Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Flyback Transformer How hard are these to replace?
    Genius:
  • 1,030 Answers
Flyback transformers rank about a 5 or 6 on dificult to repace.. depending on the model of tv that you are working with.. the rca itc222 can be difficult.. dependend on your soldering experences. To replace this one you have to pull the chassis tray up and out to get to the bottom... unsolder the pins ussally a vacum desoldering tool is required because it is important to remove all solder from the pins..then gently pry the clips that hold it on the board... this is where you can mess up unless the pins have be completly solder free you can crack the board... NOW the hard part... removing the wire from the flyback.. if the flyback is the type that the wire comes out. the wires will eather have a clip around the large wire or you will have to go to the other end of wire and pull it out from the splitter. eather way this wire is firmly in an will require gently but extremmly firm pulling to get out.
Posted on May 19, 2008
REPLACEMENT FLYBACK TRANSFORMER SONY TRINITRON CRT TV KV-2062E IS REQUIRED
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Jan 02, 2016 | Sony Televison & Video
Picture on Samsung TXL2791F gets smaller after a few minuets
The horizontal output transistor that drives the flyback transformer overheats now. There might be other reasons too for this fault. If the flyback transformer has any internal winding short, this transistor will overheat.
Just replace the horizontal output transistor. Check its heat. If the newly replaced transistor too overheats, replace the flyback transformer.
May 24, 2012 | Samsung TXL2791F 27" TV
TV HARD TO TURN ON POWER KIGHT TURNS ON AND OFF THREE TIMES THEN YOU HAVE TO WAIT THEN PUSH BUTTON AGAIN
Check circuit board with the flyback transformer(the transformer has a thick red wire connected to the top of it)for bulging capacitors. Capacitors are the ones that look like little cans. If you find any then replace them. Also, resolder all the points at the bottom of the flyback transformer. This should fix your problem. If not try using a blow dryer and heat up the back of your t.v. for about 5-10 minutes.
Aug 24, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Flyback transformer
A flyback transformer is one of the more expensive components in a projection TV. If there is no clear reason, such as a known power surge, you could well replace the flyback transformer again soon because the root problem was elsewhere.
An OEM transformer is not necessary but you might have trouble convincing an authorized factory service technician to use anything but the original manufacturer's parts.
As with many of today's electronic devices, if it is more than a year or two old, you will find the new products cheaper and with more features. The next generation of projection TVs will use lasers and scanning will be done with optically controlled micro-mirrors - no flyback transformer required.
Oct 07, 2009 | Toshiba Televison & Video
I am replacing the flyback transformer
You should post here pictures of old transformer and point out what wire you want to remove, then I can give you an idea what to do as flyback transformer is not in front of me.
Oct 27, 2008 | RCA HD52W59 HDTV Projection Television
36" RCA- loud whine/squeal when it is plugged in, otherwise no power.
The HOT Hortz output transistor has gone home, 99% of the time from a faulty IVHT (Flyback Transformer), very common on the ctc187cl* chassis. The factory Flyback is no longer available, I have had problems finding an aftermarket one to replace it with.
The HOT is a BUH517, but you can also use a 2SD5129. It is the transistor mounted on the siler heat sink with a metal clip rather than a screw, just in front of the flyback.....
If you replace just the HOT, most of the time you will get a rapid arc (27,000volts - BE CAREFUL!!!) from the lower (yoke) post on the flyback. If the flyback is shorted, It may also just burn out the HOT and go right back to "squealing"....
Good luck finding the flyback!!!
Oct 06, 2008 | RCA F32450 32" TV
Flyback Transformer
Yes you can get the replacement flyback which is flyback 259296 at the following link and they provide free tech support to do the repair . Its a very easy repair takes about 20 minutes and requires the very basic soldering skills. heres the link.
http://servicemanuals.vstore.ca/
May 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Computer monitor
disconnect the flyback transformer B+ POINT. if the tick sound goes the problem may be in the flyback transformer. replace the transformer.
Apr 07, 2008 | SAMTRON 55V 15" CRT Monitor
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
189 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
