FixYa.com
Tags:
HP Compaq Presario SR1350NX  PC Desktop
REINSTALL XP HOME EDITION ON Compaq Presario...
posted by SADONA4U on May 19, 2008
I'M TRYING TO INSTALL XP ON MY Compaq Presario SR1350NX Desktop PC. PICKED UP A NEW WD SATA 200 GB HARD DRIVE TO REPLACE THE MALFUNCTIONING SEAGATE. WD INSTALL DISK AND COMPUTER RECOGNIZES THE NEW HARD DRIVE AS "OTHER DEVICE", FORMATS FINE AND READIES THE HD FOR THE OPERATING SYSTEM. WHEN I TRY TO INSTALL XP, THE HARD DRIVE IS RECOGNIZED OKAY, ASKS IF I WAN'T TO USE THE CURRENT FORMAT FOR THE HARD DRIVE, LOADS THE INITIAL FILES, BUT THEN STOPS WHEN IT STARTS COPYING THE FILES TO THE HARD DRIVE. I PLUGGED IN A PATA DRIVE INTO THE EIDE CABLE AND IT DOES EXACTLY THE SAME THING. WHAT COULD BE GOING ON??????
Comment by SADONA4U, posted on May 20, 2008
Removed one of the ram chips but, still wouldn't load windows. I've tried the hard drive in my dell and it works fine. Something that is strance is this: When I use WD setup disk, the WD hard drive is only recognized as "additional storage devise" and not as Master or Slave on the motherboard. It formats the hard drive just fine. The bios recognizes the hard drive normally but when I try to install the OS, it loads the inital files but, then when it starts to copy the installation files, it stops and gives me the blue screen of death. I tried loading Win 2000 pro and it does the same thing but gives me a syntex error on the blue screen. The computer boots up and runs fine using my copy of Ultimate Boot CD for Windows. I'm thinking of copying Windows from another Compaq and try booting that way.
Comment by SADONA4U, posted on May 21, 2008
IT'S ALLLLLLIIIIIIIIIIIIIVVVVVVVVVVEEEEEE! Your recommendation was spot on! I took out the other ram module and put the first module I had taken out back in and it started loading Windows just fine. Thank you so much for your help!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 19, 2008
FixYa! (100)
Dageezer
Rank:Guru Guru
Rating: 87%, 218 votes
Files copy errors during the XP installation process are often an indication of BAD RAM.
If you have dual RAM modules, try install with 1 memory module installed
Comment by Dageezer, posted on May 21, 2008
If you took out one RAM module, and the problem was the same, did you try the other module by itself. Everything you describe, indicates BAD RAM
Rating Locked! (?) SADONA4U has rated this solution as FixYa!
Can you Help with these PC Desktops problems?
PC Desktops
I cant open an Email
I cant open an Email acc it... Answer This...
PC Desktops
I can't seem to open
I can't seem to open most of my... Answer This...
PC Desktops
I CANNOT READ MAIL BECAUSE
i cannot read mail because... Answer This...
PC Desktops
d-link dwl-g630 has stopped...
d-link dwl-g630 has stopped... Answer This...
PC Desktops
ACTIVATING MICROSOFT HOME AND...
activating microsoft home and... Answer This...
Repair Service
Find PC Desktop Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
