Question about Sony PlayStation 2 (PS2) Console
PS2 my sons playstation is a model SCPH-50001, it will not read a disk just keeps asking for a format disk. Is teh laser burnt out in it or is it just finally crapped out
    Problem Solver:
Some PS2's have a problem with reading certain Blue disks. You have two options:
1. I believe that you can send it back to Sony to repair (they will make you pay for the shipping)
2. If the disc is just for install, you can put a little piece of tape on the inner ring(the tape will touch the top and bottom of the inner plastic ring) and it should read the disc.
I had this problem also years ago. The most steadfast way would be to send it back to be fixed.
Posted on May 19, 2008
Multi taps do'nt work with my PS2
Ok Turn On Your PS2 Make Sure You Don't have a disk inside. It should show you Browser, System Configuration, and if u press triangle it will take u to the Version menu go to console look at you console code ex. SCPH-77001. Then look at you muti tap to see if they have the same code if it does should work not the same code will not work.
Feb 16, 2009 | Sony PlayStation 2 (PS2) Console
PS2 Modded Trouble Reading DVDr's
Your DVD potentiometer pot on the back of the PS2 laser lens needs to be readjusted. Some people will try to tell you it's out of alignment but if that was the case it would not read CD's. Some people will try to tell you the laser lens is bad. If that was the case it would not read CD's. On the back of the laser lens are two potentiometer pots. In english? Two lil screws that are turnable. One controls the power of the DVD laser one controls the power of the CD laser.
That link will give you pretty lil pictures of what i'm talking about :)
In a nut shell the story goes like this folks. If your PS2 won't read certain game DVD's that are of a certain color or if it all of a sudden mysteriously fails to read games it once read but will play cd's just fine, the voltage of the laser for DVD's is not set correctly. (this does needs manual tweeking from time to time if you take your ps2 and move it around alot or if you take it over to friends houses etc etc. Basicly alot of movment in general can take this out of alignment. Even keeping the PS2 on it's side could theoreticly (just my opinion) based on gravitational pull, unbalance the potentiometer.
Step 1 identify your PS2 version:
Version 1 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U1"
Version 2 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U0"
Version 3 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U2"
Version 4 - SCPH-30000, 30001, 35001, 30002, 35002, 30003, 35003, 30004, or 35004, 8 screws on bottom of case
NOTE: Version 4 has 2 varieties of motherboard: Gap/No Gap, the difference between v4 "Gap" and v4 "No Gap" is the "Gap" is there's a spot in the center of bios chip where each side lacks solder points.
Version 5 - SCPH-30000R, 30001R, 30002R, 30003R, 30004R, or 30006R. Also, some SCPH-30000, 30001, 30002, 30003, and 30004 models have a V5/V6
NOTE: Version 5 & 6 - the difference between these two versions is one of the connectors in the corner.
Version 7 - SCPH-39000, 39001, 39002, 39003, 39004, 39008 or 37000
Version 8 - Only in Japanese consoles. SCPH-39000, or, SCPH-39006 (GH-022 BIOS 090)
Version 9 - if you have SCPH-50000, 50001, 50002, 50003, 50004, 50006, or 50007 you have a v9 or v10 board.
Version 10 - SCPH-5000x, with date code "3D" to the right and below the serial number on the back of the console. (GH-026 board)
NOTE: To know if its a v9/v10 start up PS2 with no game in it ,press triangle and check dvd driver version dvd ver 3.00 = v9 & dvd ver 3.02 = v10.
If your model # is SCPH-50000, 50001, 50002, 50003 or 50004 AND if you can find a small ''a'' under the SCPH number or have DATECODE "3C" you have a V9 PS2 main board. (GH-026 board).
If your model # is SCPH-50000, 50001, 50002, 50003 or 50004 AND if you can find DATE CODE "3D" as shown below, you have a V10 PS2 main board. (GH-026 board).
Version 12 - The new slimline PS2 consoles are referred to as PSTwo here, but elsewhere they are also known as "v12" units... their numbers are SCPH-70011/SCPH-70012, and also SCPH-70004 CB (Belgium).
Step 2 use either google or the link above. If you're using google your keyword search will be something like "ps2 v12 laser lens adjustment" *replace v12 with your ps2 model.
In either case navigate to the site and follow instructions to set the pots back to their factory default settings.
Oct 11, 2008 | Sony PlayStation 2 (PS2) Console
Game shark problems
Gameshark is a 3rd party disk and sometimes depend how the disk was made.The laser inside is calibrate to read the format specified from the manufacture (SONY) and quite few time the laser ned to be adjusted a little bit to make work but i do suggest to try another disk if still doing the same .The reading issue is a common problem for ps2.If your machine is a slim one i suggest to replace laser since are not expensive and can give more boost to your game
Jun 16, 2008 | Sony PlayStation 2 (PS2) Console
Disk read error on slim ps2 scph 75003
hello pauldonp...if this is an early version of the slimline they had a problem with over voltage which inturn took out the laser.your only option may be to replace the laser . sony did bring out a mod for this..i preferr the real old version of the ps2 as they had all separate boards and if one went faulty you didnot have to replace the lot ,also the lasers were a lot cheaper than the later models .in the slim lines the lasers are not all that expensive .they do take a bit of setting up as you have to know the ohms setting on the laser for each model..hope this helps
Feb 08, 2008 | Sony PlayStation 2 Slimline Console
I believe the SCPH-version 30000 through 50001 use the UBD ports for Playstation Specific Devices like the eyetoy.  The Slim PS2 has is more diversified and can read USB devices just like a computer.  To get details on your PS2, you can get detailed instructions at  sign up and go to Support for your older version PS2 and read up on connecting to the USB port.  You may find out how to actually do it. I have not tried my self.  I wish I could help more.
Oct 31, 2007 | Sony PlayStation 2 (PS2) Console
PS2 DVD version
Hi SDK0013,
I am not sure which version PS2 you have but the only way to realy get there is to change the motherboard from one version to another.
I know that SCPH-50001 Motherboard will fit in a  SCPH-39000  case.
Oct 25, 2007 | Sony PlayStation 2 (PS2) Console
Ps2 disk read error - please help
it sounds like a timing issue,,,at the front of the cd underneath is a cam and a bar with teeth, gently push or pull the bar so it advances to the maximum position, then make sure the cd drawer is closed and plug the unit in to test.....afterward reassemble the unit , also do not look into laser beam, blindness will occur...
Aug 11, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
111 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
