Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Flyback Transformer How hard is it to change out the transformer??? are there any online resources that will provide instructions?
  • RCA Master
  • 8,617 Answers
Yes you can get the replacement flyback which is flyback 259296 at the following link and they provide free tech support to do the repair . Its a very easy repair takes about 20 minutes and requires the very basic soldering skills. heres the link.
http://servicemanuals.vstore.ca/
Posted on May 19, 2008
Spraying sound and tv shuts off
the flyback transformer or the Box cap CL031 is arching and will need replacement the flyback is most likley of the two. You can get flyback transformer with instructions from www.tvrepairworld.com
Jan 18, 2012 | RCA HD52W59 HDTV Projection Television
I need a transformer
Hello
It is not clear from your post, that which transformer part number you wants to know. Anyway I'm hereby send you the part numbers of it two main transformers.
[1] Horizontal Ouput Transformer, or Line Output Transformer or Flyback transformer [HOT or LOT or FBT]; Part number is (257807)
[2] Switeched Mode Power Supply transofrmer [ SMPS transformer]: Part number is (257807)
OK.
Dec 16, 2010 | RCA F36650 36" TV
Is it hard to change the flyback transformer RCA D52W19BYX1
no you can easially do it yourself. You can get the 259296 flyback kit from www.tvrepairworld.com which also has the step by step instructions on CD
May 09, 2010 | RCA D52W19 52" Rear Projection Television
Flyback transformer
A flyback transformer is one of the more expensive components in a projection TV. If there is no clear reason, such as a known power surge, you could well replace the flyback transformer again soon because the root problem was elsewhere.
An OEM transformer is not necessary but you might have trouble convincing an authorized factory service technician to use anything but the original manufacturer's parts.
As with many of today's electronic devices, if it is more than a year or two old, you will find the new products cheaper and with more features. The next generation of projection TVs will use lasers and scanning will be done with optically controlled micro-mirrors - no flyback transformer required.
Oct 07, 2009 | Toshiba Televison & Video
Flyback transformer and horizontal output transistor change out
There is a little loose sleeve at the transformer. It can be pulled out, but it is best to squeeze the sides through hole on each side of the terminal to remove the sleeve. The wire just comes out with a small pull afetr the sleeve is removed. Good luck.
Dec 20, 2008 | RCA Televison & Video
I am replacing the flyback transformer
You should post here pictures of old transformer and point out what wire you want to remove, then I can give you an idea what to do as flyback transformer is not in front of me.
Oct 27, 2008 | RCA HD52W59 HDTV Projection Television
36" RCA- loud whine/squeal when it is plugged in, otherwise no power.
The HOT Hortz output transistor has gone home, 99% of the time from a faulty IVHT (Flyback Transformer), very common on the ctc187cl* chassis. The factory Flyback is no longer available, I have had problems finding an aftermarket one to replace it with.
The HOT is a BUH517, but you can also use a 2SD5129. It is the transistor mounted on the siler heat sink with a metal clip rather than a screw, just in front of the flyback.....
If you replace just the HOT, most of the time you will get a rapid arc (27,000volts - BE CAREFUL!!!) from the lower (yoke) post on the flyback. If the flyback is shorted, It may also just burn out the HOT and go right back to "squealing"....
Good luck finding the flyback!!!
Oct 06, 2008 | RCA F32450 32" TV
Phillips 60pp9202 high voltage transformer
You can get the HV Transformer at the following link for 132.00 which includes free shipping and free step by step instructions by online instant messaging so you can easily replace the part yourself. Very easy repair. The HV generator is listed under the flyback section yours is Phillips 32942 Flyback ( HV Transformer)
Heres the link.
Aug 01, 2008 | Philips 60PP9202 60" Rear Projection...
Flyback Transformer replacement instructions?
remove solder from all pins and squeeze clips to remove...
Oct 12, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
No power
Check the FBT and the Horizontal Output Transistor also.
Sep 18, 2006 | Panasonic TX-15AT1 15" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
153 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
