Question about Motorola Mobility RAZR V3m Cellular Phone
Backlight on external screen
The backlight on the external screen goes out if you leave it alone and I want it to stay lit enough to see the time so I know it is working; my older RAZR would do so but this won't. I have seen stuff on the internet about doing a SEEM edit to correct this but am scared to do so. Is there ANY other way; or somewhere I could take it to get it done? The guy at Alltel where I am didn't have a clue.  Thanks
    Brigadier General:
  • 7,752 Answers
Take it to a mobile tech n have them fix it for you or you can just extend the personalise settings
Posted on May 29, 2008
Vizio Model SV320SVT powers on, after Vizio splash screen it goes blank. Power stays on, but no backlight on screen.
Yes its very repairable as long as the logo stays white you can assume the main boards good. I would recomend contacting the people at www.tvrepairworld.com by hitting the contact us button from their website. They will be able to assist you in finding out whats happening with the set for free. They have most parts available as well.
Aug 07, 2012 | Vizio SV320XVT 32 in. TV
I have a samsung syncmaster 943NW which goes on for about 5 seconds and then just goes black. When restarting the screen it does the same again, goes on for about 5 seconds and then black. Is there...
I had the same problem with this monitor (Samsung 943nw)
When turned on it would only stay on for less then a full second.
When shining a light on the screen I could see what was on it, so it was just the backlight that was shutting down.
After I turned down the brightness of the monitor, the next time I powered on the screen the backlight stayed lit and it was back to normal.
Dec 11, 2010 | Samsung 943NW Monitor
Screen goes black
I think your battery might not be shorting out the lcd.
Leave the battery out and see if the lcd stays lit without going black, if it does it probably is the battery thats bad.
Try a known good working battery and see if the lcd stays lit. If the lcd stays lit then you know the battery was bad. if you get the same symptoms from another battery then you know its something with the motherboard at that point.
Jun 20, 2009 | Toshiba Satellite A45-S151 Notebook
I was chaging setting and I turned of backlight
If its just the backlight then you can stay in a well lit area and look at the screen that way to change the setting, also you could try plugging it in to keep the backlight on.
May 19, 2009 | Nokia 1600 Cellular Phone
Toshiba Sate. M35X-S19 - Blank Display
It is more than likely that it is the display that is the problem.
And your original problem may have been the display and not the motherboard.
Please rate this if you find it helpful.
Thanks
May 05, 2009 | Toshiba Satellite M35X-S149 PC Notebook
The picture is intermittent, stays for a long time,
is the backlight staying lit even with the picture out? I had the same problem with my Aquos LC32DA5U my backlight was always on but no picture at all, just a lit up black screen, the problem is the LCD controller, I replaced that and it's perfect now.
Jan 09, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Backlight behind numbers
in the case of your phone, you have to replace the keypad membrane of your phone, if you cant find a spare keypad membrane, you have to replace the whole flex. you can buy a flex in motorolla service centers near your place.
Jun 12, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Monitor Went "BLIND"!
Actually, there's 3 major manufacturers of laptops and parts.
Can you connect to an external monitor and boot the unit up. You may have to toggle (F3 or F5 i think) between on board and external a few times. If you get an image on the external, it's probly the lcd inverter (#1), or the backlight (#2), or the cable is not completely connected to the lcd (#3)
Let me know how the external monitor test works and we'll narrow it down from there.
Good luck
Nov 27, 2007 | Toshiba Satellite A45-S150 Notebook
Motorola Mobility RAZR V3m Cellular Phone Logo
44 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
