Question about SmartDisk USB Floppy Drive Titanium Edition (FDUSB-TM2) External Floppy Drive
  • 1,552 Answers
It came with a warranty? Correct ???
Exchange it for a non-defective unit.
Posted on Jan 04, 2015
  • 135 Answers
SOURCE: Floppy
I'm assuming this is on a PC. If so, inserting a floppy will not cause the PC to do anything. (The reasons for this are historical and not important to solving your problem.) You need to open "My Computer", then browse to your A: drive to see the files on the floppy. A handy shortcut to My Computer is to press Windows+E. (Like Ctrl+E, but using the key with the Windows logo on it instead of the Ctrl key.)
Posted on Feb 16, 2007
  • 44 Answers
SOURCE: configuraton of my computer for aSmartdisk Fdusb-tm2
You need to find and download drivers for the drive, this usually isn't the case though if you are using an up to date opertaing system.. serach online for "Smartdisk FBUSB- TM2 Drivers" and this should sort out the problem after you install them and re-start the laptop..
Posted on Dec 16, 2007
  • 326 Answers
SOURCE: how do I read my floppy disk
after you place your floppy disk in the drive go to ''my computer'' which you should find on your desktop and double click on the removable drive(thats if its usb), If not it will be your ''A'' drive (if youve connected it by ide cable).
Posted on Feb 03, 2009
SOURCE: my computer does not reconise my device. ive lost
chack you Usb Cable is't working if it's working then chack you USB prot
Posted on May 02, 2010
  • 145 Answers
SOURCE: the computer this worked with
you have a compatability issue. I've run into that type of floppy before. time to convert to flash drive.
Posted on Nov 27, 2010
How to get sony 2x fdd external mpf88e/ua/181 to work on windows 8?
Try to use the windows 8 generic floppy drive driver. Legacy hardware is difficult to make work. You might want to see if you can download and install multiple drivers for similar floppy drives and see if one of them works.
Jun 18, 2014 | Sony 2X Floppy Disk Dives External...
I need a usb external floppy drive for windows 8 64 bit computer
Amazon com Sabrent External USB 1 44 MB 2x Floppy Disk Drive FL UDRV...
The above link has info on the drive. If you do a search " external floppy drive windows 8" you'll get several sites listed.
May 07, 2014 | IBM USB Portable Diskette Drive (05K9276)...
My laptop says no bootable device insert disk what is wrong?
NO BOOTABLE DEVICE When the PC cannot see a boot file/disk on either the hard disk or floppy drive it gives an error message "No bootable device. Insert boot disk and press any key" First thing, check to see if the is a floppy disk in the floppy drive, if so removes this disk. If there was no disk in the floppy drive then it may be a hard disk problem.
Check the BIOS to see if the hard disk is detected, if not open the case and re-seat the data cable on the hard drive and also where it connects to the motherboard disk controller.
If it still gives this error message and the BIOS does not detect this hard drive, then the hard drive is probably faulty.
A further check on the hard drive, remove the hard drive and connect it to an USB hard drive adapter and connect it to a working computer's USB port, if this computer does not detect it as an external storage device then the hard drive is faulty.
To get the computer operating again, install a new hard drive in your computer and then install Windows on this hard drive plus the computer's device drivers and your programs.
Oct 30, 2012 | Toshiba Computers & Internet
Is there a Windows Vista download to be able to use SmartDisk High-speed 2x Floppy Drive?
Windows has its own support for floppy drives and it should see it.
Is this an external drive that is plugged in USB, if it is it should still work.
If this has an ide connector, then it is attached to the motherboard, that is how a computer comes with a floppy drive, it uses a port on the motherboard.
All windows version have floppy support.
Feb 11, 2010 | Computers & Internet
I have a Toshiba Tecra S3 laptop with a standard Toshiba SATA hard drive (MK6032GSX rv. AS311G). It was a corporate hand me down. It is in dire need of a re-format due to age and virus but when I try it...
Windows XP does not have the SATA driver on the install CD.
You need to download the SATA driver for your model laptop from the Toshiba WEB support/download page.
If the laptop has floppy drive, then copy the SATA driver to the floppy and when you boot up with the Windows XP install CD and then press F6 to install the SATA drivers which is on the floppy as instructed..
Oct 30, 2009 | Computers & Internet
Need to install sata driver on hp dc7100 windows xp sp3
Drive a:\ refers to a floppy drive, if you have not got a floppy drive in the laptop then i suggest that you borrow or purchase a USB one, they are not expensive !!!
When you have got a USB floppy drive all you have to do is format a floppy disk in the FAT file system and copy the drivers to the floppy disk.
Plug the floppy disk in the machine that you want to install XP on, start the install as you normally would and look at the bottom of the screen for where it says "press F6 to install third party drivers" and hit F6 as soon as you see that prompt, let it get to the stage where it displays your drive and it should pick up the SATA drive you have in the machine and install windows.
Post back if you need any more help or advice.
Good luck.
Jul 27, 2009 | Toshiba Laptop Keyboard for Satellite L10,...
Reinstalling windows 98 o toshiba 420cdt laptop
You have two choices:
  • Convert your windows 98 cd into many boot floppies. Then install from floppy. There is a utility on the CD (although I can't remember its name. I think it's something like makedisk.exe) that when ran will prompt you for many floppies.
  • You can remove the hard drive drive from the laptop, and insert it into another desktop computer. You'll need a small adapter to do this, like the one found here:
  2. Once you have inserted the drive into another machine, you can now copy the files from the windows 98 cd to the hard drive.
  3. Now re-insert the drive back into the laptop, and boot from the floppy again. Once inside DOS, you can change directory to your windows98 cd files on the hard drive, and simply run setup.exe.
The second method takes a little longer, but will give you many other benefits, including never having to insert the cd to install a windows component again. Let me know how it goes.
Sep 17, 2008 | Computers & Internet
How to install XP in toshiba Satellite L45-S7423 laptop
I found it!!!>>>
Just go to Toshiba support web site Download the Storage Manager Driver for XP 32 then have an External floppy drive with formatted Disk ,install the drivers Files in the floppy connect the floppy drive put the XP sys CD Boot from the CD as in Solution #1 or by press on F12 tell choices boot screen popup select the CD then after that when the third party appear press F6 to chose the Driver for HDD to get recognized by the system. J
Mar 27, 2008 | Computers & Internet
Can not get new plug and play usb floppy drive to recognize floppy disks.
Did it work before?
If yes, then it died.
If no, then replace it.
Mar 16, 2008 | Computers & Internet
3.5 Floppy drive
Hi, i have installed thousands of Internal Floppy drives and there aint no conflicts between win/95/98/me and xp. all discs should be compatible, unless you took it from a apple machine for example. did it work when you put in a new floppy drive? all the best John
Feb 21, 2007 | Teac Floppy Drive 235HF Internal Floppy...
SmartDisk USB Floppy Drive Titanium Edition (FDUSB-TM2) External Floppy Drive Logo
Top SmartDisk Computers & Internet Experts
Sunday Ojelabi
Sunday Ojelabi
 Ian Kayhan
Ian Kayhan
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
