Question about Acer Aspire 5100 Notebook
Unlock DVD Region code
Hi
I am having Acer Aspire L5100 mini pc - Window Vista Home Basic. My pc DVD model was Pioneer DVD -RW DVR-K06RS. Currently, my DVD Player has been locked, and was unable to watch certain DVD. I hope to unlock it to region free. Could you recommend me a suitable software? Thank you.
Fiona
  • 38 Answers
You could install videolan vlc media player(google it).it seems to ignore region settings on any computer, except as far as i know it doesn't work with macs.
Posted on Aug 08, 2008
Dear Bibfion75
Could you get answer to your problem? I am also having same problem for my Acer laptop. If you got any answer please sms me or call me at Mob###97639-34081
Posted on May 31, 2008
    Champion:
  • 207 Answers
Reset the software back again
uninstall and reinstall it
and then check
Posted on May 19, 2008
  • 8,596 Answers
It is illegal to change the DVD region coding. Also, this question should be reposted to DVD section- you will get better results.
Posted on Jun 10, 2008
Pioneer DVR-K17RS ATA ACER CODE=39
Code 39 for cd/dvd drives is a common problem, you need to edit the registry to fix this error. See these instructions on how to fix code 39.
Mar 28, 2009 | Acer Aspire 5610-4648 Notebook
Pioneer DVD RW DVR-K16 Problem
you have to reset your region code.a good technician or even the pioneer care can reset the codes in few minutes. you also take your user manual which is must.
Mar 27, 2009 | Pioneer (DVR-K16) DVD RW Dual Layer Burner
Unlock region on dvd
you have to convert your firmware(dvd) to rpc1
Sep 30, 2008 | Computers & Internet
it's windows issue, you just need to edit windows registry.
Follow this step from microsoft:
http://support.microsoft.com/kb/314060
Jul 01, 2008 | Acer Aspire 5610-4648 Notebook
Hi How old is this laptop? If it is brand new, then you should be able to send it back to acer. Its the problem with drive or mainboard not with the drivers.
Thanks
Mar 16, 2008 | Acer Aspire 5610-4648 Notebook
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)". You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
This will surely help you resolve your issue. Good Luck!!!
Thanks
Feb 22, 2008 | Acer Aspire 5630 Notebook
Try to remove the device from Device manager, and then reinstall or upgrade the driver. If the error continues to occur, it may be possible to edit the operating system Registry to resolve the issue.
Click the Start button, press run and type regedit.
  1. In the Registry Editor window, in the left pane, double-click the HKEY_LOCAL_MACHINE folder.
  2. In the HKEY_LOCAL_MACHINE folder, double-click the System folder.
  3. In the System folder, double-click the CurrentControlSet folder.
  4. In the CurrentControlSet folder, double-click the Control folder.
  5. In the Control folder, double-click the Class folder.
  6. In the Class folder, click to select the {4D36E965-E325-11CE-BFC1-08002BE10318} folder.
  7. In the right pane, click to select the UpperFilters registry value.
  8. Press Del / Delete to remove the registery entry.
  9. In the Confirm Value Delete dialog box, click the Yes button.
  10. In the right pane, click to select the LowerFilters registry value.
  11. Press Del / Delete to remove the registery entry.
  12. In the Confirm Value Delete dialog box, click the Yes button.
  13. close the regedit window.
  14. Restart the computer.
Feb 11, 2008 | Acer Aspire 5100 Notebook
If you can't restored the driver, you should reload the operating system using Alt+F10 or using disks (not from windows, boot from disks)
In your case, it's look like you can't access the dvd in windows, i hope you can access in dos mode.
Jan 20, 2008 | Acer Aspire 3680 Laptop
Hi i want to unlock my laptop to any region, can you help
PC DVD drives can have the region code changed 5 times only.
Whatever region you set it to on the last available change will be the units permanent region from then on!!!
Any hardware modification to the unit to 'unlock' it is a violation of many countries laws and absolutely unlawful in the U.S..
The region codes are there to protect the copyrights of the media producers and ensure the units proper operation with inserted media.
Jan 05, 2008 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5100 Notebook Logo
450 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
