manually redistribute the load,if this doesn't correct the problem,then try unplugging the unit for 15 minutes to re-set the ecu control unit and re-plug in and retry it
Nov 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Having code ul
In most casest this indicates a problem with the software in the machines main control circuit board, replace board with this part number 26-110-8564393R and this should resolve the problem part cost about 114.16 if you like go sears parts direct .com or call parts directly at 800-573-6456 also vist vist manage my life .com and ask for assistance in installing the board thanks
  • Plug the U.I. back in and then plug the washer back in. Codes should then be cleared.
Most of the time if no mechanical faults can be found the CCU (Central Control Unit) needs to be replaced. I would recommend running the diagnostic cycle first (see image below).
This is a very labor intensive do-it-yourself project, it involves extensive tear down of the washer. If you are not already sure you can perform these checks safely and competently, refer this work to a qualified professional. Working with live electrical current can be very hazardous and possibly deadly. Testing voltage output requires working with electrical current. Do not attempt these measurements without the proper tools and safeguards. First you will need to see if the washer gives that "UL" error while running the washer empty. Start a load with nothing in the washer. If the "UL" error comes up there is a mechanical issue or bad CCU. If the "UL" error does not come up there is most likely a loading issue. A common problem that causes a "UL" error is mechanical friction. I.e. something keeping the basket from moving as designed. You will need to remove the basket from the tub. I have included an illustrated set of instructions (See below). Check between the basket and tub for foreign objects such as socks or other small laundry articles.
Sep 24, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Ul code up and before that just cut off during load
The ul code is unbalanced load. Try adjusting the load. If it happens again try removing some of the clothes.
Mar 09, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Code ul appears shortly after start up
I think ul is unbalanced load, not unlocked lid.
Jul 21, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
618 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
