Cooling problem interior fan shoots air;exterior fan does not work.air is not cool
  • 145 Answers
The condenser is dirty. The coils on the back need cleaned. Do not take it to a car wash. You need to go to a HVAC supply dealer and buy some coil cleaner and follow the directions on the bottle.
Posted on May 19, 2008
CHH012CD-13B
This type of unit does not drain into the outside unit. It drains into a nearby interior drain, or just to the outside near Inside unit. If the unit is cooling properly, you're ok.
Jul 01, 2014 | ComfortStar CHH012CD-13B Wall Mounted Mini...
Exterior fan motor replacement
i would replace its run capacitor first.
Jul 04, 2013 | Ruud UAMB Air Conditioner
Fan will not turn off
which fan? Interior fan, or radiator cooling fan? Is it the radiator cooling fan, or the fan controlled by the air-conditioning?
Run the vehicle, turn on and off the air-conditioning to identify which of the fans in the engine bay is the one triggered by the air-con and which is the primary cooling fan.
If the primary cooling fan is permanently engaged, then first try replacing it's relay as it may have fused closed.
Oct 29, 2012 | 2005 Cadillac Escalade
I have a trane XB1000 unit (DOB around 2000). Was cooling fine, but noted a whining noise at the outside unit. Loudest near the base below compressor tank. Interior filter clean, a-coil fairly clean,...
If the sound is coming from the outdoor unit, check fan blade if unbalance and if the compressor is making the noise, an internal mounting spring must be broken, be ready to replace the compressor when the internal pipe got broken.
Sep 03, 2011 | Heating & Cooling
I cannot get our house cooled down. We have a RTH230B Honeywell thermostat. The central air has been running for 24 hours. I set it to 72F and our house is still 82 degreesF
Did you go outside and check the exterior housing? Look for oil on the pad; accumulation of leaves, etc that restrikes air flow; and is the exterior fan running? I doubt if it is your thermostat!
On the interior, you should see some water coming from the condenser exhaust hose also.
Jun 04, 2011 | Honeywell Heating & Cooling
WHY DOES MY RADIATOR FAN COMES ON ONLY WHEN MY AC IS ON ON MY 88 TOYOTA COROLLA
it is generally because the air con heat exchanger has to be cooled in order for your air con to work correctly and cool the interior of your car.
The air conditioning utilises a gas by the name of freon. This gas is pumped around the air con system by a compressor. The gas, going through the aircon cooler or heat exchanger, starts to cool down. Depending on the system layout, the gas is forced through a very small aperture situated after the cooler. It reverts to a liquid, passes through the matrix in the car, a fan blows the interior air of the car through the matrix. The fluid picks up the heat, and cooler air exits the matrix and, (hopefully) cools the interior of the car. This endless cycle is repeated as long as the air con is powered on.
Hope this brief description will suffice.
Jan 25, 2011 | 1988 Toyota Corolla 4 Door
Wine cooler not cooling below 65 lights works but not fan any ideas
Brand and model number will help someone answer your question easier. But to guess the problem I would think the fan is the answer. Both interior and exterior fans must run while any cooler or refrigerator or it will cause the compressor to over heat and stop cooling. Running with a bad fan can also damage the compressor internal overload. f you unplug the fan wires and test for voltage you should get your local voltage unless the fans are DC. Thanks, Lit me know the model and make and I will help you further, Sea Breeze
Feb 11, 2010 | Refrigerators
Motor and fan on exterior unit work once then do
im not qiute sure about this but it sounds to me like you are getting a hard lockout from high or low pressuers on the out side unit
Aug 27, 2009 | Heating & Cooling
Heating & Cooling Logo
87 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
