Question about Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424
Brand new freezer
I just bought a brand new kenmore upright freezer. I leveled an plugged it in using the coldest setting. Went to check the freezer temp to switch frozen items from old to new and found that it wasn't working. Not sure what to do I need the new freezer working cause the old one is shot.
  • vphillips1 Jun 27, 2008
    freezer not freezing
    Genius:
  • 1,122 Answers
FIRST TURN THE TEMP CONTRAL ALL THE WAY OFF.LISTEN FOR A CLICK AND TURN TO HALF WAY SETTING IF IT CLICK IT'S ALLRIGHT, NEVER TO COLDEST,NEXT PLUG A RADIO IN THE PLUG TO MAKE SURE YOU HAVE POWER,DOES YOUR FREEZER HAVE A LIGHT ON FRONT TO TELL IF POWER IS ON?ALSO CHECK BREAKER BOX,THANKS-MIKE
Posted on May 29, 2008
I accidently turned off freezer.How do i turn it back on?
Turn the interior temperature control back on by setting at approx halfway between "off" and "coldest". (Make certain the branch circuit is hot - you should hear the compressor turn on when you set the control, possible an interior light will come on as well).
If the freezer does not run, check to see if you accidiently pulled the flash defrost plnger (if equipped). (See age 8 in your manual).
If you don't have a manual, you can download one here:
ShopYourWay KENMORE Upright Freezer ShopYourWay
(This is for Kenmore model 253.23024-101 or -102).
Apr 22, 2014 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezer runs but won't keep most foods frozen even on coldest setting
Check condenser clean and fan working. Check it's not frozen solid because you've been running it full pelt; if it is, fully defrost it then set it at a mid range setting.
May 13, 2012 | Kenmore Freezer 20.6 cu. ft. Frost Free...
I have a kenmore upright freezer and can't remember which setting it should be on. It has coldest 1 2 3 etc.
I keep min two notches from the coldest setting.A great way to check where you should set yous,is ice cream.Put an open container of ice cream in the freezer,and turn the freezer to coldest.The next day try to scoop the ice cream.If the ice cream is hard the freezer is too cold.Adjust the freezer two notches ,and try the ice cream the next day.Repeat till you are happy with the hardness of the ice cream.It should be easy to scoop but not too soft.
May 17, 2011 | Kenmore 14.8 cu. ft. / 419 liter Chest...
How do I adjust the freezer temperature on a Kenmore upright freezer?? Brand new, model number 461.27432, didn't come with a manual.. can't tell whether 7 or 1 is considered the coldest temperature?
Sorry there is no manual on-line for the freezer. But I can tell you this 7 is the coldest and 1 is the warmest.
Good Luck and Please rate 4 thumbs up for the free answer.
Jul 04, 2010 | Kenmore Freezers
In OF mode-wont come on - is new
I have a similar freezer under the Kenmore brand and experienced the same problem. Try raising the temp setting to +10 degrees. Unit should then start up again.
Jul 29, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Problem with upright freezer not freezing
It sounds like the unit is low on freon or the compressor is going bad. You have several other components that could be affecting this as well. Make sure the coils are free from dust and clean underneath. This is a bit premature for you to have problems now, especially since it is a Sears product.
Feb 15, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Purchased a 2004 upright freezer i dont know how to set temp
sir seven is the coldest setting. Good Luck
Jan 10, 2009 | Kenmore Freezers
Kenmore freezer quit working after power outage
simple stuff, you have a compressor a stat and power. check the receptacle to be sure you have 120 volts . then check the compressor with stat at max cold setting to see if you have 120 volts at compressor. if you do then compresssor is bad =new compressor or new unit. if no power to compressor then stat is bad= new stat. i always recomend new unit cause new stat or compressor wont fix a freon leak.... i have replaced a few compressors that died soon after due to a freon leak. good luck...
Nov 23, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424 Logo
196 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
