Question about Toshiba Satellite M35X-S111 Notebook
Darkscreen computer screen went dark. Does not completely eluminate
  • 1 more comment
  • robertgee May 19, 2008
    Where is the frony bezel?
    None of the above were successful!
  • robertgee May 20, 2008
    Thanks but I,m off to purchase a new computers .
  • 3,037 Answers
Sounds like backlight went out.
This is sometimes caused by loose connection or a bad inverter sending power to the backlight. If you're lucky then resetting the inverter connectors will help. The inverter is usually located in the same panel as the screen, You will need to look in your manual to learn how to disassemble it to access the inverter.
Also, see if the light goes back on if you wiggle the screen part back and forth a few times or shake the laptop a little.
let me know of any further help that you may need.
Posted on May 19, 2008
  • Benjamin Patri
    Benjamin Patri May 19, 2008
    You may have to replace your inverter if wiggling or shaking did not fix the problem. If you are good with electronics then you could probably do it yourself.
  • Benjamin Patri
    Benjamin Patri May 20, 2008
    Well, I'm sure if you want to sell the one with problems you could get quite a bit for it from someone who knows how to fix it.
    Please feel free to give me some feedback by rating my solution, thanks
    Have a Great Day! and good luck on the purchase
  • 2,335 Answers
I would suggest to open the front bezel and check for proper connections to the ballast circuitry or a broken wire will also cause this failure.
  • Jaime Hernandez May 19, 2008
    To get access to the circuitry for the backlight you will need to remove the screen frame that is in front to hold the screen in place.
    You will find some hidden screws under some small rubber(s) that are used to keep a space between the keyboard and the screws.
  • Toshiba Master
  • 13,433 Answers
Its possible that the backlight is failing.
Try pressing the FN (function key) and the more light button, it most likely has a bright sun on it, possibly the up key.
  • Ekse May 19, 2008
    Might not be the arrow up. Look at your keys there should be light blue icons on the keys look for the one that increases the backlight.
  • Ekse May 19, 2008
    also the button which turns off the backlight when the cover is closed might be stuck. see if you can find that button. Its very small and doesnt have any markings on it. Look around the laptop when the screen is closed it touches the switch.
Screen went black but sound stayed
Your Xbox Rims In Xbox ARE NOT WORKING.
May 16, 2013 | Microsoft Xbox 360 Console
Last night the screen started going dark, then went out, black
If still under warranty, I would suggest going that way as this is a bad matrix driver....
Feb 15, 2010 | Sony Televison & Video
My screen goes dark every time i completely open my walkman 760a
Dropping you phone every now and then is very detrimental to your phone. What you are currently experiencing is a flex problem since you are using a flip up phone. You have to take the phone to a technician to refix the fllex for you.
Jan 13, 2010 | Sony Ericsson Walkman W810i Cellular Phone
My screen went dark suddenly, when I try to restart my computer the screen is tinted red before going dark again. The screen is not completely black as there is letter visible underneath.
From what you are describing, it sounds like the inverter board is failing. This board sits under the LCD screen and is responsible for taking the DC voltage from the battery and AC adapter and converting that voltage to high voltage AC power for the backlight lamp that sits inside the lcd screen. Without that high voltage the screen goes dark. Most inverters do not fail right away, there are voltage fall offs etc. Inverters are approx. 15-20 bucks on ebay, for most laptops, they can be changed out simply by removing the bezel around the screen, unplugging the two connectors on the inverter and changing it out. In most cases except Dell, the inverter is just sitting in there and is not held in by screws.
Nov 30, 2009 | Toshiba Satellite A100-S8111TD Notebook
Screen is dark
DID YOU TRY EXTERNAL MONITOR TO SEE IF IT IS A SCREEN ISSUE
ROD
Feb 09, 2009 | HP Pavilion zd8000 Notebook
Acer Travelmate LCD screen went dark
The same thing happened on my HP. I ended up buying a LCD screen off ebay. That corrected the problem. New screens cost $150+. You can get one off ebay for half the price.
Jan 16, 2009 | Acer TravelMate 270XV Notebook
Screen went dark
this hapeened due to the fialure of a thn light placed in the screen . it cn be replaced but it cost more. its a flurocent like tube placed in the screen provided in the top of screen
Jan 28, 2008 | HP Compaq Presario V2000 Notebook
Toshiba Satellite M35X-S111 Notebook Logo
43 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
