Question about Motorola Mobility RAZR V3
Loses reception I turn phone on and and sometimes reception is there sometimes not but after a little while the screen goes white and then when it comes back on (in just a couple seconds) reception is gone and will not return.
    Sergeant:
  • 282 Answers
Is it a water damaged phone or dropped?
Posted on May 19, 2008
Verizon LGev3 white external screen
you got a white screen on your phone it means you screen cable is a loss so you have to go service center to resolve the problem
May 18, 2017 | LG Cell Phones
Nokia 6300 Memory Store Not Ready Then White Screen Appears
Bro. . Goto any mobile software shop and flash your mobile. This is software problem
Feb 25, 2012 | Nokia 6300 Cellular Phone
Nokia 2630 .The problem is White screen for 2-3 sec. then turn off .Help pls
1. Check the battery. They may be worn out and dead.
2. Next time, your screen goes blank / white, shut off the mobile voluntarily, restart the phone and press reset button.
3. This will fix the problem. Caution: You may lose all your data.
May 15, 2010 | Nokia 2630 Cell Phone (Unlocked) - Black
My samsung screen is white but it works ive tried everything, this hbas happen before screen going white and the battery had to be without juice to come back. it works but ithe screeen is white
hi, the main reason the screen turns whits is due to the thin ribbon that sends the data from the circuit board to the screen being damaged what happens is that the thin copper wires that are inside the ribbon ware and then break causing a short to the screen and this is what turns the screen white. this happens on most flip and slide phones as the ribbon moves when you slide or flip the phone so over time it becomes brittle and you lose the connection and this turns the screen white.
sometimes it will right itself if you open and close the phone a couple of times but this wont be a long term fix how ever it may be that bad that this will no longer work, its not expensive to get this ribbon replaced but taking you phone to a small phone shop would be your cheapest option.
May 14, 2010 | Sony Ericsson K800i Cellular Phone
Screen is white. it turns on and off when battery
Either you accidentally dropped and spoilt your phone or water had managed to seep through. Try opening and get your phone screen out to wipe it clean (if you dare). Sometimes the connection can be bad from your phone to your screen if it's wet or dusty inside.
May 04, 2010 | Cell Phones
Little to no reception
there can be two problems,one with the trnsmitter of the set or with the cellular service.first try another sim,if not,get the trnsmitter changed.
Dec 05, 2009 | Samsung Propel A767 Cell Phone
Screen gets distorted and turns white
The part that is bad is the Ribbon flex cable that geos from the main board to the LCD board. Over time the cable becomes chaffed and will lose continuity between the traces. It can be fixed with
Tessco Part #: GH97-07715A
It does need to be soldered on the LCD side.
Apr 25, 2009 | Samsung SPH-m520 Cell Phone
Phone screen goes blank to a grey color (externallY) .
same problem, broke my screen, ordered a new screen off ebay and replaced it. now it works fine most of the time but sometimes external display freezes. sometimes goes black, sometimes goes multicolor pixelated (full screen, in blocks, or lines) when this happens sometimes touchpad still works, others not. removing battery usualy temporarily fixes.
Mar 09, 2009 | LG VOYAGER VX10000 Cellular Phone
My nokia 5300 wont charge
your mobile was wet someday
and now the effect is on
U should imedietly go to ur near nokia care center
and for the charge thing
Tell nokia care center to replace the charging needle ... bcuz it is rusty..... !
Mar 08, 2009 | Nokia 5300 Grey Cellular Phone
Motorola Mobility RAZR V3 Logo
42 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
