Question about Bosch 24 in. SHU43 Built-in Dishwasher
Panel light flashes and ticks but will not run cycle
I have tried regular wash and quick wash with the same resulting problem. I start the wash and it acts normally for about 1 minute preparing the wash cycle the countdown light is normal - I can hear the water start to fill then it stops. Then - the light on the wash button starts flashing and I hear a ticking sound - At this time the countdown light is off - there is also a sound lower near the bottom of the washer. I can push all three buttons to empty the tank - the countdown light goes to zero and the ticking stops. The tank empties.
Seems your flow switch is faulty
Posted on Jun 09, 2008
How do I reset the washing program ? I tried to change the washing cycle and it would not run. Now I cannot return to the original washing cycle.
Unplug the power then plug it in again. Now select the program you wish to run and start it. Make sure the door is well shut.
Dec 03, 2014 | Washing Machines
Why are some of the lights and some of the buttons on my Kenmore Dishwasher Model 66513743K601 not working?
Why would you not try removing it and cleaning the contacts?
Yes; the pannel will need to be replaced if that does not work.
Sep 07, 2014 | Dishwashers
Kenmore elite dishwasher model 630 Smart Wash light is flashing
You may want to try:
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel.
Check to make sure that there's no standing water in the bottom of your dishwasher. Standing water in your dishwasher may indicate that your dishwasher has stopped mid-cycle. You will need to press the "Cancel/Drain" button before you can reset your dishwasher control panel.
Dec 18, 2013 | Dishwashers
How to run self test on bosche dishwasher
Here is an excerpt from "Bosch Dishwasher Troublesoooting".
Running a Test Cycle
Bosch dishwashers have a test cycle which can be run as a troubleshooting measure. The method to run this test cycle is similar across the Bosch dishwasher range so if your dishwasher features seems different from those described below then try experimenting, as the process is fairly straight forward and will be very similar. Bosch dishwasher model numbers are usually found around the top or lip of the door. One of the most common differences between dishwasher models is simply the names of the buttons. For example in the first example below, POWER SCRUB PLUS and REGULAR WASH may be called WASH and ECO depending on your dishwasher model and the country you are in. The other key difference is whether your dishwasher has a display panel (which can display error codes) or not (in which case a program light will illuminate to tell you the fault.
To run the test cycle hold down the POWER SCRUB PLUS and REGULAR WASH buttons. Whilst held down press the ON/OFF button. The lights above them should flash. Now you can check the status of each dishwasher program by pressing its button. Now you can run the full test cycle = Press the POWER SCRUB PLUS and REGULAR WASH buttons again. The dishwasher will start up and when the cycle has ended one, if you have no display panel on your dishwasher model the indicator lights will illuminate if a malfunction was detected as follows -
CLEAN - A temperature sensor fault. If this is the case then the test cycle will be very short as the dishwasher will terminate the test once it's been detected.
RINSE/DRY - A water sensor/filling fault. If this is the problem then the test cycle will not complete as the dishwasher cannot detect the right level of water, the dishwasher will just keep filling and draining again.
WASH - A heating fault. Check your heating element.
If you do have a display panel on your Bosch dishwasher then after the cycle is complete an error code will be shown if a fault has been detected. The error codes are as follows -
0 - No errors have been detected.
1 - A water sensor/filling fault.
2 - A heating fault.
4 - A water filling fault. This can also appear as F on the display during a normal cycle.
8 - A temperature sensor fault.
When troubleshooting your Bosch dishwasher, running the above test cycle is a good start in diagnosing the problem and should give you an idea of where the problem lies with your Bosch dishwasher and what fixes and repair are in order. Our general troubleshooting page will give you some ideas on other things to check on your dishwasher. Good luck!
Mar 29, 2013 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Lock light turns on then blinks and wont start
Possible that the lock switch contact has some issues, try a cleaning spray on the switch and open and close the door several times with the spray. This might clear the switch contacts.
Also make sure that the contacts to the connectors from the control panel are in order, remove and tighten or repeat few times.
Otherwise the control panel can be a suspect.
Jul 03, 2012 | Maytag Bravos MTW6600T Top Load Washer
Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
Mdb6650aww code flash: Rinse Cycle & Wash Button.unit inoperative
You might try running the diagnostic mode which can be model dependent. To find your particular method to do this .... unscrew and remove the lower kick plate under the door. The service technician paperwork is usually taped to the kick panel or the tub or side wall. Within that paperwork should be the work process to run through the diagnostic mode. The work process is one of pushing various control buttons in a sequence within a quick time frame and repeating 2-3 times.
If that fails ... other potential reasons run the gambit of a bad control panel (or loose wire connection to the panel), bad heating element, etc
Good luck on your troubleshooting!
Jan 20, 2018 | Dishwashers
Washing machine begins the wash cycle going immediately to the agitate cycle, without filling up with water first.
water will not stop running into drum unless shut off at faucet does not happen all the time and wife can't find her rubber boots
Apr 26, 2009 | Washing Machines
Bosch 24 in. SHU43 Built-in Dishwasher Logo
784 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
