Question about Motorola Mobility RAZR V3
Keypad backlight does not come on
The backlight for the keypad does not light up. Has done on occasions in the past.
    Sergeant:
  • 282 Answers
Change the keypad flex connector. If still don't come the light you need to change some parts near flex connector.
Posted on May 19, 2008
No backlight or key pad light nokia e71
There is a light sensor in your Nokia E71
This light sensor senses the outside light and activates the keypad light accordingly.
When you have enough backround light the keypad light wont light up.If the background light is less then the keypad light wil light up.
You dont get the keypad light ON because the light sensor might have activated.
If in dark also you wont get the keypad light on then the fault lies with the keypad light unit.please give your mobile to the nearest authorised service centre for service.
Thanx
Jul 26, 2010 | Nokia E71 Smartphone
Is there a way to turn off the keyboard lights. It is nearly impossible to see the letters when the lights are on.
I went to Settings/Display/Backlight Timer/Display & Keypad then selected off.
You can see the keys on the keypad a lot better with the backlight off.
Nov 19, 2009 | LG Neon GT365 Cell Phone
No backlight on my n95
LCD Back light not working:------ To fix this you need to change a coil in the Board of the phone. The Image of the cable location is below:----- dcd5d17.jpg Sir, I am honest and advising you to consult another expert for the back light problem in the Top Slider Keypad. Sir, please rate my solution for the first problem.
Thank you Sir, I wish the second problem will be solved. Have a nice day.
Sep 23, 2009 | Nokia N95 Cellular Phone
Is there any way of turning on the backlight on the numeric keypad on the u600?
From your main menu go into "Settings". Select.
Scroll down to number 5 "Light settings. Select.
Scroll down to number 3 "Keypad light". Select.
It will probably be set to "Night time" 05:00 PM.
Use your direction pad to change it to "Any time" Save.
The keypad backlight will be on all the time.
Aug 17, 2009 | Samsung SGH-U600 Cellular Phone
Keypad malfunction
its simple.i discovered it myself.remove the housing of the phone,then remove the white sticker above the keypad circuit.when your done insert the battery,turn on the phone and short circuit the backlight in the "Ok" key (not the center) in the upper left with the number "2" key.after that your phone will restart.and done
Jun 21, 2009 | Sony Ericsson K550i Cellular Phone
1997 BMW 318iS manual coupe - fuel warning light stays on
The last comment added to thread should work OK.
Jan 07, 2009 | 1997 BMW 318
Backlight on the screen not working
there is dim light on the screne
Nov 12, 2008 | Nokia N95 Cellular Phone
K800i no backlight or keypad light. it is not a firmware fault a i took it to a specialist and they tried flashing it but no luck, they told m it needs a new screen but if that is the case why doesnt the...
go to setting and hit on display and u shold see when u get there then look for backlight and keypad light hit on them and u will be able to do the rest its easy
Sep 12, 2008 | Cell Phones
Keypad backlight erratic
There is a small opaque circle just above right soft-key. Put a small piece of black plastic electrical tape over it and keypad lights all the time. This circle apparently is a so-called "battery saver" which senses light in the area so unless you're in a dark area keypad will not light. There is absolutely no mention if this in the manual that I can find.
Aug 22, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Nokia1600 repairing
hi there sir must go to your nearest service center to replace your LCD it must be damage already. the light of that phone was built-in to the LCD display. and that is why also your keypad doesn't have light cuz' it is series to the display light.
ok!
peace!
Mar 30, 2008 | Nokia 1600 Cellular Phone
Motorola Mobility RAZR V3 Logo
160 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
