Carrier evaporator coil
My dad, retired hvac commerical saw an article regarding my Carrier unit and the evaporator coils giving out before warranty expires. My warranty (5 year) just exp in April and now evap coil is shot. Is there a recall out there? We are in Grand Prairie, TX.
Thank you
R.A. Kay
  • 3 more comments
  • texasjenn1 May 27, 2008
    having same issue highland home not even 3 yrs yet, leaked on my wood floor caused damage and I am hearing that the builder is taking care of the issues with other people on my street saying they know the coils are defective but no recall as of yet from CArrier but if you need more info let me know---who is your builder?
  • Anonymous Aug 01, 2008
    I have a American Standard Unit that is 5 years old and I had the same problem, the coil had pin holes in it . American Standard replaced the defective part but will not cover the labor. I belive that because it was defective and there are many other defective coils that they have had to replace it should be a recall. I have emailed them but they have not responded to my secound email.
  • aaa1702 Oct 21, 2008
    I had a evaporator coil leak on a 2 yr old unit Carrier unit. I had to pay $125 to have the system recharged. After 3 months it stopped cooling again. The service tech who responded the second time had a very good idea where the leak was and stated Carrier has had a big problem with evaporators failing. The part was replaced at no charge this time and after asking the HVAC company about the warranty, they said the new coil would be warranteed for 10 years (no labor). The HVAC sales rep stated they've had to replace many of the evaporator coils and wouldn't recommend buying Carrier in the future. There to many options. I'll not buy another Carrier.
  • dorjac Dec 16, 2008
    We built a new house in 2007 and have had bad odor cming from our registers. In doing some research on our units, I discovered that we have a preferred series heat pump in Bryant and builders grade coil in Carrier. I have made numerous calls to Bryant but the only thing they have offered us is to install an air purifier, which would cost us over $100. to run a month, according to our electric company. Bryant diagnoised our coils of having Dirty Sock Syndrome, which is a bacteria growth on the coil.
  • leclair Jan 15, 2009
    i purchased my townhome in Feb. 2003. i have a carrier 2 ton. it has always been low in freon, so i have needed to add some and have it recharged every year. i left in 06 and returned in 07. i could not get the house cooled. i was told that i had leaked over 2.5 qts of freon and that there was a leak in the coil. a $1400 repair. the ac went out of warranty in feb 08. of course. is there a way i can buy the part separate? is this something that a lic. hvac needs to do? i live in summerville, sc. any recommended installers. thanks, cherie
    Problem Solver:
  • 8 Answers
We are from ac company in Georgia,and I personally have changed out over 50 coils this summer. Mostly 2006 and 2007 models, R22 and R410a..I think there is a BIG problem and if you push hard enough they will pay the labor.
Posted on Oct 31, 2008
  • mrcooler Nov 18, 2010
    Hey gking I am a sevice company as well- what is theprocedure for replacing the evap coil in a package unit model 48vl series? Do you have to cut refrig lines and remove the top condenser section?
    Thanks
  • Herbie Hutchins May 19, 2013
    I do this trade for a living and see alot of evaporator coil are not just leaking from carrier ALL the manufactures are having the same problem. Carrier is the better of them all.
I recently contacted Carrier Corp after our routine annual HVAC check on our residential system indicated that our 4 ton AC unit and 3 ton unit had leaking evaporator coils.
They basically told me to shove it in a very curt letter - In other words even though a leaking evaporator coil is a manufacturing defect they will not offer any financial assistance in replacing the failed evaporator coils.
I spoke to several HVAC engineers and they indicated Carrier has a high percentage of evaporator coils and compressor failures on residental HVAC systems.
The copper wall of the evaporator coil is being drawn thinner than in earlier years and the R22 being acidic slowly eats through the copper tubing.
Evaporator coils should not fail according to the HVAC Engineers if properly manufactured.
The Bear
Posted on Jul 23, 2008
  • phillipwicks Aug 03, 2011
    The r-22 refrigerant is not acidic. if the unit is properly installed, vacuum the system install a filter drier , charge the system with r-22 refrigerant you should not have a problem . it's the unseen person installing the equipment not following proper procedure. that is why carrier does what they do. they can't control the installation. I'm a independent HVAC tech and not a carrier lover
    Scholar:
  • 57 Answers
In some cases if you complain to Carrier Corporation... LOUDLY they will wave the out of Warranty because of the closeness. Make a point of stating " I'll never own another Carrier anything " might help. I have seen this work. If it dosn't work the first time try again and ask to talk to the supervisor over who your talking to. If the coil is bad now it must have been bad in april while under warranty, leaks usually start slow could take a year to leak out.
also let them know your Dad is a HVAC guy this could also help. THE WHEEL THAT SQUEAK'S GETS THE GREASE.
