Question about Maytag Washing Machines
Maytag Model MAV 4057AWW Top LOAD
Machine will do all the cycle but will not spin on any cycle. sometimes the drum may move approx. a couple turns and then stops. please help me with tyhe cause.
  • cikid May 19, 2008
    washing machine will not go into the spin mode on any of the cycles can u help me ?see model above
Clutch spring inside transmission was either broken or came away fr. shaft, 10yrs warranty on this model so maytag is replacing transmission. the Maytag man keeps getting bussier all the time, product is falling in ratings by conusmers guide .
Posted on May 22, 2008
Maytag MAV 8260 AWW Does not work at all. No water flow, no spin (even when filled with water from hose) Does it have an internal fuse? Where is it located? Is the large timer switch the brain of the...
Some model have fuse in top control panel, check lid switch, yes large button is the brains, it sometime can fail but usally only takes out 1 of the cycles.
Nov 02, 2013 | Maytag MAV7600 Top Load Washer
Maytag mav-1 doent spin
What does it do when it gets to the spin cycle?
Nov 29, 2012 | Maytag Atlantis MAV6451 Top Load Washer
Wash machine model mav 7600, started making tremendous noise, first in spin cycle only and then in wash cycle also. After running a few loads with the noise the machine just stoped running....
This sounds like collapsed/broken drum bearings. Check for movement between inner and outer drum. Also rotating the drum by hand will be hard (or immpossible), and noisy. It could be the motor and belt, but most times it is bearings.
Aug 11, 2010 | Maytag Washing Machines
Exessive noise when in spin cycle?
Could be dirty bearings. As long as it is still spinning, it is nothing to worry about. If it suddenly stops one day, it is probably frozen bearings or the brushes in the motor.
Jun 23, 2009 | Maytag Dependable Clean Top Load Washer,...
Maytag MAV 9600 grinding noise/no agitation. Tub
sounds like a transmisson problem expensive to fix
May 17, 2009 | Maytag MAV9600 Top Load Washer
SPIN CYCLE WON'T START UNLESS DRUM IS MANUALLY STARTED
YOU NEED A NEW COUPLING THAT GOES BETWEEN THE MOTOR AND THE TRANSMISSION...IT'S ABOUT A $20 PART.
Mar 13, 2009 | Maytag PAV2300 Top Load Washer
My maytag atlantis mav6200 only spins on whites cycle
Try running the machine in another cycle the very next time you use it. I'm trying to determine if this is machine fault something else.
If you just used the machine wait for about 1/2 hour before starting it again.
Jan 14, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Washer Noise While Spinning
Most washer models have snap-clips holding the front of the top panel down, with hinge-like clips at the back. Carefully pry up the top panel on the front of the machine using a tool that won't scratch the finish, such as a plastic or wooden wedge. If it does not pop loose fairly easily, then carefully examine the back of the machine to see if this is a rare model that has screws holding down the top panel. (But really, it _should_ just pop loose.) Once the top panel is tilted up to expose the inside, you should be able to see everything you need to see inside the body to evaluate a spinning drum problem.
Aug 04, 2007 | Maytag MAT13MN Top Load Washer
Washing Machines Logo
150 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
