Question about Cyberhome DVD Recorder - DVR1600
CYBERHOME DVD RECORDER DVR1600
I'M TRYING TO RECORD A TV SHOW, AFTER I PUT A BLANK DVD+R, IT SHOWS 'NO DISC' ON THE DVD RECORDER.
  • Anonymous May 31, 2008
    My dvr 1600 also shows "no disk" all the time. sometimes it work but most of the time does not work. please suggets any solution . thanks
  • 3 Answers
I cannot say this with authority, since I own a 1200 model, but from what I've read of that model researching my own it's most likely the power supply. It is repairable if you or someone you know can solder. Here's what I found:
http://cms-system.cyberhome-dvd-help.com/modules.php?name=Forums&file=viewtopic&t=2699
I did pretty much the same to my 1200, replaced two 2200uF caps with 35V versions. Make sure the rated voltage of the new caps is at least 16V! Higher is better. There's also a firmware update for that model, you might want to look into that too. Of course, you can't use it until this is fixed.
Posted on May 24, 2008
When a blank disc is inserted it attempts to load and then a message appears saying no disc. i am therefore unble to format the disc for recording. If i eject the disc about 10times somtimes it will then...
OK you could try to use a cleaning DVD that may help.
If that doesn't work, then you have a faulty laser or quadrant detector in your laser assembly and the only way to fix it is to replace it.. it is also possible there are other problems too.
However i would doubt the economics of being able to do so. and any monies to be spent may well be put towards a new unit with a warranty?
Aug 06, 2010 | Cyberhome DVD Recorder - DVR1600
No Disc
I have a Cyberhome DVD Recorder (DVDR16D) when i put in disc it reads no disc on my TV. any solution?
Jul 08, 2008 | Cyberhome DVD Recorder - DVR1600
CYBERHOME DVD RECORDER DVR1600 - Need Power Supply
Bill,
I can rebuild your power supply if it is not in aches. A Compute power supply works with these unit if you know how to modify it.
May 22, 2008 | Cyberhome DVD Recorder - DVR1600
No Disc
I have the same model ... you can't use DVD-R or DVD-RW discs, only DVD+R or DVD+RW
Apr 26, 2008 | Cyberhome DVD Recorder - DVR1600
Finalizing DVD disk
In cases like this you should use nero to finalize the disk for you or stick it in the computer to get the data off the disc using nero as well.
good luck
smeags.
Dec 03, 2007 | Cyberhome DVD Recorder - DVR1600
CyberHome DVD Recorder - DVR1600 says No disc when there is a disc
Hi! Pick a jhonson's bud -- dip it into the lens cleaner solution -- rub gently on the lens both clockwise and anticlockwsie -- leave it to dry -- cover up -- run the machine.. but be careful -- don't touch the lens with ur finger and dont try to rub roughly -- lens may go forever. still if the problem remains , replace the lens. chhoton
Aug 21, 2007 | Cyberhome DVD Recorder - DVR1600
Cyberhome dvr1600 problems
Try cleannng machine with dvd cleanner if u have staples surplus near u it only costs 10 can cn twice thiswoked for me had a same promblem.
Aug 10, 2007 | Cyberhome DVR 1600 DVD Recorder
Recording problem on new blank discs...
Try using Verbatim DVD's, they seem to work the best with Cyberhome recorders.
Nov 30, 2006 | Cyberhome DVR 1600 DVD Recorder
Cyberhome DVD Recorder - DVR1600 Logo
152 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
