Question about Cowon System iAUDIO X5 MP3 Player
Dropped it -- now only blank screen
Dropped my iAudio X5 and now I get only a blank white screen when I turn it on or try to charge it. Have hit the reset several times and nothing happens. Connected to USB, my computer does not recognize it. Sounds like I killed the hard drive -- right? If so -- or if it's something else -- is it fixable?
  • tbros May 19, 2008
    Since I cannot get my computer to recognize it, I can't reinstall the software -- think you are right that it's a serious problem.
    Know where I can buy a 60g iaudio X5 -- seems to have been discontinued.
    Genius:
  • 3,422 Answers
It looks like something has been damaged internally.I suggest you to get it repaired or just go for a new one.But anyways you can try out the following:
Try connecting your player to another USB port. Using one port all the time to connect and disconnect USB items a port can develop a range of files associated with configuring the USB connection. Some of these files might actually have been from your player connected before, or some of these configurations could be from other USB items you connect to this port. Changing ports can often lead to an immediate good connection simply because ther are no conflicting configuration files. If this does not solve your problem, we can now entertain the next process to try.
coolguy008: THIS IS A BIG ONE. This is the last thing to do. Before you try this process, please complete a full back up of your system. This is important as the next step can have side effects you did not entirely expect. AND Second, you might need your XP Install Disk (not in all cases). What this process is about is renewing all hardware/software configurations relating to USB connections.
Here is what you do:
1. Right click MY COMPUTER
2. Select PROPERTIES
3. Select HARDWARE
4. Select DEVICE MANAGER
5. Select UNIVERSAL SERIAL BUS CONTROLLERS
6. Right click on each USB CONTROLLER and select Uninstall
7. Uninstall all entries
8. Reboot your computer
9. As your computer re-boots it will reinstall all USB connections it detects
THEN, when all other USB items have been configured and connected by the system, you then should try connecting your USB Player.
If these suggestions are implemented and you are still have connection difficulties with your computer, there are several other things to try. If you have another XP Computer you should try connecting your player to another computer to see if the problem is a player problem or not. If it still has this problem with the next computer, it maybe be a fault of the player.
IF YOU HAVE COMPLETED ALL the above mentioned and still have a problem, you should next contact the seller of this machine for further instructions of what to do next.
Goodluck,
Please don't forget to rate the solution
Posted on May 19, 2008
  • Priya darshan May 19, 2008
    You can buy one from HERE
    Please don't forget to rate or accept the solution as fixya
    President:
  • 2,712 Answers
Looks like damaged some internal device. You can try to reinstall the software/flash it. If that does not work, it does look like a serious problem, and you may have to take it in for servicing or buy a new one (whichever works out cheaper for you)..
Hope that helps.
Upon formatting a COWON x5 iAudio I had a power failure and the device turned off during the format process. Now it turns on "HDD FAILURE" is displayed
it needs service
got hit by lightening>
or dropped it?
or can be bad luck
its dead. get it serviced. in a real shop
"elecronics shop"
Jan 08, 2017 | Power Computers & Internet
Laod movies onto my iaudio x5
u can use JETAUDIO converter. . . set your profile to iAudio x5
then click the convert button. . .
Jun 23, 2008 | Cowon System iAUDIO X5 MP3 Player
How long dose it take
it don't take long, it depends on the file size you are putting into it, otherwise it might take a while based on that, or the amount of file you have in it, if it takes a while scrolling and you get a hour glass on your computer screen wait until it all loads up and it should work perfectly for you
Apr 08, 2008 | Cowon System iAUDIO X5 MP3 Player
Gets stuck at the loading screen, also a lack of battery life.
i had the same problem, try to reset it or, if you got rockbox built in try to turn it on and off, i don't know if you might have 2 sides to your mp3 player but try that out, and definitely buy a new battery, they sell it most likely at any electronic store...the wires should be plugged in inside and if not try to connect them inside: connect them as this red, black, and red if you do that it should solve your problem
Mar 30, 2008 | Cowon System iAUDIO X5 MP3 Player
Iaudio x5 wont stay on
you should check if any wires are disconnected, and you might need to change the battery for it, if thats the case, sounds like the battery must of broke
Mar 06, 2008 | Cowon System iAUDIO X5 MP3 Player
Cowon iaudio mp3 player
Yes you should get a new battery, it sounds like the battery you have must of died out, or is in bad shape, once you buy a new battery everything should work
Jan 01, 2008 | Cowon System iAUDIO X5 MP3 Player
Dropped iaudio X5 and it wont turn on
i found out a problem with it, i had the same problem if u have rockbox on their, u got to get rid of it, when it turns on plug the USB to the mp3 player, make sure it comes in the Drive of your computer, use a Windows XP, or any updated windows computer make sure that it's formatted into a FAT32 drive and format make sure u put the original firmware back into it, it can be downloaded from any Cowon Site, here is the steps if u want to know how to start it off Windows XP formatting instructions:
1. Connect your iAudio player to your PC's USB port and wait for it to detect.
2. Go to My Computer, click on Start then click on My Computer
3. Select the iAudio drive, then click on file and select format.
4. Click OK to format
Needs to be a FULL format and in FAT32.
after that is done, it will reset all the folders, and wipe off the hard drive and it should be back to normal, from then on it should work, if it doesn't try to use this site to request for a RMA repair service http://jetdb.jetaudio.com/RMARequest/Request.aspxand if u want to, u could try the Rockbox again if it is on it, but just know it's not fully supported by Iaudio...and ill give the Firmware link too if u want it [X5 Firmware]http://www.cowonamerica.com/download/iaudio_x5_jsfw.htmlor if it don't turn on possibily u can try to reconnect the power wire into the solder joints that should help with that issue, the power wire is red...that should help turn it on
May 03, 2007 | Cowon System iAUDIO X5 MP3 Player
IAudio X5 not recognised as removable drive
If there's no difference in the operating systems, or other software, a possibility is a faulty USB socket on the computer. Try another USB, or swap workstations... ;] hope it works out
Mar 21, 2006 | Cowon System iAUDIO X5 MP3 Player
Cowon System iAUDIO X5 MP3 Player Logo
138 people viewed this question
Top Cowon System Audio Players & Recorders Experts
Tom Chichester
Pamela Leach
Pamela Leach
Are you a Cowon System Audio Player and Recorder Expert? Answer questions, earn points and help others
