Question about Canon PowerShot A630 Digital Camera
No flash in auto mode
My A630 will sometimes operate flash in auto and most of the time (as of 8 weeks ago) if flash is on, picture wont take at all (no click, no shot no nothing). Any suggestions?
  • Canon Master
  • 4,738 Answers
Try a mode other than auto, and turn off the flash. Then try taking a picture. Did it work? If so, then your flash is either burned out, or the flash safety circuit thinks that the camera is open. If the flash is burned out, then professional repair is required, as a flash change-out is not trivial (Call 1-800-OK-CANON). However you mention the flash works sometimes, so a totally burned out flash tube is unlikely.
It's more likely to be only a break or bad connection in the safety circuit. Many Canon cameras use some of the screws in the camera case to serve as a means of detecting if the case is open (and thus disables the flash to prevent shock). Examine all the screws around the perimeter of your case. Are they all there and tight? If not, tighten loose screws and try moving and replacing any missing screws with one of the others that are still there.
Posted on May 28, 2008
I have a canon powershot a630. It suddenly won't take pictures in auto mode. Orange light in front stays lit and arrow on display screen flashes. It will take pics in some other modes (P, Tv, Av,...
See this blog article. If you don't notice any gaps, and tightening all the loose screws doesn't help, then the next likely problem is the flash unit itself is burned out. If so, this would require professional repair to correct.
Dec 30, 2010 | Canon PowerShot A630 Digital Camera
How do I turn off the flash for the canon powershot a630?
First of all, the flash can not be turned off in "Auto" mode. You can turn it off in any mode other than Auto. Would recommend Program "P" mode, which is very similar to Auto, but allows you to modify certain minor items such as flash and white balance.
Rotate your mode dial to "P", then press the button on the back with the "lightning bolt" icon. Press until the lightning bolt with a slash shows up on your LCD screen. The flash is now turned off in Program mode. Try taking a picture.
Remember, if in low light conditions you'll need to keep the camera extra steady without flash to get a clear picture. Recommend placing the camera on a table or chair (or even better, use a tripod), then using its autotimer to snap the picture.
Nov 01, 2009 | Canon PowerShot A630 Digital Camera
A630 Indoor pictures are too dark in Auto, Flash
try using night mode indoors. otherwise, simply get into setup and go back to factory settings, and use AUTO mode. hope it helps
Oct 07, 2009 | Canon PowerShot A630 Digital Camera
Pictures too Dark
Try resetting the camera. Go into the setup menu and find "reset".
Sep 21, 2009 | Canon PowerShot A630 Digital Camera
Lost manuel to canon powershot A630 and I wanted to know how to take a black and white picture.
By pressing the center button on the four-way controller, you'll open up the Function menu. This menu has the following options:
  • ISO speed (Auto, High ISO Auto, 80, 100, 200, 400, 800) -
  • White balance (Auto, daylight, cloudy, tungsten, fluorescent, fluorescent H, underwater, custom) -
  • Drive (Single-shot, continuous, self-timer [2 or 10 sec, custom] -
  • My Colors (Off, vivid, neutral, sepia, black & white, positive film, lighter skin tone, darker skin tone, vivid blue, vivid green, vivid red, custom color) -
  • Flash exposure compensation (-2EV to +2EV in 1/3EV increments) - in manual mode you can adjust the flash strength in three steps (1/3, 2/3, full)
  • Metering (Evaluative, center-weighted, spot)
  • Compression
  • Resolution
- Lisa
http://www.dcresource.com/reviews/canon/powershot_a630_a640-review/
Feb 26, 2009 | Canon PowerShot A630 Digital Camera
A630 clicks and wont take picture. Stays in preview mode.
Do you mean you are expecting it to show the photo that you just took for a few seconds before it goes back to preview mode? There's a menu setting which I think is called "Picture Review" and you can set it for something like 0, 2 seconds, 5 seconds, something like that.
I hope that was it.
-Vince
Oct 01, 2008 | Canon PowerShot A630 Digital Camera
No flash in "P" mode
In all of modes you can use "up" key to toggle between "always on", "auto"  and "off" mode for flash. (in some mode there is only auto and off.) also the flash light icon on top right of screen shows th status of flash. I hope this helps...
Aug 02, 2008 | Canon PowerShot A640 Digital Camera
Dark image....even using flash.
go to the menu & open setting file.properly check the settings of auto mode
Aug 18, 2007 | Canon PowerShot A630 Digital Camera
Canon PowerShot A630 Digital Camera Logo
176 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
