Question about Sony Cyber-shot DSC-W55 Digital Camera
Say access, turn the power off and on again...
  • 13 more comments
  • Miguel Moreno
    Miguel Moreno May 24, 2008
    I turn the camera on and it just says acces, then Turn Power Off and On....
    Also, I noticed that when I turned it on before the little light next to the lens (the ones u look through insted of using the LCD screen) and before it turned green, now when I turn the camera on its yellow/brown, and now it doesnt light up at all
  • voreo May 27, 2008
    my camera keeps telling me to turn power on and off again while constently beeping
  • camshy May 28, 2008
    I have the same problem. When I turn the camera on, the screen says "Access" and the lens comes out and back in about 3 times while the orange light flashes. Then when the lens stops moving, the light goes off and the screen says "turn the power off and on again." I've recharged the battery, tried gently twisting the lens, tried pulling it out farther.
  • Anonymous Jun 07, 2008
    Yeh I have the same problem and have no idea why it started! I had just up-loaded my picture on to my computer and ever since it hasn't worked! very strange and annoying! have tried twisting the lens barrel etc but nothing seems to work!
  • Anonymous Jun 11, 2008
    access on / off problem
  • Anonymous Aug 05, 2008
    i am mm so upset i have pulled on and tugged and pushed in and out and nothing . i have tried everything...please help
  • Anonymous Aug 07, 2008
    grrrrrrrrrrrr - this thing is still brand new. Purchased at Sears - they don't care if it doesn't work. SONY doesn't care if it doesn't work. Piece of junk! Never buying SONY junk again. Never shopping at SEARS again either. Not a satisfied customer.
  • stormsaputo Aug 12, 2008
    Lens will not contract back in, screen says access, turn the power off and on again
  • Anonymous Aug 13, 2008
    My Sony Cybershot 7.2 has the same problem. The lens is extended and will not retract - it is clicking. I've tried pulling, pushing and smacking without luck - any other suggestions?
  • emlad Aug 14, 2008
    I've had the same problem as everyone else on this thread (the screen
    says "access" and the lens goes in and out and takes like 3 minutes to
    finally retract itself, but I've also had an additional problem, which is:
    The camera works when I initially start it up after not touching it for
    a few days, but the lens is really not focusing at all. The pictures
    are unfocused (but not grainy, if that makes any difference - just
    generally unfocused). I've tried turning macro and on and off but it
    doesn't change anything. It just seems like holding the
    picture-taking-button halfway down to focus doesn't do anything at
    all. After I go to the picture viewing screen, I can view the
    pictures, but then once I try to go back to the picture-taking mode,
    the problem with the lens not wanting to retract and the "access..." on
    the screen occurs.
    The problem started soon after I uploaded a bunch of pictures on to my
    computer (the pictures were fine, which was pretty fortunate) and I
    accidentally left the camera on and the battery ran out. I'm not sure
    if that gives you any insight...
    Anyway, I'm really frustrated because these problems happened only a
    few weeks after my warranty ran out, so I really don't want to have to
    send it in for repair. Any help would be greatly appreciated!
    If you are unable to offer a solution that works on my camera, however,
    then if you could offer a rough estimate on how much it might cost me
    to send in my camera, I would really appreciate it. If that's not
    possible, it's okay, but I really just want a ballpark measure so that
    I'll be able to make a decision on whether or not I should get it fixed
    or (very unhappily) invest in a new one.
    Thank you!
  • Anonymous Aug 18, 2008
    it says access" turn pooff and on...nothing else gonna happen...what can i do??
  • albertdejeu Aug 23, 2008
    Na het aanzetten komt er op het display "toegang" te staan waarna de lens inklpat en uitschuift en het toestel vraagt om het uit en weer aan te zetten maar ik krijg geen toegang
  • m4tthias Aug 29, 2008
    Same problem. Lens goes in and out for 3 times. Access. Turn the power off and on again. Never buy Sony Cybershot.
    Is there any 'proper' way to bang the **** out of it ?
    Thanks
  • Anonymous Oct 07, 2008
    Same problem here. It kept saying access and that I have to turn it off and on again. I did what I read on here. It works find now. Hope it keeps doing that.
    But if you have the same problem like your reading, follow the directions and it will hopefully work for you too.
    Dont be scared to bang it.
    R. Ramos
  • johanssonsan May 07, 2009
    I tried the bangin-thing to, it worked! But now when the lens is out, the picture is unfocused. Anyone else with the same problem?
I had the same problem with my cybershot w55. I looked around online and found out that all you need to do is smack it around a little or yank on the camera lense. Basically the lense is just out of line. I had to pull on the lense as it was coming out, but some others had to hit the lense or push on it while it is going in and out. Don't be afraid to hit/yank it pretty hard! It has worked for me ever since!
Posted on Jul 30, 2008
  • 3 Answers
I had the same "access" problem as everyone else - but here's the real way to permanently fix this problem when banging and smacking it barely works.
