Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
Green Spots I have what looks to be green magnet spots on the screen, I thought with a projection I couldn't get that.  Any ideas, and solutions?
  • expeditionhi Jul 18, 2008
    I also have the green spots on my 2004 TV, was told my Sony that it may or may not be covered, but they were willing to send out a service technician to find out. The service bulletin states blue spots, so we will see if the technician thinks the spots 'could' be blue.
It's probably the famous optical block problem. I had the same problem, mine were blue, but looked like magnet spots too.
Posted on May 20, 2008
I have a sony lcd projection tv model kf-60xbr800, green spots on the lower right corner , it start with one spot and now the spot are all over the screen
Those Rear LCD TVs get bad light engine on some. Causes fuzzy spots size of quarter. Or sharp small bright spots looks like road map or 'stars'. Need new/rebuilt light engine.
Apr 08, 2014 | Sony Grand WEGA KDF-60WF655 60" Rear...
I have 3 green spots size of a tennis ball on my Panasonice PT52LCX65 TV screen. Anyone have any Ideas?
This tv is a LCD projection it has
a red blue and green LCD pannel that the light shines though The green one is bad. Comon problem for these set.
Oct 29, 2013 | Panasonic PT-52LCX65 44" HDTV
Green Spots on my Vizio VO42LF 10A
ok so what you need to do is have your tv degaussed...its basicly a strong electric magnet rubbed in fron of ur tv screen..you can buy a degauss for 30 us...or its cheaper to just take it to a tv repair...also some new computer monitors have a degauss setting..put the screens facing each other and hit the degauss funcion on the monitor..do it several times or till u see results.....enjoy
Aug 01, 2009 | Vizio L32 32 in. LCD HDTV
Green and purple spots on my screen.
This unit requires the EEPROM correction tool Part # LSUQ0100.Only an authorized Panasonic service center will have this tool.
Jan 14, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
TV issue
There are many causes for spots on top of an LCD rear projection tv, you are probably in the first two cases, both require part replacements and repair job.
If the spots are faint blue, green or pink shadows, then it can be a problem with the anti polarization panel placed on top of the LCD.
Similar spots (colored shadows) may be caused by a problem with the light engine, in that case the fix will be expensive.
If the spots are bright lights, like an aura, that is a problem with the color wheel.
Problems on the light tunnel can cause static gray shadows.
If the spots are static dark stains than that is lcd liquid, the LCD panel must be replaced.
Oct 15, 2008 | Televison & Video
Green spots
Good Day;
It sounds like the TV has foreign objects on the tubes, lenses or inner-screen, such as dust or bugs.l Remove screen from the front and observe.
If it were a TV problem the spots would be near the center of the picture.
Good Luck.
Jun 07, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Nephew used a magnet and put on the screen and made the screen purple and green spots what can I do.
If this is a direct ciew television and not a projection the tv should be back to normal after a few dozen off and on cycles as the TVs degausing coils should correct the issues.
May 03, 2008 | Televison & Video
HELP Green spots
"eprom upgrade" by a Panasonic tech will solve your problem...
Dec 27, 2007 | Panasonic PT-61LCX65 61" Rear Projection...
3 green spots on the top center of my projection hd tv
I had a similar problem and brought it in to a technician for a quote of $860 to fix. The problem - speck of dust on the optics. If it weren't under warranty I would take it apart and blow off the dust myself.
Dec 19, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
179 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
