Question about Konica Minolta magicolor 2430 DL Laser Printer
Where are the Toner Contacs located?
Where do I find the Toner Contacts on the KM 2430? I too am getting the error message that no toner is installed. They are all installed.
The printer won't allow the toner carosel to turn either. Is there a way to manually turn it to get the toner cartridges out?
Thanks
  • wayne churchill May 11, 2010
    Look into the printer where you install the toner cartridges, you will see the contacts at the back (you may want to use a torch).
    Has the problem with the carosel only happened since replacing/ removing one of the toners??
    New Friend:
  • 16 Answers
On the right side of the toner cartridge you will see a green chip with three copper contacts on it. Those are the contacts you were looking for. You may see black lines on them. Clean them off with an eraser or rubbing alcohol.
Posted on Jul 18, 2008
On the right side there is a vertical **** with a square hole in the middle. If you push down inside that with a screwdriver, it will release the rack to rotate.
Posted on Jun 13, 2008
Kyocera km-2550 check toner container error
Set toner container. The toner container is not set properly. Set the toner container properly. See page 5-5 of the operation guide.
Replace Waste Toner Box The waste toner box is full. Replace the waste toner box with a new one. See page 5-5 of the operation guide.
Jun 13, 2011 | Kyocera Mita KM-2550 All-In-One Laser...
We have a Kyocera Mita KM 1510 and I am getting an error code C710 and the add toner light is on. I put in a new toner cartridge but the error message and the light are still on. Any suggestions?
C 710 is a Toner Sensor Problem
Defective toner sensor - Replace toner sensor
Poor contact of the toner sensor connector terminals - Reinsert the connector. Also check for continuity within the connector cable. If none, repair or replace cable.
Developer problem - Replace developer.
Apr 07, 2011 | Kyocera Mita KM 1510 Laser Printer
Have a Konica Minolta 2430 DL and it ask me to install blk toner after install toner it has error line 2408. can you help me?
2408 means that the toner cartridge you are trying to rotate to is already in the top position or you need to install another toner cartridge before you can rotate to the color you want to replace.
To fix the toner not installed message clean the three contacts on green chip on the right side of the toner cartridge. You may see black lines on them. Use an eraser or rubbing alcohol.
Nov 11, 2010 | Konica Minolta magicolor 2430 DL Laser...
I already replace a new toner but there an error msg AP
Hi
The AP message indicates thet the dev is so low in toner that the machine has to go into a full cycle mode to get the toner levels up.
The error code is telling you that one cycle is not enough. you will have to turn the copier off/on and cycle it at least one more time....more if neccessary
Jun 15, 2009 | Kyocera Office Equipment & Supplies
What is C 710 error codes?
You machine toner is empty insert toner
Jun 14, 2009 | Kyocera KM-1505 Copier
Konica minolta 2430
Most likely you received this message after a toner was replaced. Reseat the cartridge and restart the printer. If that doesn't work remove all of the toner cartridges manually and reinstall.
Turn off the printer and open the top cover. Follow the toner cartridge all the way to the right side of the printer (on the white part). You should see a hole that looks like a cross. Take a pen or key and push down on the black button in that hole. While you are holding it down rotate the toner cartridge towards you. You want to get the colored roller on the cartridge about 1/2in away from the metal bar that says "consumable reorder". You should be in a position to take out the toner. Let go of the hole and remove the cartridge. Repeat the steps until all of the cartridges have been removed.
Turn the printer back on at this point. You are going to get toner not installed messages on the printer. Open the top cover and the cyan tray will be in place. Shake the toner and install. Close the cover and let it cycle to the next color (black). Repeat the process until all cartridges are installed.
If you are still getting the error you either have a bad cartridge or the carousel that the toners sit in is damaged.
Jul 16, 2008 | Konica Minolta magicolor 2430 DL Laser...
Error 2408
Jul 11, 2008 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta 2430 DL Xtoner not installed
Check the toner contacts in the printer, you may find one either dirty , bent or broken.
May 16, 2008 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta magicolor 2430 DL Laser Printer Logo
79 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
