Question about Toshiba Satellite A135-S4527 Notebook
Windows won't run
Bootstat.dat file is compressed
  • 143 Answers
Try this solution and let me know if it works for you. You may have to get this hard drive into another computer and give it a whirl from there.
Posted on May 19, 2008
Read dat files
right click the dat file...choose open windows media player and click ok...
now on all the files with .dat extension will be played by the windows media player.
Dec 30, 2009 | Microsoft Windows Vista Home Premium with...
How to Backup and restore the registry
In case you go and modify the registry manually and you want to back it up in case something goes wrong and you want to restore it, this is perfect for you.
1.) Go into the start menu and click "Run".
2.) Type "cmd" and click OK
3.) type in the window "copy c:\windows\system.dat c:\windows\system.000" and press enter.
4.) Once Complete type "copy :\windows\user.dat c:\windows\user.000" and press enter.
You have now created a backup of the registry.
1.) Go into the run menu again and type cmd.
2.) Type in the 2 commands that was shown in the backup section except in each command swap the twon directores.
(e.g.) "copy c:\windows\system.dat c:\windows\system.000" will become "copy c:\windows\system.000 c:\windows\system.dat"
Whatever was backed up when you created the backup file will be restored to the windows registry.
on Dec 26, 2009 | Computers & Internet
How can you backup and restore the Registry?
Maintaining the Registry
Windows 95
Microsoft included a utility on the Windows 95 CD-ROM that lets you create backups of the Registry on your computer. The Microsoft Configuration Backup program, CFGBACK.EXE, can be found in the \Other\Misc\Cfgback directory on the Windows 95 CD-ROM. This utility lets you create up to nine different backup copies of the Registry, which it stores, with the extension RBK, in your \Windows directory. If your system is set up for multiple users, CFGBACK.EXE won't back up the USER.DAT file.
After you have backed up your Registry, you can copy the RBK file onto a floppy disk for safekeeping. However, to restore from a backup, the RBK file must reside in the \Windows directory. Windows 95 stores the backups in compressed form, which you can then restore only by using the CFGBACK.EXE utility.
Windows 98
Microsoft Windows 98 automatically creates a backup copy of the registry every time Windows starts, in addition to this you can manually create a backup using the Registry Checker utility by running SCANREGW.EXE from Start | Run menu.
What to do if you get a Corrupted Registry
Windows 95, 98 and NT all have a simple registry backup mechanism that is quite reliable, although you should never simply rely on it, remember to always make a backup first!
Windows 95
In the Windows directory there are several hidden files, four of these will be SYSTEM.DAT & USER.DAT, your current registry, and SYSTEM.DA0 & USER.DA0, a backup of your registry. Windows 9x has a nice reature in that every time it appears to start successfully it will copy the registry over these backup files, so just in case something goes wrong can can restore it to a known good state. To restore the registry follow these instruction:
* Click the Start button, and then click Shut Down.
* Click Restart The Computer In MS-DOS Mode, then click Yes.
* Change to your Windows directory. For example, if your Windows directory is c:\windows, you would type the following:
cd c:\windows
* Type the following commands, pressing ENTER after each one. (Note that SYSTEM.DA0 and USER.DA0 contain the number zero.)
attrib -h -r -s system.dat
attrib -h -r -s system.da0
copy system.da0 system.dat
attrib -h -r -s user.dat
attrib -h -r -s user.da0
copy user.da0 user.dat
* Restart your computer.
Following this procedure will restore your registry to its state when you last successfully started your computer.
If all else fails, there is a file on your hard disk named SYSTEM.1ST that was created when Windows 95 was first successfully installed. If necessary you could also change the file attributes of this file from read-only and hidden to archive to copy the file to C:\WINDOWS\SYSTEM.DAT.
Windows NT
On Windows NT you can use either the "Last Known Good" option or RDISK to restore to registry to a stable working configuration.
How can I clean out old data from the Registry?
Although it's possible to manually go through the Registry and delete unwanted entries, Microsoft provides a tool to automate the process, the program is called RegClean. RegClean analyzes Windows Registry keys stored in a common location in the Windows Registry. It finds keys that contain erroneous values, it removes them from the Windows Registry after having recording those entries in the Undo.Reg file.
on Dec 02, 2009 | Computers & Internet
How do i read .dat files that i receive by email
If these files are forwarded email messages, you can try this trick: save the .dat file to your disk, rename it with an extension .eml instead of .dat and then try to double click it. OE should open it in a new window.
However, if the .dat files are something else, you have to know what they are... Might try saving them and opening in Notepad to see if they contain anything familiar.
Oct 25, 2009 | Microsoft Outlook Express
Error message says: missing file, aquatica.dat
This is a system files. These are basic file's in a window directory.Regarding aquatica.dat, it is a multimedia file component.
You can repair this by downloading .dat file from .dat database. You can easily search the file online and add it. If you purchase a software, it would cost you certain bucks. Better reinstall windows or restore.
Computer can be affected by the missing of these files. It depends on How many files are missing, configuration of the PC, Virus, Malisware, Adware etc.
The simple option - Restore or Reinstall, if not a tech.
Let me know,if need any further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 25, 2009 | Dell Computers & Internet
I havent been able to download anything on my pc for a few weeks now, i have tried absolutely everything, i cant even download attachments on my email, please help
u've to delete a (index.dat) file.
in Vista
in XP
u've to go this link and remove each index.dat file.
Sep 18, 2009 | Microsoft Windows XP Home Edition
New version of window live
in Vista
in XP
Sep 18, 2009 | Microsoft Windows XP Professional SP2 Full...
How do i enable ntfs compression in vista x64
You don't want to compress your drive... it's really not recommended. And you can't de-compress it once compressed.
I will suggest buying a new drive; Harddrives are rather cheap, and cloning utilities will make the transfer of your data eazy peazy.
May 26, 2009 | Microsoft Windows Vista Ultimate Edition
Playing media file
If you are using Window's Media Player 7 Or Greater then use the following code;
I Used Windows Media Player 11
'For Opening a file WindowsMediaPlayer1.URL = "<Drive>\<Path>\<Filename WIth Extension>"
'For Stoping WindowsMediaPlayer1.Controls.stop
'For Playing
Explore "WindowsMediaPlayer1.Controls." it has all the control u require
Sep 09, 2008 | Lenovo 3000 J Series 1.80G VBE PC Desktop
Toshiba Satellite A135-S4527 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
