Question about Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine
Foam insulation What Type of adhesive can i use to glue the insul ating foam in the underside area of the ice holding compartment
  • 770 Answers
Pure silicone
Posted on May 19, 2008
What makes it sweat on the sides of the freezer
The insulation inside the walls is deteriorating, or you have a very high moisture atmosphere in the room where it is.
If the freezer is in a garage or not in a setting where looks is important, you can glue polystyrene insulation on the side of it. If it is in view, you need a new one.
Oct 06, 2016 | Danby Freezers
Hello my freezer is not cooling properly and the defrost timer is . making a loud buzzing noise. Please help
Your freezer compartment will freeze up and not cool properly if the defrost timer does not allow the unit to go into its self defrosting mode to get rid of the ice that serves as an insulator.
Replace the timer.
Jan 19, 2015 | True T-23F 23 Cu. Ft. 1 Door Freezer
Freezer insulation
Could you fit a trace heater inside the drain tube to keep the ice from forming? Or extend the dripdown time after defrost cycle so the water doesn't accumulate? If the tech thinks the insulation has blown, it may be time to bite the bullet and replace the fridge.
Apr 18, 2014 | Freezers
Hi we have recently moved to a house an we have inherited a fairly new whirlpool chest freezer which works very well but there is a lot of condensation on the outside which results in small pools of water...
The insulation between the inside and the outside of the freezer haas become water logged, This can be twmporarilly remedied by switching off the freezer and letting the insulation dry out for a few weeks, less in hot dry climates, but the solution is temporary and the problem will reoccur. To have the foam replaced means a complete strip down of the freezer and is seldom worth the cost. I am sorry, but you will probably have to get used to living with the problem. Incidently, it does make inroads into your electricity bills.
Jan 16, 2011 | Whirlpool 21.6 cu. ft. / 612 liter Chest...
Why condensation on out side of my freezer
This condition is telling your that your freezer insulation is deteriorated or even leaks causing outside air contact to your freezer. By visual check the leaks, if you found, laminated it by using HVAC insulation like duct tape, PU foam etc. For best is to replace all insulation of your freezer.
Regards
Jan 15, 2011 | Whirlpool 21.6 cu. ft. / 612 liter Chest...
Suction line on walkin freezer is sweating from condensor to evaporator above ceiling
The insulation wrap around it needs to be replaced. Thats the black foam stuff around the pipe.
When it gets old it loses its insulation quality and the the humidity condenses on the pipe.
Wrap it well in new insulation ensuring that all seams and openings are taped, and every square inch of pipe is wraped, but not to tightly. (Compressed insulation lowers efficiency)
Aug 26, 2009 | Freezers
Water lines to ice maker are clear and pressure is good but the ice maker recieves no water to make ice
Take a 6 inch piece of 14 gauge insulated wire and strip one inch of insulation off both ends of the wire. Bend the wire into a U shape. Remove the plastic cover from the front of the ice maker.Locate the holes marked L and V. Insert the 2 stripped ends of wire into the L and V slots. If you get water,the ice maker is bad. If you do not get water,the water valve is bad.
Aug 18, 2009 | Kenmore Freezers
Ice build up
Sounds like moisture built up in insulation and may be defrost problem. If you can check inside coil to see if it is clear then moisture is in wall and carrying cold to out side or area is not well insulated. Again hard to tell with out getting into it .
Jun 28, 2009 | Arctic Air 22 cu. ft. Commercial Freezer...
Sub Zero insulation freezing
These units are pretty much manufactured, then the insulation is inserted as a liquid that forms into a solid insulation. Consider the age of the unit for a replacement IMHO.
Mar 11, 2008 | Freezers
Door liner on chest freezer broke due to ice build-up
if you can't find a replacement, use a piece of flat vinyl siding that goes on houses. You can heat it and bend it as needed, or cut it and screw the pieces to a balsa wood frame for lightweight support. Glue or epoxy probably won't work as the cold temps make them brittle but external caulking may be ok to hold the pieces together. Be sure to sand all edges and corners as the cut plastic can be sharp. If you can disassemble the unit and place the door face down, you can fill the cavity with insulating foam to help stabilize it.
Nov 27, 2007 | GE 25.1 cu. ft. / 711 liter Chest Freezer...
Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine Logo
105 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
