Question about Frigidaire Affinity ATF6000ES 3.5 Cu. Ft. I.E.C. Front Loading Washer
Frigidaire affinity front load washer
I put a load of towels to washing..went to put them into the dryer but they still seemed to have suds in them, so I rewashed the load again and and now there are alot of suds all in the washer..so I tried one more time to wash them and same problem..It had something flashing on the front. Any ideas on what may be wrong?
Laura
  • 1 more comment
  • Anonymous Jun 15, 2008
    same problem with the washer. third time washing the towels. loads of suds. did not add additional soap. I opened the door and the towels are soaking wet. It's like they are not spinning out. The errors I am getting are EF0 and EF2. can anyone help. my email is tmorris3133@yahoo.com.
  • tmorris3133 Jun 15, 2008
    same problem. towels have been washed 3 times. loads of suds. towels soaking wet, like they did not spin out. Errors I am getting are EF0 and EF2. Repair man said that you will always get an error with each load you do. Does not make sense to me.
  • plantstone Dec 07, 2008
    Same problem for me, please email the solution.
    plantstone@gmail.com
Same problem!
Posted on Aug 21, 2008
Fridgidair affinity washer paused with error code EF2
According to SearsPartsDirect.com ( http://www.searspartsdirect.com/washer-repair/error-codes/frigidaire-front-load-washer-error-codes.html ) : EF2 Condition Too much suds Check/Repair Reduce the amount of high-efficiency (HE) high-efficiency detergent being used in the washer.
Aug 31, 2012 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Can I reverse the door on my new Frigidaire Affinity front loader?
Hi, as far as i know you can only reverse the dryer, the wiring for the door latch doesnt allow you to reverse it on this washer.
Sean
Mar 26, 2011 | Frigidaire Affinity ATF7000ES Front Load...
I put a non he soap in. now i have lots of suds. what do i do?? (OK, my 11 year old did it, truly!)
The machine automatically will run a cycle to try to eliminate the excess sud's if it does not work you can try adding some vinegar to the load witch will get rid of the excess sud's ,of course you will have to rewash the clothes....Hope this helps Good Luck
Dec 06, 2010 | Frigidaire Affinity ATF7000E Front Load...
Washed load of towels wont work
try cleaning the drainage filter located under the front bottom panel.
Aug 14, 2009 | GE WSXH208A Front Load Washer
Water level too low. clother wet. No water visible or suds. What is wrong.
Your expectations are based on top load washers.
Front load washers use only a very little water, and suds are an enemy. (HE soaps are designed to clean without suds. Suds are really for show and cause drag on the wash tub during spin.) If you start a load with no clothes, you will see that the water level never gets above a couple inches in the tub. That is the correct water level for front loading machines. PS. Because of the low water use, make sure you use very little soap. (one to two tablespoons per load only!)
Aug 12, 2009 | Frigidaire Affinity ATF7000E Front Load...
My clothes never have a good smell or at best any smell recently. I also never see the water stay in the washing and it suds up like it used to. It appears that when the water is being put in, it is going...
Try this. Run a load of a few towels with no soap, no bleach, no fabric softeners. Set wash water temp to hot. After hot water enters and begins to wash, stop the washer and open the door. Pour in one cup of vinegar (white is fine.) Run the entire wash cycle.
-Buy a supply of High Efficiency Washing detergent (marked "HE") and do not over fill the detergent cup (use a little less than the directions say, never more.)
-Buy a name brand supply of fabric softener with a scent you enjoy and can recognize.
Run the next weeks loads of wash (no need to use Hot water any more) and report back here with how things are smelling. OK?
Aug 11, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF6000ES 3.5 Cu. Ft. I.E.C. Front Loading Washer Logo
261 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
