Question about Linkskey Computers & Internet
Wireless Connection I have a comcast cable modem connected to a Linksey wireless router, when I turn my laptop on at home it continues to tell me I have a invalid IP address. I can use my wireless laptop at work, hotels anywhere but home, where I continue to pay comcast to provide me no service??
  • 2 more comments
  • cgarza May 20, 2008
    Here is the info. that I have:
    Model #WRT54G
    Serial #CDFF1G3R1389
    Operating System is Microsoft XP
    How would I know if the network is not connecting, it connects
    but says that I have limited access to the internet and will not open any web pages.
    Thanks.
    When I view wireless connections it shows my connection even shows that it is to connect automaticly, it is not secured I have not been able to connect a connection to go through the process of making it a secured network.
    When I view the wireless networks it shows the connection with a yellow caution sign showing limited connection.
    Thanks,
    I have done all of the above?
    Have you tried accessing the router setup page and check the wireless settings just to make sure you are really connected to your own network?
    Now this I am not sure how to do?
  • 298 Answers
It's possible that you are not yet connected to the wireless network that you have at home.
May I know the model no. of your wireless router from Linksys?
What is the operating system of your laptop?
You might also want to check if your computer is picking up the signal braodcasted by the linksys router.
Posted on May 20, 2008
  • 4 more comments
  • Jeffrey Pedimonte
    Jeffrey Pedimonte May 20, 2008
    It is possible that you are not connected proprerly to the network. if you network is secured you need to make sure that you have typed the network key.
    Try this to check if your network is available.
    On your wireles computer go to control panle>Network Connections>Then right click your Wireless network connections>Select View Available wireless network. A new window will pop up and it will show you the available networks around you. Check if you will see the name of your network on list and if it will say secure or unsecured. And from there you can reconnect to the wireless network. You can reply to this post in case you still have a problem.
  • Jeffrey Pedimonte
    Okay, did you try to disconnect and reconnect just to refreshe the connection? If it will not work. You try this, unplug the power for the router leave it off for a minute and plug it back again. See if you will have a connection.
  • Jeffrey Pedimonte
    Because if you are sure that you have the right settings. then it's possible that it could be a faulty with the router's f/w.
    BTW, have you tried to disable the firewalls on your computer?
  • Jeffrey Pedimonte
    If you want you can contact this support that I found, its supportrix their no. is 1 877 787 8749 you can use promo code "support call" so you can get a free support from them. that is if you want give it a try, i think they can assist you with your concern.
  • Jeffrey Pedimonte
    Have you tried the no. that I gave you?
  • Jeffrey Pedimonte
    You can also check this link on how the check the wireless settings and security on your linskys router.
I just recently bought a used d-link wireless router, and i am currently on comcast demand, and i have an acer laptop windows 7. how do i connect the router to my modem which will enable me to connect to...
To set up the router you need in the first place to connect to the router with a wired connection.
Once you have configured your wireless connections then you can continue wirelessly.
Sep 01, 2010 | Computers & Internet
I have comcast cable net and D-link WBR 1310
Hi, forget about the USB connection since you wanted to use a router for your wireless connection. Contact Comcast asnd make sure they assist you in making your computer connect to the Internet using the ethernet connection because you are going to use the ethernet connection for the modem-router connection. Once your computer is online with the ethernet connection, you can connect your Dlink router to the modem and configure it for Internet connection. There will be more steps before you can use the wireless connection. Just make sure you can get online with ethernet connection first.
Jul 23, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Connect Laptop to PC desktop which has cable connection.
YOU WILL NEED TO GET A WIRELESS ROUTER TO BE ABLE TO USE THE LAPTOP WIRELESS, iT IS A VERY EASY SET UP AND CONNECT THE DESKTOP WIRED AND THE LAPTOP WIRELESS TO A WIRELESS ROUTER.
May 06, 2009 | Arris SURFboard SB5120 Modem
True Mobil 2300 can't find IP address
OK...
since you have a comcast modem the router should automatically pick up connection,since you have already reset the modem,what you need to do is to check whether you are going online suing the modem,once you can go online using the modem,reset the rotuer as well,connect all the devices properly(the cables should be in the appropriate ports)turn off all the devices for 60 sec and then turn the modem,wait for the light to be steday,turn on the router and then the computer and check if you are being able to go online i am sure you will be,incase you are stuck let me know ffurther...
vedhick
Feb 10, 2009 | Dell TrueMobile 2300 Wireless Router...
Wireless router stops internet connection to modem during install
are you sure your hooking the comcast modem in the right place?
Feb 08, 2009 | Arris SURFboard SB5120 Modem
Connection
Hi Susie
With related to your particular issue it seems like that your broadband modem is not configured for the router. There are basically 2 types of connection. DSL and Cable modem. Verizon, ATT are DSL and comcast other providers give you a normal cable broadband connection. If its comcast make sure the cable from the comcast modem is going to the internet port in the linksys router and also make sure that there is a system connection the linksys router and the cable from the system goes to any of LAN 1, 2, 3 and 4 ports. Then reset your cable modem by using a pin and inserting to the reset hole in the modem. You could use the same step to reset your linksys router as well .If its a verizon or dsl connection you need to put normally your username and password in the router page. here is the link to how to configure linksys for your internet modem.
Here is a video as well on it?
http://in.youtube.com/watch?v=vSAXMO7aNzg
http://tinyurl.com/5tqqhl
Also post the linksys router model. your ISP modem model number and also information on how many systems are wired to the router and wireless and let me know if you need more help.
Thank you
Rakesh
Dell Laptop Expert
Jan 09, 2009 | Linksys Wireless-G Broadband Router
Want to hook laptop up to home computer via cable modem
You need a router or a wireless router to do that.
If your cable modem is wireless you can set directly via wireless network a connection with your laptop (the laptop also need a wireless card (if dont have any built in))
The connection must be done in this way
ISP ----->> Cable Modem ---->> Wireless Router o Router ----->> Computer ( 1, 2, or more)
Nov 19, 2008 | Computers & Internet
Wireless router needing ethernet connection?
Hi ABVT66 - Didn't your router come with two short cables? It should have. One is the cable that hooks up the modem to your router and the other is the cat5 (ethernet) cable that connects your router to your pc. Let me know if you have these cables. Also, if you check your device manager on your pc, click on the + next to network adapters and it will tell you your network adapter. DON'T RATE THIS 'TIL WE'RE DONE. Thanks.
Jeff
May 22, 2008 | Computers & Internet
2wire Wireless router not working w/Comcast cable modem
Its almost impossible to connect a 2wire DSL router with a Cable modem. They dont go hand in hand.
Although you can connect the outgoing ethernet wire from the modem in the last ethernet plug on the back of the router and then have the ethernet connections coming from the router. But not wireless. and if you find a way, contact me at jneal2k9@hotmail.com
Feb 03, 2008 | 2wire (1000-400108-001) Router
Computers & Internet Logo
99 people viewed this question
Top Linkskey Computers & Internet Experts
David Payne
David Payne
Are you a Linkskey Computer and Internet Expert? Answer questions, earn points and help others
