Question about Canon FAX L-120 Plain Paper Laser
Canon Fax L100 - toner required even though not empty
on our canon fax L100 it is requesting new toner; even though we've just recently changed the toner.
Any suggestions would be greatly appreciated.
Thanks,
CT
  • coliturtle May 19, 2008
    slight amendment - we've actually changed the toner twice recently
  • sameoldels Dec 02, 2008
    I had the same problem as you, I know this is a very late post but I actually got the fax machine to stop display the message "No Toner Cartridge Put in Cartridge"
    I spoke to Canon Technical support and recommended me to have an engineer turn up on site, or to try the steps given below.
    1. Take Paper out of tray
    2. Lift the toner bay lid, and take the toner out of fax machine
    3. Disconnect the power for 1 minute
    4. Connect the power cable to the fax machine
    5. Wait for the fax machine to power on (will see message drum lost)
    6. Insert toner cartridge
    7. Insert paper
    This process actually worked and has resolved my problem.
    Hopes this works for anyone else who tries this method!
  • 64 Answers
Hi
first do use the original toner if no use the original toner if yes check the toner cartridge may could be brocken ore the toner jammed on it if its ok you have to check the toner sensor that located in side the fax m/c under the toner cartridge may its came out of position .
thanks
Posted on May 21, 2008
Out of Toner / Change Toner - Canon image CLASS MF4370dn
The percentage-of-available-toner is based on calculations made by the printer's internal software -- quite different from putting a measuring-stick into an above-ground oil-tank to determine the ACTUAL level.
So, while the calculations say "zero percent left", there still is some toner inside the toner-cartridge, and so it still prints.
Buy a replacement cartridge. When you finally do run-out of toner, install the new cartridge.
Compare it to buying a new quart of milk, and then using the last 1/8 of the quart of the milk currently inside your refrigerator -- use the "old" milk until it is 100% gone, and then switch to the "new" milk.
Mar 11, 2014 | Canon imageCLASS MF4370dn...
Where do i turn off ECM on Canon l100!
Go to the service menu:
press MENU after that press #
Choose SERVICE CHOICE and press OK
Go down to the ECM MODE
Press OK, change to NO
After that just leave service menu by pressing C
Sep 08, 2011 | Canon FAX-L100 Plain Paper Laser Fax
Fax L100 codice errore durante rx 0033
Information from service manual Canon L100:
Error Code 0033 :DCN was received through a non-normal procedure
Jan 18, 2011 | Canon FAX-L100 Plain Paper Laser Fax
FAX MACHINE CANON L100 ,RX ONLY BLACK PAPER?
Change toner,it may be damage.So you can change.
Dec 14, 2009 | Canon FAX-L1000 Plain Paper Laser
Canon-l100-fax
Under user mode (MENU), there must be something like user sett.
Feb 19, 2009 | Canon FAX-L1000 Plain Paper Laser
Storing FAX numbers in Canon FAX-L100
Hi - You can download the manual from the link underlined in blue below:
FAX-L100
See page 4-6:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Jul 31, 2008 | Canon L120 Fax Laser Printer
Canon L 100 toner cartridge problem
First, before the new cartridge is installed, was the Silk tab pulled out to make the toner accessible?
Are the tabs fully seated when the Toner cart is installed?
If these have been done then contact Canon Customer Care at 1-800-828-4040 8am-8pm EST M-F, Sat 10am-8pm EST
Mar 07, 2008 | Canon FAX-L1000 Plain Paper Laser
CANON FAX L100 COMES UP MEMORY FULL
We had the same memory full problem. Just unplug the main switch and it will automatically reset the printer and you will be able to send and receive faxes after.
Feb 05, 2008 | Canon FAX-L1000 Plain Paper Laser
Canon FAX L-120 Plain Paper Laser Logo
685 people viewed this question
old marine
old marine
