Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
TV shuts off on it's on after about 20 - 30 minutes of play
I initially thought the problem was signal related, but have tested three different inputs and none of them solve the problem. TV will freeze then shut itself off.
    Scholar:
  • 173 Answers
Freeze like the picture is in pause?
picture freezing is desired function on the remote and handled mainly by the "picture and picture" circuits. but the video that is involved and processed there is handled by many circuits and microprocessors.
what you describe is an intermittent heat related problem if you almost can set a watch to the the shut-off time. you can feel, if your a tech, what part is running hot with a finger or start freezing a suspect part with freeze spray and see if stays on long past overdue. make sure your vent holes in the back are not covered and keep the back at least 1/2 foot from the wall.
Posted on May 24, 2008
My Phillips flat screen picture flips after being on about 10 minutes no flashing lights I switch the format and it straightened up for a minute but started back flipping can you help me assess this...
Vertical 'flipping' is almost unheard of with modern digital video. Are you receiving your signal via the coax antenna or cable input? You might try using a different input method and possibly a different source (DVD player etc.) to see if the problem is consistent. You might also check the refresh rate of the TV and try changing it. If the problem only happens after the TV warms up, you may have a heat related electronic problem with the TV. Try blowing a fan on the TV too see if this delays the problem for 5 minutes or so.... If it's heat related, it will likely be an expensive repair unless it's under warranty.
May 05, 2014 | Televison & Video
VCR/DVD & Samsung TV: "weak or no signal"
Take the VCR remote, check VCR output settings ( scart1, scart2 , RCA) and signal format (PAL) etc
Jul 26, 2008 | Samsung TX-T3093WH TV
Just picked up an old Pioneer PDP 4304 HD 47in TV and sound will play through various inputs but NO Picture. That is only some little colorful speckles. Any Suggestions?
Please check if the video inputs are working as what is observed by you is that none are working. If so this means there is no signal processing specially Video and the fault seems related in the AV section. You need to use a signal test to confirm from the tuner section, to the IF section and the AV section.
Possible the fault seems related to a failure in the AV processor/ logic switch.
Sep 28, 2011 | Pioneer PureVision PDP-4304 Television
I have an onn 42 inck flatscreen tv and since last night have lost all colour on screen,,,tried cable and scart all seem ok,,any ideas
Hi.
If the problem happens using different input and devices, then it is either the terminal circuit (input/output connectors) or the processing unit in main board. The terminals are unlikely the culprit if problem concerns different inputs.
I imagine that the picture is not properly B&W (gray-shades) but some kind of reddish, bluish or greenish picture as the LCD will process picture using RGB (red green blue) channels instead of CYMK (cyan yellow magenta black) like CRT TVs.
Test the TV using an external aerial. You will notice if the channels have the wrong color even from static.
Use different inputs, different cables and different devices. beware of SCART cables, the SCART contacts are very easy to break. A defective cable will loose picture. Better testing using AV cables and component cables. AV cables are red/white for sound and yellow for video. If the two-wired yellow cable does not work, then the TV is faulty.
Other test can be done using component cables. Component cables send the three red-green-blue signals on different cables, hence testing is simple. Test swapping cables and see if TV tone stays the same if color tone changes the problem were the cables. Test also using at least two different devices (e.g. one DVD player and one TV receiver or a playstation).
If you find that the TV is defective call the manufacturer at the number listed on manual. If the problem is that one or more RGB channels do not work the TV main controller board must be replaced.
Regards.
Ginko
Sep 13, 2011 | Televison & Video
Hello, In the last couple of days my Sony TV (KDL32S3000) has been working fine for about 10 minutes then a message appears saying 'POWER WILL BE TURNED OFF BY AUTO SHUT OFF SOON' this message...
If this happening when TV is viewed then it is possible that the auto shut off is active as no signal is detected by the processor and so is instructing to shut down.
However this fault is related to a problem in the signal detection circuit, if this happens with the auxially circuit- play station- then some logic gate is faulty which needs to process and detect the signal.
Remove power for few hours and see if the fault resets, if not the circuit needs a technical review.
Jul 08, 2011 | Sony KDL-32S3000 32 in. LCD Television
Denon receiver AVR-3300: Unstable source selection
Go over here: http://denon.custhelp.com/cgi-bin/denon.cfg/php/enduser/std_alp.php?p_sid=1NlVrsDj
I have some Denon components myself and had some problems. Ask them here, and within a day you should have solution for this problem.
Probably you have to reset the device to factory settings.
Jul 22, 2009 | Denon AVR-3300 Receiver
Stuck on a video mode
Some TV's disable inputs if there is no signal. I suggest confirming cables are connected properly, and accessing the system menu, and perform an autoscan for channels
Apr 27, 2009 | Initial HDTV-320 32 in. LCD TV
A friend accidentally changed settings on my panasonic plasma model th42pa50a..now no picture..the panasonic logo appears on screen only
Press TV/Video button repeatedly on Remote Control as shown in below picture.
You will get picture in TV from all connected things like cable, DVD etc
Dec 01, 2008 | Televison & Video
Yellow line on left side of screen-
If this is only happening on one input like your cable input and the dvd player is working great on a different input, then the issue can possibly be signal related and not a problem with the tv, if this haapens on any input you are watching, check to see if it affects the menu if it does then your looking at a Logic board issue, if it doesn't affect the menu but happens on multiple inputs then you have to replace the signal board
Aug 18, 2008 | Philips 42PF7421D 32 in. LCD HDTV
Crosley TV
The TV is in the demo mode. This has nothing to do with the cable signal. If it is a Magnavox set, which is what you have it listed under, then press the volume up and the volume down buttons at the same time.
Aug 07, 2007 | Philips Magnavox 20MS3442 20" TV
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
190 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
