Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer
My pump went out, probably since I didn't realize there was a filter :) I cleaned this and need to purchase a new pump. Where is the best place to purchase this pump?
  • 5,911 Answers
Assuming that your model number is correct, searspartsdirect.com has the pump for a reasonable price. Just type in your COMPLETE model number in the Search menu and you can locate the pump under the "Pump and Motor Parts" heading as item number 10 (part #8181684). If you need assistance in how to replace the pump, click on the following link for step-by-step instructions:
http://www.fixya.com/support/r401841-replacing_kenmore_elite_water_pump
If you do not wish to order the part on line, take the part number provided, and go to your nearest applaince repair retailer. I hope you find this information helpful. Please post back if you need further assistance.
Posted on May 22, 2008
What is code message F02?
Repairing the F02 error code can usually be done without ordering parts. Tools needed to repair your whirlpool Duet F02 error code are towels and a quarter inch socket.
Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out.
With the filter out clean and install it back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back, it may require you to clean the drain pump filter again.
If you require a new drain pump motor, you can purchase the part from the link below.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-error-code-f02-duet-sport-error-f02-fix/#sthash.PuGd0iuQ.dpuf
Sep 09, 2014 | Whirlpool Duet Sport HT WFW8400TW 3.7 Cu....
Why does my whirlpool frontloader stop in the middle of a cycle and read f 02
Sep 06, 2014 | Whirlpool Washing Machines
My whirlpool duet washer had a F02 code now it won't pump water
Aug 24, 2014 | Whirlpool Washing Machines
F- code 02
How to fix a Whirlpool Duet & Duet sport error code F02. Repairing your F02 error code can usually be done without ordering parts. Tools needed to repair your Duet F02 error code are towels and a quarter inch socket.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out. With the filter out, clean and install back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back it may require you to clean the drain pump filter again.
Dec 03, 2012 | Whirlpool Duet GHW9150P Front Load Washer
What does F-02 flashing on the display of my Whirlpool Duet washer mean?
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jun 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Not draining
how do i unclog the drain pump
Apr 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do i clean the pump filter on a duet washer
take the kick panel off. dead center you will see it
Jan 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a front loader whirlpool duet #ghw9100lw2
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
Apr 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport HT front load washer keeps having F21 Error
remove the lower access panel (3 screws along the bottom of unit) behind htere you will see the pump and an access to clean the pump filter, probably filled with assorted debris. be aware when you unscrew there will be water behind it,
Nov 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Need to buy drain pump
I have found searspartsdirect.com to be the best source for purchasing parts. Just type in your model number and the pump will be located under the "Pump and Motor" heading as item number 10 (part #8181684). The Sears website also has helpful exploded view illustrations that you can use for troubleshooting and component identification. For comparative pricing, repairclinic.com also carries many of the same parts. Use the part number provided by Sears for your search. This is the easiest way I know of to order parts and have them shipped directly to you. This generally isn't a standard part that an appliance repair retailer would carry in their inventory, I hope this helps answer your questions. If you need assistance in installing the replacment pump, go to my profile and look under my "Tips and Tricks section. I have a write up on step-by-step instructions for replacing a pump on a Whirlpool Duet and Kenmore Elite front loader.
Oct 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
88 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
