Question about AT&T 954 Corded Phone
Two lines stay lit
I've tried to use book and it does not work
  • Anonymous Jun 11, 2008
    Line 3 and 4 stay lit up and cannot use those lines handbook has no solution.
    Problem Solver:
  • 5 Answers
I suspect someone disabled lines 3 and 4 on these phones.
To re-enable these lines:
1. Press PROGRAM
2. Press *
3. Press #.
4. Enter one digit on the keypad for the line number.
2=L2
3=L3
4=L4
5. Press 0 to turn the line off, or 1 to turn the line on.
6. Press Trnsfer. You will hear a confirmation ring if you entered the data correctly.
Alternately, you may have only plugged the line into the L1/L2 jack on the back. This phone does not take a 4-line jack, but instead takes two 2-line jacks.
Posted on Apr 30, 2009
Why does flame sputter and doesn't stay lit?
Either a lot of air in the lines, or the wrong pressure regulator is installed.
Nov 28, 2015 | Heating & Cooling
Pilot will not light after repeated attemps. Shut main gas line off as book suggested. Re-lit burners and then oven pilot. Pilot only stays lit if holding red pilot button
90% chance your thermocouple is bad.
This should work: http://www.partstown.com/southbend_range/sou1196078
10% chance your red push button safety valve is bad. If it is really hard to push in I would recommend changing that as well.
Jan 27, 2014 | Southbend 4603AA-2TR LP - 60-in Range w/...
How do you shut off the brake warning light?
The float in the brake resevoir appears to be stuck at the low fluid level. Try taking off the cap and moving the float to seeit taht works
Jan 27, 2013 | 1999 Toyota Camry Solara
Malta dryer burner won't stay lit
usually a clogged vent or I've seem a coil go bad that allows it to light once but not the second time in the cycle
Feb 01, 2012 | Maytag Dryers
Phone won't shut off. Display stays lit all the
The software got stuck whil shutting down. Try resetting it to factory defaults after saving your phone book and other valuable info on there.
Jun 26, 2011 | Samsung Cell Phones
Empire DV-210: Pilot light will light and stays lit, but when I
The thermocoupler is no good. It's that bulb sitting in the pilot flame. when it goes out it shuts everything doen in the main valve. It has to be kept hot by the pilot, that's how it know whether or not it is safe to open the main .
Oct 07, 2009 | Reddy Heater-10-12-15,000 Btu L.P.
Empire wall furnace won't stay lit after addional tank added.
Air in gas line? Bleed the gas line and try again. Make sure tanks are on.
Nov 27, 2008 | Empire GWT-25 Wall Mounted Panel Heater
RCA executive series
No ringer could well be a setting and light on 2nd line means their is No 2nd line and most 2 to 4 lines phones at least require 2 active lines for the system to work correctly
Mar 30, 2008 | RCA 25202RE3 Corded Phone
Line 2 stays lit even though I don't have a second line
I would like to add a fax machine to my unused 2nd line. What is the proper way to hook it up so it does not interfer with my regular phone line #1? Please advise
Mar 05, 2008 | RCA 25202RE3 Corded Phone
AT&T 954 Corded Phone Logo
262 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
