Question about Mitsubishi VS-45607 45" Rear Projection Television
Mitsubishi model # VS-4007R will not turn on. Just clicks
  • rdgordon Jun 19, 2008
    Same problem, just clicks and will not power up. No green power light and black screen.
  • darmian Jul 19, 2008
    I have aMitsubishi VS -45607,when i try to turn it on,the green light blinks and then shots off.moe
  • 927 Answers
Good Day, ya'll;
TRY THIS:
1. SHUTDOWN CAN BE CAUSED BY NO VERTICAL DEFLECTION. SINCE THE VERTICAL CIRCUIT IS POWERED BY THE SWITCHED POWER SUPPLY THE UNIT MUST BE TURNED ON TO TROUBLESHOOT THE CIRCUIT. THIS CAN BE ACCOMPLISHED BY TEMPORARILY DISCONNECTING THE VERTICAL INPUT TO THE X-PROTECT CIRCUIT. ** TO PREVENT DAMAGE TO THE CRT'S YOU MUST UNPLUG THE CRT PCB'S. ** TO DEFEAT THE X-PROTECT CIRCUIT, UNSOLDER D4A1 LOCATED OFF THE COLLECTOR OF Q4A1. IF THE UNIT POWERS ON AT THIS POINT, YOU HAVE CONFIRMED A VERTICAL FAILURE AS THE CAUSE FOR SHUTDOWN. ** D4A1 MUST BE REINSTALLED IN CIRCUIT TO PREVENT CRT DAMAGE. ** 2. WITH VERTICAL PROTECTION DEFEATED (D4A1 OUT OF CIRCUIT) WHEN THE UNIT POWERS R514 (PIN 11 OF THE FLYBACK) OPENS. CHECK PARALLEL CAP. C512 .33 UFD 400 V IF C512 IS GOOD REPLACE THE FLYBACK PART # 334P191020 ON THE MAIN PCB. 3. CHECK PIN 1 OF IC401 FOR 10.7VDC. IF LOW OR MISSING CHECK FOR SHORTED D4000 (PART #264P487030) LOCATED OFF PIN 1. (PCB-MAIN) 4. CHECK PIN 8 OF IC401 FOR 28.4VDC. IF MISSING CHECK FOR OPEN D520 AND R540 AT PIN 5 OF FLYBACK TRANSFORMER T503. (PCB-MAIN) D520 PART #264P102020 R540 (1.2 OHM 1/4 W) PART #103P398010 5. CHECK FOR DEFECTIVE IC401, PART #272P239040 ( PCB-MAIN) 6. CHECK R540 1.2 OHM 1/4 W OFF PIN 5 OF FLYBACK (PCB MAIN). 7. EXCESSIVE 130V SUPPLY. CHECK C911 47 UFD 100 V AND C914 47 UFD 50 V, IN THE IC900 CIRCUIT.
If you are not technical then you should call a factory authorized service dealer and an estimate, as you can see this can get complex.
Good Luck, big IRISH.
Posted on Jul 31, 2008
I have a Mitsubishi 50" Big Screen Model VS-50707. When trying to turn it on, it blinks once and clicks, then doesn't turn on. It has been doing this for a while, but eventually would come on and need some...
The picture tubes are warn out or the deflection circuit is failing. The power supply is struggling to fire them up. Takes a lot of power.
Some TV shops have the know how to replace the tubes. About $1000 parts and labor.
Dec 30, 2009 | Mitsubishi VS-50707 50" Rear Projection...
My vs-6055 you can hear it click but it wont turn on
check q570 if shorted replace it,also regulator ic401 goes bad along with c402 100mf/50volt electrolytic cap
Sep 01, 2009 | Mitsubishi VS-6055 60" Rear Projection...
My mitsubishi VS-4007R wont turn on but i hear a click like its
my tv does not turn on the buttons are locked what can i do
Jun 08, 2009 | Mitsubishi Televison & Video
Vs-4007r
Sorry to say this you need to change circuit board in your tv . High voltage damaged the circuit board . The symptoms indicates like that .
Oct 20, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi VS-50607 has Jitter at top of picture- intermitant
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 10.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs
http://servicemanuals.vstore.ca/
Jan 14, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-60719 60" Turns off
replace the regulator and check for bad connections
Sep 21, 2007 | Mitsubishi VS-60719 60" Rear Projection...
Mitsubishi vs-4507ca
It just click ON and OFF, right? If you hear the hight voltage noise tring start, may be the Tv has bad vartical IC or regulator IC. If you have no experience with electronic you will need a technician to halp you.
Sep 11, 2006 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
89 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
