Question about Sharp AR-M280N Copier
Sharp AR-M280N- Printing dark lines
Our is printed several dark lines across documents, and somtimes faintly repeats text from the top of the page in the middle of the page. Any thoughts on how to fix this problem?
  • atmsi8492 May 23, 2008
    Thank you for your help.
    Where would you remommend that we go to get a new drum?
    Do you happen to know what model # I am looking for?
    Problem Solver:
  • 5 Answers
Sure there is toner on the up charger just lose and clean it. And you have your normal copy back
Posted on Aug 22, 2013
  • Sharp Expert
  • 1,326 Answers
It sounds like you are going to need a new drum and drum cleaning blade. How long has it been acting up? When was the drum last replaced? The image repeatting could also be coming from the UFR??? It really depends on how many copies you have on it and has it been seatting for awhile..... Need some more info... But you most likely will not be able to fix your self..
Posted on May 21, 2008
SHARP M455N PRINTING LIGHT
The ink toner is is now infected by foriegn matters by effecting the printer laser head.Tries air compressor machine blow out the ink toner print head ink injector and laser printer print head.Wait about and hour reinstall the the ink toner to the printer,the toner should work find again.Not the ink toner is not saveable,must have be replace for normal operation again.
Mar 18, 2014 | Sharp AR-M455N Copier
Printer is only half printing doc on each line, have done test page, very faint, aligned ink, clean cartridges, all with top v faint and bottom dark ink, new cartridge last fri and was working well,...
Open the rear of the printer and make sure theres no paper jam or broken parts.
Try printing a document with the rear of the printer open and watch to see if anything out of the ordinary happens.
Mar 01, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
How much could i sell my ar-m280n copier for
Check online or ebay to get an idea. It depends on the market and how much you want to recover. Also the economy in your state
Nov 17, 2009 | Sharp AR-M280N Copier
Sharp AR-M280N -scanner
the ip address is not configured correctly in the machine. You may be able to print but the scanning server is incorrect.
Dec 09, 2008 | Sharp AR-M280N Copier
Black Lines
Do the black lines only show up when useing the adf???? Or do they show up on both the adf and the copyboard glass??? If it is only when using the adf...... The fix is easy.... you have to clean the smaller piece of glass that is to the left of the copyboard glass with windex or rubbing alchola. If it is with both you may need a new drum and blade or a new ufr... Good Luck
May 20, 2008 | Sharp AR-BC260 Color Copier
Printing problem
Are the problem prints all from the same source? If so the problem could be on the transmission end. Can you connect to your fax and print to it from a local workstation? If so print several images with dark solid patterns and see if it is actually the printhead. Try printing in cyan, magenta, yellow, and black colors to to rule out each individual printhead.
Jan 03, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Sharp AR-M237 Grayscale Copier Problem
Yes.There should be settings to enhance that in your print driver properties page.
Easiest way to access that is to open a document and click "file' then 'print and that will bring up your printer options.
Look around the print driver for ways to enhance your prints.
Most drivers have several options in graphics areas to make adjustments.
You can access printers from the controle panel and also right click the printer and select properties to access it.
There definatly are ways to adjust that.
Hope this helps you some.
Dec 19, 2007 | Sharp AR-M237 Copier
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
Sharp AR-M280N Copier Logo
112 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