Carrier is a large company and does not like unhappy customers. Good Luck
Posted on May 20, 2008
Studies have concluded that it's not the coils, but the gas-off from building materials in new home construction that are reacting with, and to the metal in, and on ALL coils, not just Carrier coils. Although Carrier coils 2003-2005 used for R-410a were in reality, R-22 coils that could not withstand the higher pressures of Puron.
Posted on Dec 12, 2008
I just found out that my 2 year old 4 ton Carrier coils need to be replaced because of a leak. I have the Performance N coil model CNPVP with Puron. Repair company says parts are covered, but labor will run $750. I contacted Carrier and they said I can ask for a review. The family next door had the same repairs done last year and Carrier has not paid for his labor. This is there email response back to me,
"Thank you for contacting Carrier. On behalf of Carrier Corporation, I apologize that one of our products has failed to meet your expectations. Labor and service charges are not covered under the manufactures warranty. However, our Management Review Board is willing to look into this matter for you. In order for them to do so you will need to have the work done and paid for. As soon as that is done we will need a copy of the paid invoice to investigate further. Please advise if this is what you would like us to do."
Carrier is a piece of $hit if they don't pay for the labor. Carrier stand behind your products and workmanship. My house was built in late 2007 and I'm the only owner. Used the A/C for 2 seasons, just like my neighbor.
PS - The repair people are replacing mine with tin covered coils, so hopefully these screw-ups at Carrier can do it right this time!
Posted on May 19, 2010
I have a 2ton and a 3 ton carrier in my house 5 years and 6 months as of december 4th. both coils have leaks!!!! carrier told me the same thing,they know the coils are no good,and are going to do NOTHING about it. Told me Too Bad **** it up because carrier will do nothing for me, now are in the future. Only if the courts make them do something!!!!! I am replacing my systems with TRANE systems. have talked to several neighbors that have TRANE systems have had no trouble at all with there units. i even called TRANE asked what would they do in my case. The response GIVE ME NEW COILS AND HAVE THEM INSTALL UNDER WARRANTY AT NO CHARGE!!!!!!! Thats right FREE of charge. Guess why i am spending over $10,000.00 replacing those pieces of #%&$ Carrier systems. Because if coils are bad after 5 years, what about the furance and the outside units?
Preston
from Louisiana
Posted on Dec 15, 2009
This is ridiculous.. unhealthy and they need to be shown that wasted resources calls for bankruptcy after a well awaited lawsuit. Many Carrier furnaces already lost the lawsuit over an issue with the secondary heat exchanger design. They designed the secondary exchangers on hi/-efficiency furnaces with two types of metal that are inevitable to rust just after the warranty runs out. Come on people, we don't need to be rocket scientists to realize that they knew this. I'm calling the company again tomorrow. I am sick and tired of paying the piper to come and inspect our furnace/leaky evaporator coil and him with his vacuum in hand and nothing more to offer than I could have already done myself, says, "it's normal." I then asked the carrier serviceman, "Ok, so what about the gas byproducts and the water vapour it's pushing through my vents when the central air is on?" He shurggs and says, "It's not the carbon dioxide you have to worry about, it's the ammonia." What a waste of time and money. He then leaves after getting paid $130.
Posted on Aug 12, 2010
  • seaausa Sep 25, 2010
    I am having the same problem.The inside coils are leaking which causes the coils to sweat (because it gets low on freon) and leak water (all of water) which is dripping on the 1st floor ceiling.
    seaausa the coil will sweat all the time. its called warm air hitting a cold evaporator coil. when it gets low on refrigerant it will not sweat that much it will start to freeze up.
Our Carrier evaporative coil is broken beyond repair due to copper too thin to hold the refrigerant. Our home and A/C is less than 4 years old and the AC repairman said that if we replace it with another...
If in fact the coil is less than five years old then the parts should be under warranty. Labor only charge. As for the tubing, all coils have very thin walled tubing as to transfer heat more effectively. Aspen coils did have defected coils which were manufactured for a number of brands at about the time you purchased your unit. The manufacture may step up and help if you contact them directly, customer support from Carrier. Estimated cost for labor depending where you live should be between $500 to $800 dollars depending on installation. It could be a little more if it is an attic installation.
Aug 24, 2011 | Heating & Cooling
The unit is freezing up and leaking alot of water
Hello, first thing is check the condition of the filter on the front of the unit, if it is dirty wash it and let it dry then reinstall it. Also, it is a good idea to clean the evaporator coil with a can of coil cleaner that you can pick up at any heating and cooling store. Just spray cleaner on evaporator coil and let it dry. If this does not solve the problem tjen the unit might be undercharged and will need a hvac tech to recharge it
May 04, 2011 | Haier HWR06XC9 Air Conditioner
My window unit is not blowing cold air
Hello, usually when a air conditioner does not ool it falls into two categories, airflow or low refrigerant charge. The first thing is check the air filter and make sure it is clean, if it is not was the filter with soap and water and let it dry. Tjen check the evaporator and clean it with some coil cleaner, ypu can purchase coil cleaner at a hvac supply house, and then spray it on the coil and let it dry. If this does not help then the unit is low on refrigerant and must be fixed by a hvac technician.
