Question about Dryers
Hunter ceiling fan (model # 20736-300)
Fan was working fan and yesterday starting acting as if the battery for the remote needed changing. (we always use the remote) Today the remote worked once to turn the unit one but then ....nothing. I changed the battery twice but still nothing. I also cannot get the unit to work when pulling the chain. What do ya think?
dave
  • FergusonW Jul 12, 2008
    I have the same problem with one fan. With the others, the remote controls the fan speed but not the light. What's up?
SOURCE: we have a hunter type 2 ceiling fan installed on a bedroom ceilin
Okay. Turn off circuit breaker. Take the bottom off the fan. Mark how the wires are connected. Remove switch by unscrewing the sleeve you mentioned. Take the switch to Home Depot (or the like) -- buy a replacement.
If you have to turn the breaker back on during this process, make sure you have a wire nut over the end of each of the loose wires you disconnected from the switch.
After you take the switch out, you'll know how to reinstall it, so I won't go thru that.
Charlie
Posted on May 12, 2009
protek480
  • 1714 Answers
SOURCE: Dryer wont start. I have went through the wiring but....
If it won't do 'anything' you need to check the whole start circuit. You need a multimeter and some knowledge of electrical troubleshooting to do this. I can help you if you meet the above description...let me know
Posted on Jul 20, 2009
SOURCE: Hunter Douglas Ceiling Fan Does Not Work
have hunter douglas fan glass globe broke cant find repalcemants i have all the serial no do you no wher i can go to find 91/2 globe
Posted on Aug 20, 2009
Controlfrk
  • 304 Answers
SOURCE: The dryer doesn't start when turned on. Has been
The problem you describe is usually caused by a thermal fuse intended to shut the dryer motor down and keep it off because of a problem with air flow within the dryer.
The following process will allow you to test the thermal fuse and replace it if you find it open.
Unplug unit and turn off gas if gas model. Check to be sure you have 240 Volts at wall outlet.
Most parts likely to fail on electric dryers are inside the rear cover. Heater is on right inside can, safety thermostat on lower left of can, High limit thermostat (non-resettable) higher left of can. On the blower housing to the left are the operating thermostat and, in some models, a thermal fuse (white plastic). ALL can be continuity checked easily. Always disconnect wire on one side of what you are testing. One will likely be open. Replace the component that fails the continuity test.
The thermal fuse or high limit thermostat failure generally points to a reduction of air flow due to SOME blockage either inside the dryer or in the vent pipe leading out of the house. If you find either of these parts bad be sure to check the vents after replacing parts to ensure the same parts won't fail again.
Posted on Sep 09, 2009
  • 2976 Answers
SOURCE: I have a hunter ceiling fan that lost two lower speeds
The fan motor is burning out. It must be replaced.
Posted on Sep 16, 2009
Hunter ceiling fan model 23285-420 w/remote control...worked fine for about a year then lights would start flashing when turned on. Changed remote control and receiver with no change. Eliminated the...
The problem is not your remote on the fan. It is the light kit. We have the same problem and our electrician diagnosed it as the light kit. This problem started just out of warranty, of course, and we are now purchasing a new light kit to fix the problem.
Jan 28, 2012 | Hunter Ceiling Fans Individual...
Hunter ceiling fan remote lights up but fan not working
Try changing the batteries in the remote it may have enough juice to light up but not enough to start the fan. Thats were I would start and if this is not the issue get back and we can look into this further.
Oct 10, 2011 | Hunter (25417) Ceiling Fan
The remote on my Hunter ceiling fan (Model: 27185 - 060) does not activate the ceiling fan. I can turn the light on manually, but not the ceiling fan. I cannot see the antenna on the ceiling fan.
The first thing you need to do, is change the battery(s) in the hand held remote, as well as the battery(s) in the receiver inside the fan's cowling. Weak batteries will limit a remotes operation.
And, FYI - there is no antenna on the ceiling fan.
I hope this helps you. Thanks for choosing FixYa.
Jul 25, 2011 | Heating & Cooling
Hunter ceiling fan 52 ",
Hey dale. Sounds like either the integrated remote pack inside the fan housing might be bad, or the reversal switch part. If it has a switch on the fan housing to change it from forward and reverse, you could try going to a hardware store and replacing that switch. If that doesn't work, then it is probably a bad remote receiver pack iside the fan, it will be a bigger, probably black little box. If this is the case, your better off getting a new fan, as it will cost about the same. If your fan doesn't have a little switch to change blade direction, 9 out of 10 times it is the receiver pack. If your fan does have a switch for fan direction, there is a good chance it is a bad switch. It could also be both. After 10 years with the fan, you might seriously want to consider purchasing a new fan.
May 17, 2011 | Hunter Ceiling Fan Remote Receiver...
Remote for Ceiling Fan (Model: AC 552 AL) no longer works. I changed out batteries and still does not work
Maybe it needs to be reprogrammed after new batteries. What is the model number on the remote, please?
Jul 12, 2010 | Hunter 52" Ceiling Fan With Light And...
Need the manual for our ceiling fan, Hunter, Park
i have to fans close to each other i would like to change the code on the remote
Apr 24, 2010 | Hunter Ceiling Fan Light Remote Control
Hunter ceiling fan (model no. 25736) and light not starting
Home Depot sells universal remote systems (transmitter and receiver) for around $30 (in Delaware & Pennsylvania) -- don't know price in Chicago).
I'd just replace it. Hunter may be correct that they are the only source for the receiver, but if you get a new transmitter as well, you don't need their receiver. The labor is the same either way.
Charlie
Aug 18, 2009 | Hunter 52" Ceiling Fan With Light And...
Need instruction page for the Hunter light/fan remote control
There is a battery in the hand held remote and another battery in the receiver which gets tucked into the ceiling mount cover. Remove the ceiling cover and you will see the battery there, usually a 12 volt battery.
The upp/down slide is a dimmer.
In the event that changing the batteries doesn't solve your problems, Hunter makes replacement remote sets, available at Home Depot, lowes, etc and usually around twenty dollars.
May 31, 2009 | Hunter Ceiling Fan Remote Transmitter...
Hunter ceiling fan w/ remote won't work
You need to change the receiver inside the fan. It is located in the top canopy of the fan. you don't have to buy a new remote just the receiver to save money and match the dip switches to the remote.
Nov 13, 2007 | Dryers
Dryers Logo
329 people viewed this question
Top Dryers Experts
