Question about Hotpoint WF645 Front Load Washer
Filter unable to locate filter so as to clean it
LE5L
Posted on Sep 06, 2008
MW512 Fisher & Paykel Washer Machine...Where is the lint filter located?
Fisher & Paykel machines don't have a lint filter.
Manual cleaning of agitator and s/steel bowl will make your washing cleaner.
Oct 12, 2012 | Fisher and Paykel Washing Machines
I have a WM2277HS TROMM Washing Machine and at the end of the cycle the water does not drain nor does it spin. Therefore, the rinse & spin cycle only rinses but does not drain the water nor spins. ...
Sounds like a bad lid switch. Check to see if you hear a "click" from the switch when you open and close the lid. If you do not, then you should replace the lid switch.
Nov 26, 2010 | LG WM2277HSW XL Front Load Stackable...
Unable to remove filter on machine
Assuming you have located the filter at the bottom front of washer, you unscrew it anti-clockwise to remove and clean.
If there is a small screw in the filter handle, then unscrew it first, before removing filter.
Please rate my solution.
Thankyou.
Feb 01, 2010 | Candy AQUA1000T Front Load
I have a Creda 1200 washing machine, I am unable to locate the fluff filter. Does my machine have one? if not, what happens to dogs hairs etc? will they damage my machine?
The filter is at the rear of the washer.
Remove the lower rear cover of washer.
Remove the large black hose fastened to bottom of drum.
Clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well..
Thanks.
Jan 17, 2010 | Creda W120VW Front Load Washer
Dryer shut off during cycle, unable to restart, does not start when pushing knob.
sounds like your blower is either clog, or the exhaust duct is clog with lint. also pull the front face off and clean out the location where the filter sits, they become clog over time and no ones cleans there. Your over heat protection circiut shuts down the dryer when it cannot exhaust enough air.
Jan 04, 2010 | Maytag PYE2300AY Electric Dryer
Washing machine will not spin when full of water, but does when empty & water will not drain out.
The washer will not spin if it has water in it.
You need to locate the pump filter, remove and clean it.
You do not specify a model number, so I am unable to tell you exactly where the filter is.
Some are at the front, others inside at the rear.
Hope this helps you.
Dec 18, 2009 | Hotpoint Washing Machines
Location of the filter in the S1444 Seimens washing machine
Hi There
The filter is at when open the door look straight down. just grab it and pull up the filter. I got lost finding the filter when i bought my dryer.So your not alone on that one.lol
Hope this little advice helps you. Let me know how it went and thank you for writing to fix ya. Merry X-Mass and a Happy New Year.
Best regards Richard
Dec 14, 2009 | Siemens WD61392GB Front Load Washer /...
Filter needs cleaning as water does not empty
I was unable to locate your filter in your machine but if it would help after you clean the filter you could install an inline filter between the valve and the hose. This is an RV filter it just screws on like the hose.
http://www.flowpur.com/html/rv_filters.html
The FP12GKE shows just how easy it is. Any RV filter will work.
Aug 19, 2009 | Washing Machines
Location of water filter on lg fridge freezer
OPEN DOORS LOOK IN UPPER RIGHT AND UPPER LEFT
Jul 22, 2009 | Refrigerators
Yam ybr125 wont idle off choke,also cannot find idle control scre
you may need to replace your spark plugs
as the idle should remain constant as long as the tune of the bike is good IE oil changes done regularly / plugs cleaned and or gapped , air filter cleaned or replaced all of these can affect your bike.
hope this helps
Dec 13, 2008 | 2005 Yamaha TT-R 125 LE
Hotpoint WF645 Front Load Washer Logo
114 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
