Question about Philips Televison & Video
I have blinking red lights on my television. It blinks once and then four times.
  • copop May 22, 2008
    Copop
    The model number of my TV is:
    37MF231D/37
    It blinks red once and then blinks red 4 quick times.
  • Philips Master
  • 8,617 Answers
I would need the model number of your set in order to assist you with your problem. Please post your model number
Posted on May 19, 2008
2 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: blinking red lights
I will need to know the model number of your set in order to be able to help you out with the problem, as different models have different error codes.
Posted on May 23, 2008
Red light blinking four times, pause, four blinks again, etc. etc.
Only a repair shop can tell you what you ask .SORRY
Oct 05, 2015 | Televison & Video
Tv wont come on
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can vet an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. http://electronicshelponline.blogspot.com/
Dec 29, 2013 | Televison & Video
No power red light blinks four times
These blinks (flashes) are fault indication.By the number of blinks occur at one time switch ON, you can vet an idea about the faulty circuit stage inside the TV.Count the blinks occur at one time switch ON, carefully.Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected.If you wish to get more details, check the site linked here.It has blinking codes detail to many brand TVs.Pull up older posts.http://electronicshelponline.blogspot.com/
Dec 29, 2013 | Sony KV-27S42 27" TV
Red light blinks 4 times, no video or audio
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
Apr 27, 2012 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Hi i have lost instruction manual for my total remote urc 11-4110 b02 Universal Remote could you tell me how to code it to tv manually please
@font-face { font-family: "Cambria"; }p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0cm 0cm 10pt; font-size: 12pt; font-family: "Times New Roman"; }div.Section1 { page: Section1; } SET UP
TV
The Search Method
If your device does not respond to the TOTAL CONTROL after you have tried all the codes listed for your brand, try searching for your code. The Search Method allows you to find the code for your device by scanning through all the codes contained in the memory of the TOTAL CONTROL.
To search for your TV code:
1 Switch your television on (not on standby) and aim your TOTAL CONTROL at your TV.
2 Press the TV key on your TOTAL CONTROL.
3 Press and hold down SET UP until the red light blinks twice. (The red light will blink once and then twice)
4 Press 9 9 1. The red light will blink twice .
5 Now slowly, alternate between POWER and TV, over and over, until your television turns off. You may have to press these keys many times (up to 150!), so please be patient.Remember to keep pointing the TOTAL CONTROL at your television when you press these keys.
6 As soon as your television turns off, press SET UP.
The TOTAL CONTROL remote should now be ready to operate your device. Turn your device back on and try all the remote’s functions to ensure they are working
properly. If some of the TOTAL CONTROL’s commands are not operating correctly, try the search method again. You may be using the wrong code.
Once you have Set-Up your TOTAL CONTROL, you can blink back your SET-UP CODE for future reference.
Example: To blink out your Television code:
1 Press TV once.
2 Press and hold SET UP until the red light blinks twice (The red light will blink once and then twice).
3 Press 9 9 0. The red light will blink twice.
4 For the first digit of your four-digit code, press 1 and count all the red blinks. If there are no blinks, the digit is "0".
5 For the second digit, press 2 and count all the red blinks. If there are no blinks, the digit is "0".
6 For the third digit, press 3 and count all the red blinks.
7 For the fourth digit, press 4 and count all the red blinks. If there are no blinks, the digit is "0". Now you have your four-digit code.Make sure you write your Television code for easy future reference.
Aug 12, 2010 | Televison & Video
E50a10 blinks four times
Four blinks is a fan rotation error code which means one of the four fans is not operating properly. Check these fans and replace any found defective.
  • Remove the lamp cover.
  • Remove the rear cover by removing the 13 screws holding it in place.
  • Check the fans.
053bd7d.jpgLocation of fans 1 and 2
Location of fans 3 and 4
Dec 07, 2009 | Televison & Video
Blinking red lights
Take out all the cables (HDMI,POWER,RCA,etc...) and then plug just the power back in and see if the TV turns on, and make sure when you take the power cable out, take it out from the back of the TV, when you plug it back in it should click.
If the TV powers up then try plugging in your HDMI cables and see if that works.
May 25, 2008 | Televison & Video
Blinking red lights
May 23, 2008 | Televison & Video
Red lite blinking
help mine is doing it also, 4 blinks, no power
if any gets it fixed or knows how please email me at
ron1978@comcast.net thanks
Dec 27, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
23 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
