Question about Sharp PC AX40 Notebook
Dead sharp pc-ax40
i left the laptop copying files to an external USB disk, and when i came back it had frozen, so i restarted it.Since then, the laptop refuses to turn on. The power led is on showing that it has power, but when i try to turn it on, i hear a small noise from the speaker and nothing happens. When i press the reset button underneath all green leds on top right corner tun on and still nothing happens. Any help on that? Did the motherboard died? or could it be something simpler?
Thanks
Problem solved :)
Posted on Jun 08, 2008
2 Suggested Answers
  • 357 Answers
SOURCE: dead sharp pc-ax40
You can try reseating the memory and the hard drive if you can get to it, but it sure sounds as though the motherboard is shot.
You can take it to your local computer repair shop.
Good Luck.
Posted on Mar 15, 2009
I got an old laptop and I bought a new toshiba laptop I just wanna ask how do I transfer my application and files from my old laptop to a new one using external hardrive,also wat external hardrive,and also...
You can transfer the data files only from the old laptop to the new one. You cannot transfer the installed applications/software. Software are required to installed again on the new laptop afresh.
To transfer the data you can use external portable hard disk, which can be connected to the PC using any USB port (just like pen drive) and you can copy - paste the required data to the external disk just like you copy data from one partition to another. After copying the required data, you can connect the external drive to new laptop and copy the data to the new laptop. You can use external drive of any brand/ capacity. However, it is better to have an external drive with larger capacity, so that you can transfer the data in one go.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 20, 2011 | Toshiba Computers & Internet
How to set sharp pc ax40 laptop bios to boot from usb flash drive?
Sad to say your model "Sharp pc ax40 Series laptop" does not support the "Boot from USB devices" options from the Bios.
It uses the "Floppy Drive 3.5" 1.44 MB floppy - External" ie portable FDD booting options.
Hope it helps.
Apr 03, 2011 | Sharp PC AX40 Notebook
Toshiba A 45-S150: How to boot from external dvd drive?
Remove the disk-drive from the laptop, and connect it to another computer.
Copy all the files from the recovery-media onto the disk-drive.
Reinstall the disk-drive into your laptop.
Run the recovery software from where you copied the files onto the disk-drive.
Jan 01, 2010 | Toshiba Satellite A45-S150 Notebook
ACER Aspire L100 Desktop is dead?
If the hard drive is OK then you can remove the hard drive from the desktop case, and insert the hard drive into a USB 3 1/2" hard drive adapter case, this should come with a power adapter. These are available at your friendly computer shop.
Boot up the laptop then plug this USB hard drive adapter into the laptop's USB port. The laptop will see this as an external USB hard drive. You can open the various folders and files on this external drive and copy the folders and files to the laptop.
You can delete the Windows folder and Program Folders on this external drive to free up disk space and use this as a back up drive etc.
If you are not sure how to remove the hard drive and install it into an USB hard disk case, then I suggest you get a computer savy friend to help you.
Dec 08, 2009 | Acer Aspire L100 PC Desktop
Want to use clone hard drive to run XP
Because the HP and Fujitsu have different devices, you cannot clone (or create an image of) the hard disk and expect it to work on the other laptop.
Your best bet would be to copy your data files onto a USB memory stick or an external USB hard drive and plug it into the HP. You can open the files on the USB memory Stick/hard drive to work on them or copy them to the HP's hard drive to work on them.
When your Fujitsu has been repaired you can copy the latest files from the USB memory stick/hard drive back onto your Fujitsu.
Jun 19, 2009 | Fujitsu LifeBook S7010D Notebook
Need to transfer copied files to x301 after full restore
create a new folder in your hard-disk and first try to copy 1-2 files from the external hard-drive to the new folder (copy any data/work/images you have stored/created not any files of windows folder or root of c: drive)
if the above copy works then copy back all except the c: root and these folders - Windows folder, Document & settings, Program Files
May 30, 2009 | Lenovo ThinkPad X301 2776 Notebook
Dead sharp pc-ax40
Good Luck.
Mar 15, 2009 | Sharp Computers & Internet
Getting wireless for my: Sharp PC AX40 PC Notebook
you'll need a pcmcia card, that goes in the narrow slot on side of the laptop. it's not built in on this model, according to the specifications..there are loads of good ones out there. too.
by the by, you are my 2000th solution, and you are entitled to a Complementary TuneUp4Good for your computer. contact me through my email on my profile.
Mar 21, 2008 | Sharp PC AX40 Notebook
Sharp PC AX40 Notebook Logo
156 people viewed this question
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Ricky Ostrom
Ricky Ostrom
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
