Question about Parrot 3200 Ls Color Handsfree Bluetooth Car Kit
I want to reset to factory settings my Parrot 3200 LS but in settings there's no option to do it (as mentioned in the answer above!)
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
Who can give me a link where I can find 3200ls updates? I cant find in parrot website
Posted on Apr 28, 2019
  • Kestutis Gvildys
    Kestutis Gvildys May 01, 2019
    hi ,maybe anybody has 3200sl update bin file? my unit is working with 2.03 version and I need updates,but parrot web is dead,so if somebody has it could you send to my mail:kestas.gv@gmail.com thank you
SOURCE:
  • 17 Answers
SOURCE: can i reset my parrot back to factory settings
yes you can do this by going into settings then scroll all the way down to the bottom and select factory settings the push the middle button in. then push the green button for yes.
Posted on Nov 23, 2009
  • 132 Answers
SOURCE: Problem transferring contact list from BB 8330 to Parrot 3200 LS
I had the same issue with my Nokia phone a long time ago. To solve that issue I had to upgrade the Parrot's firmware with the laptop through bluetooth connection while in the car. I have done this a few times to get the most out of my parrot.
I recently got a Blackberry and had no issues with the contacts whatsoever. I do have to say that I dont have 500 contacts, but only 130.
If I were you I would try to update the Parrots firmware to the latest one available in the parrots website.
I am not sure if the parrots has a maximum contacts restriction. That might be also your problem.
Hope it helped.
Posted on Nov 26, 2009
Testimonial: "Thank you. I shall take your advice and upgrade the firmware. When (if?) I'm successful, I'll post my experiences."
  • 277 Answers
SOURCE: my nokia 2330 classic doesnt pair with my parrot
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Posted on Aug 16, 2010
supernova278
  • 1932 Answers
SOURCE: how do i pair my
The first time that you switch on the 3200 LS-Color, you must pair your mobile phone with the kit.
1.Enable the Bluetooth mode on your phone.
2.On the hands-free kit, scroll through the menus until you come to Settings Pair with phone and select the relevant option for your phone. A 4-digit PIN code then appears on screen. Memorize it.
3.Then from mobile serach the 3200 LS-Color device
Once the search has finished, "Parrot 3200LS / Parrot 3400LS" is displayed on your phone.
4.Select the kit. Your phone prompts you to enter a code: key in the code shown on the kit screen and confirm on your phone.
5.The kit's screen displays "Pairing".
6.Once the data has been exchanged, "pairing successful" appears on the 3200 LS-Color.
Thank You
Posted on Oct 08, 2010
dancandoit
  • 436 Answers
SOURCE: I have just bought a new apple I phone 4. I can
remove all the previous paired phones from the parrot memory and then try again. if this dont work then you will need to have the software of the parrot updated. You can do this yourself but you will need a laptop with bluetooth. then download the software from parrot web site.
Posted on Feb 25, 2011
Paired my nokia with my 3200 ls kit worked ok but then stoped and now my nokia cant detect my 3200 ls kit
Try deleting all paired devices first, Menu / settings / paired devices. The remove the battery from your mobile phone for ten seconds. Then try pairing again, this should do the trick, if not the parrot may need a software update.
Nov 23, 2011 | Parrot 3200 Ls Color Handsfree Bluetooth...
I have just bought a new apple I phone 4. I can not get it paired to my Parrot 3200 LS. I am "told" the 3200 LS will not work with Iphone 4. The phones "sees" the parrot but on the...
Feb 03, 2011 | Parrot 3200 Ls Color Handsfree Bluetooth...
How do i pair my blackberry with parrot 3200 ls, asking for numeric key
Thank You
Oct 08, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
Can i reset my parrot back to factory settings
Nov 17, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
CK 3200 LS severe background noise heard by other party - Can download software update ok and pair bluetooth laptops ok, but when I try to send download to Parrot on some computers I get message no dongle,...
get your laptop and car ready then call parrot techinical, they will talk you through it, you need to select the correct serial port. it also depends on what type of donlge you are using.
Nov 13, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
My phone connects to my parrot 3200 but it wont transfer my contacts to the device
you may need to update the parrot software and also make sure you phone software is upto date. you can try sending contacts manually by going to contacts / mark all / send as business card / via bluetooth.
i could give you more buy you have not mentioned your phone make / model.
try parrot .com for more.
Nov 09, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
ANSWERING CALLS
Check to see that it isn't set to "call forwarding".
Feb 10, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
3200 LS installed in '07 Chev Sub-Parrot Won't Power Off
try switching the red and orange wires. one is constant and one is switched. you can try by just reversing them at the inline fuses. hope this helps.
Dec 27, 2008 | Parrot 3200 Ls Color Handsfree Bluetooth...
Parrot 3200 Ls Color Handsfree Bluetooth Car Kit Logo
7,614 people viewed this question
Top Parrot Cell Phones Experts
donny ardalando
donny ardalando
ray gallant
ray gallant
Marvin
Marvin
Are you a Parrot Cell Phone Expert? Answer questions, earn points and help others