Apr 20, 2011 | Frigidaire Heating & Cooling
My rudd uaka 037JAZ leaks, like to replace just AC and not coil and furnace motor. Replacement suggestion for this unit? Homeowener George
Hello, it depends where the unit is leaking from, if it is leaking from the condensing unit then you can just replace the condenser, however if it is leaking from the evaporator coil then you will need to replace the evaporater. As far as brand for replacement I like rheem equipment. The best thing to do is have a hvac technician come out and give you a estimate on a new AC and then you can make a decision.
Feb 21, 2011 | Ruud UAKA037 Air Conditioner
John. Heidel@MSSB.com I have 2 carrier units both installed in 2006 and still under warranty, they are a 38brc030 and 38brc042 the evaporator coil in both units have to be replaced and the compressor coil...
The best thing to do is to call Carriers customer service line or their tech. support number... often times the customer talking to the co. directly will get better results then the dealer talking to them...
The dealer does need to recover thier costs also... they do not make that much money on the initial installation...
It is worth a phone call or two for you to call the factory and tell them how you are going to tell all of your friends NEVER to buy any carrier products because they do not stannd behind them!!!
heatman101
Aug 19, 2010 | Carrier 38BRC036 Air Conditioner
Window A/c 10 or 15 days is good working\r\nbefore !0 or 15 days ago all Eveporater and section line freeze fan moter good praper work melt the freeze and A/C on A/C giving good cooling what is problem
Hello
You may try cleaning the evaporator filter,Also cleaning the outside coil or condensor,Simple green works good for cleaning coils and a garden hose.
Also cleaning the evaporator may help.
When unit is running properly the evaporator should feel cool and wet from top to bottom.
Last,the unit could be low on freon.
Jun 10, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Looking for evaporator coil cd5axa036017abaa . three years of recharging rather then fixing now the coil is out of warranty and Carrier and service company will not stand behind product.
Hi, if you have a leak in the evaporator coil which this happens a lot and they came out and didn't try to make any attempts in finding and repairing the leak or they found it in the coil and didn't order a new one, this is against the law by E.P.A standards. They must make every attempt in making the repairs if it means replacing the coil, no if, ands, or buts!! Keep your receipts on them charging the system. Now that its out of warranty, I would call them and bring this up about not changing out the coil when the leak was found. I am sure they used dye to locate it.I have found more leaks in the evaporator coils then I care to count, and had to replace the coil. This is something you can't do on your own I must say, as it takes special equipment to do this job. I would call the Enviormental protection agency and tell Carrier you will do this, and report them. I bet they will stand behind it then. You have to get tough with them. I am a air conditioning contractor and know the law. The E. P. A. will get them on the ball trust me. This is bull+)_(*&%!* !! Don't let Carrier walk on you, this coil should have been put in the schedule to be changed out right away, not to continue to charge it to get you through. This is a 3 ton split system. Stay on them, this will be covered if you make the call and stay on them. The E. P. A. are very strict on this as this is why they have stopped us from venting freon into the air, they have very strict guide lines we must follow and Carrier did not follow them on your unit. Please keep me posted, and the best to you.
Sincerely,
Shastalaker7
Mar 26, 2010 | Carrier 38CKC030 Air Conditioner
Looking for evaporator Coil number for Carrier Model 24ANA736
Are you replacing or adding an evaporator coil to this system? If replacing, please give us the model # (and product #) of the evaporator coil. If you can't find one for it, we will need the air handler (or gas furnace) model # so we can help you match it up.
If you just want the condenser coil for that condenser, the part # is 331230-7035.
Mar 24, 2010 | Carrier Heating & Cooling
I have to replace my Carrier coil.
Carrier did have some problem with coils but not as much aas Trane and other companies did. Contact Carrier direct and tell them whats going on and that you have always trusted Carrier to have a good product. They may pay for aprt of your coil replacment.Russ Carrier Dealer
Jul 18, 2009 | Heating & Cooling
Model number for Carrier furnace with issue for blower 5 minute off delay
I believe that this model number is for an air conditioner evaporator coil. This unit is probably directly attached to your furnace. The Model number for the furnace will be located in the compartment where the flames can be seen. It will be on a sticker or plate that contains lots of other information too like BTU/h, Volts etc...
The number you gave me gives me this info:
Cased air conditioning evaporator coil.
3 Tons
Horizontal application
Jun 27, 2008 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
16,989 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
