Question about Samsung Lands Phones
We have OfficeServ 7200 and appear to intermittently lose incoming calls only to find later that incoming caller was still there and can listen in on operator conversations.
  • kh27 May 19, 2008
    This answer is no use. Is this a common problem and how exactly can it be fixed.?
    President:
  • 2,712 Answers
Probably this manual will better assist you:
http://www.samsung.lexcom.ru/docs/manual_17809.pdf
Hope that helps!
Posted on May 19, 2008
Why made phone early now cant just get busy signals?
Sounds like your phone or line is now short circuit and is holding the line so it appears busy to incoming callers. Try disconnecting the pnone and line right up to the incoming point of your house to find the problem.
Jul 30, 2014 | AT&T CRL82312 3 Handset Answering System...
I use polycom Sound Point IP 550 phone. For an incoming or outgoing call after some duration the other end of the caller is not able to listen to me. However I can listen to them, once understanding that...
This sounds like an RTP stream issue. While SIP runs on port 5060 by default, the actual audio is run on much higher ports, 10000 and up. If your pbx system is not on a public address and you are forwarding traffic to your pbx via a router, check the RTP port range in your pbx and make sure you are forwarding those ports correctly. By putting the call on hold, you stop sending out audio traffic restart sending audio when you pick the call back up. By forwarding the entire RTP range to your pbx, this should fix your issue.
Mar 08, 2011 | Polycom SoundPoint IP 550 IP Phone
How to record conversation with a caller
when the call is active, select option> you will get the option for recording the call conversation. And the call will be saved under voice record folder
Jul 19, 2010 | Samsung B5722 Cell Phone
"Call Blocked" appears in the 6310 display on incoming calls...
"Call blocked" refers to the phone system caller ID name; this has nothing to do with the Fax function of the HP6310. Some callers block their name from showing up on your phone's call ID display.
Aug 16, 2009 | HP Officejet 6310 All-In-One InkJet...
UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Uniden Cordless Phone
Incoming calls "Unknown" reflected on screen and contact
check on the phone if you have the CLI activated also contact your service provider for activation of the CLI to receive the caller identification
cheers
pls rate the solution
Jun 29, 2009 | Samsung SGH-E370 Cellular Phone
HAVING PROBLEM WITH CALLER ID WORKING
Go onto the menu of the handset and set caller id to on.
Mar 16, 2009 | ATS RA2180BB Cordless Expansion Handset
Caller id
First you need to verify if the caller id does that to all incoming calls, showing numbers only, or if it only does that to only numbers stored in directory. If it does that to all incoming calls then you need to check manual to see if there a setting to allow both name and number of all incoming calls. Either way you need to make sure caller id functions allows both name /number on display.
Oct 13, 2008 | Panasonic KX-TG5672 Twin Cordless Phone
Can't switch from voicemail to incoming call without losing messages.
Probably not, but the voice mail extension is still a dialable number. Try 500 or 165 or asking whoever installed it what the extension is.
It will prompt you the same as if you had pressed the MESSAGE button, only there will not be any new messages. You just have to play the OLD messages and you'll hear them.
Carl
Sep 08, 2008 | Panasonic KX-T7630 Corded Phone
Lands Phones Logo
77 people viewed this question
Top Samsung Lands Phones Experts
Don Hart
Jose Ma DM.
Jose Ma DM.
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