1 - Remove battery and memory stick. Back up the mem stick if necessary or paranoid.
2 - Using a small Phillips head screwdriver, remove all of the screws you see from the front (lens side), right and left sides of the camera. Then remove all three of the covers and place aside.
3 - Clean and remove all dirt & dust in and around front of camera, paying special attention to areas close the lens and lens housing areas.
4 - Insert battery and close the battery cover and then PLACE THE CAMERA RIGHT-SIDE UP ON A FLAT, NON-METALLIC SURFACE, MAKING SURE THAT YOU'RE NOT TOUCHING ANY OF THE EXPOSED CIRCUITS OR WIRING TO AVOID POTENTIAL SHOCK. This isn't a danger issue, more of a cover-my-*** related note. When I did this for my DSC-W55 I touched it just about everywhere without receiving generating anything close to a shock.
5 - Press the power button. If lens does open fully and you're still receiving the "access" message, continue powering off and on while using a toothpick or compressed air to remove remaining dirt and dust particles.
6 - When you're DSC-W55 is back in business - and after you've tested it multiple times via several on/off cycles, begin replacing the covers one at a time. The trick is to replace one cover, then to test the camera again via several on/off cycles. Do this until you've reattached all covers and camera is fully operational once again.
Tip - you may find success early by varying the tightness of the screws for each side's cover as you move along the on/off cycle process.
Posted on May 30, 2009
Amazing !!! cant believe that banging worked...so so happy
Posted on Oct 07, 2008
Awesome!!!! guess what mine worked. i had my camera put up for over a year because of this problem, but then i decided to search a fix for it and i seen that banging it worked for everyone so i tried it myself and wallah it worked thanks guys y'all are the best.
Posted on May 18, 2009
I just ended up breaking mine more with the lightly tapping to banging it hard, used the advice on taking apart and amazingly it was like new!!!
Posted on May 31, 2009
Posted on Oct 08, 2008
Banged it once and now it is working fine. Thanks alot.
Posted on Oct 06, 2008
Thanks lorihott for the BIG BANG THEORY...it works again and I'm so happy!!!!!
I am so thankful for you!!!!
Posted on Oct 03, 2008
I was so excited to see you people solved this problem, till I tried it and made it worse. BEWARE, you are taking a chance with this "solution". I think I'll just thgrow this P.O.S. in the trash and buy a real camera
Posted on Sep 27, 2008
Wow I am amazed that really did work!! The banging thingy! I was afraid but I figured what do I have to lose.....would've had to get rid of it if it never worked anyways! Thanks for the 'technical' advice.
Posted on Sep 24, 2008
It WORKS! I whacked my camera on the lower left side (looking at it from the back). It worked well. Thanks for the info and for saving me $110 for a service visit.
Yippeee!!!
Posted on Sep 22, 2008
Omg soooo i deff agree with everyone else about lorihott
i was scared to bang my camera
but after pulling the lense out and pushing it in...nothing worked
so i turned it on and banged it pretty hard and now it works just like it used to!
thank you sooo much!
i really needed my camera tomorrow and ive tried everything!
Posted on Sep 12, 2008
Arghh I broke mine moree. =[[[
Posted on Aug 20, 2008
Great Site. Thanks for all the help :) I was so frustrated that my W55 was doing what so many others was doing. I was expecting expensive repairs.
I tried banging but finally had to get a letter opener and pried the lens out. Works fine now.
Posted on Aug 17, 2008
If your lens is not even coming out which mine did not.. smack the side REALLY REALLY hard. surprised it worked. thanks lorihott. = )
Posted on Aug 15, 2008
Lorihott - THANK YOU!!!
I am still confused how this started happening (it happened to mine like a virus almost as a result of trading memory sticks).
Thanks so much for your help!
Posted on Aug 14, 2008
Yes! i love who ever came up with bashing it about!
whoop. it fixed mine too.
thanks.
Posted on Aug 12, 2008
This worked for me too. I tried pushing and pulling the lens, but eventually just smacking it worked. Sony eSupport had no idea what to do and refered me to a repair center. Thanks!
My lens doesn't come out either?! what do i do! i've been banging it around i'm afraid i'll break 'er!!
Posted on Aug 10, 2008
The solution of banging it around worked - amazing - i'm off back to Currys to tell their tech guys!!
Posted on Aug 09, 2008
  • thebunces3 Aug 09, 2008
    amazing - bashing the lens when out solved the problem. i'm off back to Currys to tell their tech guys !
Dood my lense doesnt even come out ! ! !
LMAOROFLPIMP here...it works...!!!
You probably saved us a zillion $$$$ in repair fees.
Thanks so much
Lorihott i owe you my life you are so amazing i tried almost everything and i just had to smack it around a bit with the lense outt thnkssss
Posted on Aug 05, 2008
LORIHOTT YOU ARE MY GIRLLLL! I HAVE BEEN TRYING FOR WEEKS TO GET THIS DAMN THING TO WORK! BANGING ON IT DID WORKKK!
