Question about Philips ProScreen 4750 Impact Multimedia Projector
How do you get the bulb out of the Phillips ProScreen 4750?
There is a door next to the input panel you will see 2 silver screws that you can use a flat head to unscrew once you take those out you will see another 2 screws that you will need to remove as well once that is done there is a flap on the bulb housing with a hinge that you need to pull up then tug on it and it will slide out once you do that you will get the bulb in the housing you will need to take the wires off the bulb one will be a nut the othere will be a torx screw remove those and there will be a metal long piece that is holding the bulb in plaace yppu have to pop that out then the bulb will slide out
Posted on Jan 09, 2009
  • 563 Answers
Hi there
There should be a lamp door at the bottom of the Projector that you have to unscrew before you will be able to take out the lamp.
Posted on May 20, 2008
Convergence phillips proscreen
The adjustment requires disassembling the projector. It's not really something that should be attempted in the field.
Sep 08, 2014 | Philips ProScreen 4750 Impact Multimedia...
No Power lights coming on and not even the fan
You can check inside or at bottom if there is any fuse box because your fuse might have gone..
Oct 23, 2013 | Philips ProScreen 4750 Impact Multimedia...
Phlips proscreen 4750, how do i open up the case to get to the inside/ and how do I adjust the convergence?
There is not a lot you can do with it, even setting up the static convergeance as you require a crosshatch generator, dot generator and specialist tools to adjust the LCD immagers.
It is not practical for the laman to attempt an adjustment of this sort.
Take it to a Philips Specialized Repair Centre.
Jan 03, 2011 | Philips Office Equipment & Supplies
It keeps overheating.
Is the fan set to run continuously? Go to the menu and see if it's set up to run. Also we have this problem with mounted projectors in our classrooms, we have to keep the room cool, and make sure the projector gets circulation of air.
Hope this helps.
Nov 18, 2009 | Philips ProScreen 4750 Impact Multimedia...
The projector does not operate the "lamp" led blinks in green and turn red after one minute. The switch on button does not replied.
either it's overheated or needs a replacement bulb.Do not cover this unit with anything as it will prevent cooling down..
Jul 27, 2009 | Philips ProScreen 4750 Impact Multimedia...
Fan not running
Dear Sir,
I am willing to buy over your Philip4750
pls contact me at the soonest master300p@hotmail.com
regards
Mr Cheong
Aug 18, 2008 | Philips ProScreen 4750 Impact Multimedia...
Dark screen
Dear Bob,
Pls contact me at the soonest , i can solve this and i am willing to buy your unit.
jazz
May 23, 2008 | Philips ProScreen 4750 Impact Multimedia...
Double image or shadow image
We recently had the same problem with our church projector and we too had just changed the lamp. I read somewhere while searching for an answer that if the cable input is loose it will cause double vision of the text. Sure enough, the cable was loose and after tightening the text cleared up immediatly.
Dec 26, 2007 | Philips ProScreen 4750 Impact Multimedia...
Philips ProScreen 4750 Impact Multimedia Projector Logo
176 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
