Question about Mitsubishi VS-45607 45" Rear Projection Television
Mitsubishi VS-407R I have a big screen model # VS-4007R Manufactured in July 1992. When trying to turn on the power it just clicks, but nothing happens. I can not get it to turn on. Please help me.
I have a Mitsubishi 50" Big Screen Model VS-50707. When trying to turn it on, it blinks once and clicks, then doesn't turn on. It has been doing this for a while, but eventually would come on and need some...
The picture tubes are warn out or the deflection circuit is failing. The power supply is struggling to fire them up. Takes a lot of power.
Some TV shops have the know how to replace the tubes. About $1000 parts and labor.
Dec 30, 2009 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi Big Screen TV Model VS-6051 will not turn on. I hear a clicking sound when I unplug it from the wall but it still does not turn on.I have tried using an alternative power source and it still...
hello VS6051 POWER SUPPLY PULSATES ON/OFF IC9A1(267P062010)
VS6051 VZ2 POOR START L9A30(BEAD ON LEG OF R9A21)-R9A22 TO 1.2K, R9A12 TO 15K,C9A15 TO 330UF
VS6051 VZ2 POOR START,ADD 22UF/100V PARALLEL W/C9A17
VS6051 VZ2 WILL NOT POWER ON D9A00(264P102020) IC9A0(267P112050)
Sep 19, 2009 | Mitsubishi VS-60111 60" Rear Projection...
My mitsubishi VS-4007R wont turn on but i hear a click like its
my tv does not turn on the buttons are locked what can i do
Jun 08, 2009 | Mitsubishi Televison & Video
Powers on to blue screen and nothing else
press the input button until it cycles through all of the inputs.
Feb 11, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Have sound but no picture
Sounds like what happened to my hitachi. Power voltage regulator on the main pwr board.
Jan 24, 2009 | Mitsubishi VS-50609 50" Rear Projection...
Vs-4007r
Sorry to say this you need to change circuit board in your tv . High voltage damaged the circuit board . The symptoms indicates like that .
Oct 20, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mits Big Screen TV model #VS-5043
you have to take off the front framework to out the screen back in and it should still work
Aug 25, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi
Good Day, ya'll;
TRY THIS:
1. SHUTDOWN CAN BE CAUSED BY NO VERTICAL DEFLECTION. SINCE THE VERTICAL CIRCUIT IS POWERED BY THE SWITCHED POWER SUPPLY THE UNIT MUST BE TURNED ON TO TROUBLESHOOT THE CIRCUIT. THIS CAN BE ACCOMPLISHED BY TEMPORARILY DISCONNECTING THE VERTICAL INPUT TO THE X-PROTECT CIRCUIT. ** TO PREVENT DAMAGE TO THE CRT'S YOU MUST UNPLUG THE CRT PCB'S. ** TO DEFEAT THE X-PROTECT CIRCUIT, UNSOLDER D4A1 LOCATED OFF THE COLLECTOR OF Q4A1. IF THE UNIT POWERS ON AT THIS POINT, YOU HAVE CONFIRMED A VERTICAL FAILURE AS THE CAUSE FOR SHUTDOWN. ** D4A1 MUST BE REINSTALLED IN CIRCUIT TO PREVENT CRT DAMAGE. ** 2. WITH VERTICAL PROTECTION DEFEATED (D4A1 OUT OF CIRCUIT) WHEN THE UNIT POWERS R514 (PIN 11 OF THE FLYBACK) OPENS. CHECK PARALLEL CAP. C512 .33 UFD 400 V IF C512 IS GOOD REPLACE THE FLYBACK PART # 334P191020 ON THE MAIN PCB. 3. CHECK PIN 1 OF IC401 FOR 10.7VDC. IF LOW OR MISSING CHECK FOR SHORTED D4000 (PART #264P487030) LOCATED OFF PIN 1. (PCB-MAIN) 4. CHECK PIN 8 OF IC401 FOR 28.4VDC. IF MISSING CHECK FOR OPEN D520 AND R540 AT PIN 5 OF FLYBACK TRANSFORMER T503. (PCB-MAIN) D520 PART #264P102020 R540 (1.2 OHM 1/4 W) PART #103P398010 5. CHECK FOR DEFECTIVE IC401, PART #272P239040 ( PCB-MAIN) 6. CHECK R540 1.2 OHM 1/4 W OFF PIN 5 OF FLYBACK (PCB MAIN). 7. EXCESSIVE 130V SUPPLY. CHECK C911 47 UFD 100 V AND C914 47 UFD 50 V, IN THE IC900 CIRCUIT.
If you are not technical then you should call a factory authorized service dealer and an estimate, as you can see this can get complex.
Good Luck, big IRISH.
May 19, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-50VA1
Go to http://www.remotes.com enter in the TV model number, and order it, as there is nothing that can be done in a case like this. You could try to borrow a remote from a local store to switch the set back to the tuner section or borrow an original remote from someone.
Sep 21, 2006 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
131 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