LOVE THE BON QUI QUIS!
Posted on Aug 02, 2008
I found the RESET button, I think, and it soloved the problem for me. My camera works just fine at the moment.
The RESET button is behind the battery, a little round hole with a very small button in. Use something sharp to push it easy and then put the battery back and try again. Worked for me!
Posted on Aug 23, 2008
I had the same problem as all of you... I wooped on it... removed the battery and pushed a paperclip into the very small round holes to reset (2 of them) behind the battery. Works again like the day I bought it. I think the reset is is your first step.
Posted on Oct 20, 2008
My ps3 says "a serious
This is one of the most serious PS3 errors you can get. You can try access the PS3 service menu and doing a restore.
How to get access to service mode
  1. Make sure the PS3 is turned off,
  2. Press and hold the power button on the PS3 it will power on then power off.
  3. When it's off press and hold the power button again until you hear two consecutive beeps.
  4. It will ask for the controller to be connected via the USB cable,
  5. Turn on the controller and you will have access to the menu.
Hope this helps.
Feb 09, 2011 | Sony Playstation 3 (PS3) Console
A single sheet of paper has jamed, can not release it.
Clearing a paper jam
If the paper jams in the printer, follow the steps below to clear the jam:
Remove the paper stack from both paper trays.
Press the POWER button. Instead of turning off, the printer will try to eject the jammed sheet.
If the printer cannot eject the paper, unplug the power cord from the back of the printer.
NOTE: Do not press the POWER button again before unplugging the power cord.
Open the rear access door at the back of the printer. To do this, press the handle to the right and then pull out the door.
Remove the jammed paper. Make sure no small pieces or obstructions remain.
Reattach the rear access door and plug the power cord back into the printer.
The printer will turn on automatically and be ready for printing again.
Reload the paper in the IN tray.
Try printing again.
Nov 25, 2010 | HP LaserJet 1010 Printer
When I turn the camera on it says access , the lens goes in and out then I get a beep and message reads turn the power off and on again. I've done this over and over again and it still won't work. ...
One thing to test before going to repair, make sure you are using a fully charged and correct battery for your camera.
If so, the camera will need repair. This is a common problem and can be fixed. Teleplan Camera Repair does a great job and their blog is also very informative.
Repair: http://www.teleplancamerarepair.com/Sony_Cyber-shot_DSC-W30
Aug 04, 2010 | Sony Cyber-shot DSC-W30 Digital Camera
Hard disk drive corrupted, must be restored, then after restoring it restarts and says the same thing again and restores again
Dear,
you may try to use the PS3 recovery options.
The PS3 stores a copy of firmware drivers on the hard-drive and will reload any corrupt files. To access the recovery menu, do this:
  3. When it's off press and hold the power button again until you hear two consecutive beeps. When you hear the double beeps immediately take your finger off the power button (if your system turns off before you get a double beep just try again and hold the button, it should double beep the 2nd time you try)
Please rate my solution ++++ if it was helpful, or feel free to ask for more information. Thank you
Peter_Rei
Aug 01, 2010 | Sony Playstation 3 (PS3) Console
Hard drive corrupted
Either Replace it or try accessing the advanced menu and select option 3
To Access the advanced menu make sure your ps3 is on standby..then hold th power button soo that it turns on and then off again..now press and hold again until you hear 3 beeps (excluding the beep when you turn it on again) it should sound like this beep..............beep beep..
then plug your controller into a usb slot and select option 3
Feb 19, 2010 | Sony Playstation 3 (PS3) Console
Turn the power off and on again message
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Feb 15, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Every time I try to turn the camera on it beeps and the screen says access... then says turn the power off then on again. Why?
This problem is related to optical zoom motor,The part detail is given below:
Part No. Description
A-1231-924-A LSV-1160A
Replace the said part number and your camera work fine again.
Thanks for using fixya.
Jul 29, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
My camera Access and then say turn the power off and on again
Camera needs to be serviced. The camera got dirt in it and needs to be taken apart and cleaned. This should be done by someone with knowledge of cameras because they consist of many parts inside.
Jun 17, 2009 | Sony Cameras
SONY CYBER SHOT NOT WORKING
Hello samtx930, "turn off the power and on again" its a very commen problem and occurs when the lens block assembly start malfunctioning. Actually the slide motor not work properly and until the lens not come out completely the camera will not work, that's why the error message appears "Access" and then screen shows "turn off the power and on again". In this situation you have to replace lens block assembly.And the part No. is with description is given below: 1-788-363-11 OPTICS UNIT (ED13A) Thanks for using fixya.
Jun 14, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Sony DSC-S600
If you have a memory card in the camera, take it out before turning the camera on
Aug 24, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
7,192 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
