Question about Viking 42 in Built In Professional Integrated Side by Side Refrigerator - VISB423
Reset of Viking 42" - blowing warm air
Had a power outage and then the unit came back on, but is blowing air - even on max cool. Someone suggested tripping the breaker to cut all power to the unit. Also I know there is a program switch in the center to reset some of the units programs. This is the 4th unit we have had in 7 years and never again. Any help would be appreciated before I spend $ on another service call.
  • 6,927 Answers
Try turning the unit off for about 15 to 25 minutes to let the compressor pressures become equal.Then cut it back on and wait for a while to see if it starts working.
Posted on Aug 20, 2009
I have a Crosley 220 volt 18,500 btu window unit air conditioner with a heat pump. The cool air works fine when set on cold, but when set on heat, it doesn't blow warm air. What should I check first?
18000 BTU Air Conditioner ' The Air Conditioner Guide
www.theairconditionerguide.com > BTUs
An 18000 BTU air conditioner is your best bet if you are looking to cool a room ... 2) Frigidaire 18,500 BTU Window-Mounted Median Air Conditioner with ...Troubleshooting Guide. Lost your Everstar air conditioner manual? Fix it tips are here!
Nov 26, 2015 | Crosley CAHE18ER Air Conditioner
Unit blows cool air while in heat mode
model number? Heat pumps tend to blow cooler air than a space heater unless in money-gobbling mode.
Mar 28, 2014 | LG Heating & Cooling
AIR BLOWING LIKE IT'S ON FAN EVEN THOUGH IT IS ON COOL
close vent for outside air.....if not then probably lost its chaerge.
Oct 11, 2017 | Heating & Cooling
We have a Toshiba Model 37LX96 LCD/DVD Combo Can't turn on, after a recent power outage There is power going to the unit, but it will not turn on using the remote or using the "power"...
Common problem with the main board. Only happens after losing main power, not just turning the TV off.
I found that blowing hot air with a heat gun down the vents above the DVD player (don't melt the plastic housing) will warm the main board up enough to get the TV powered up again.
You'll be good to go until the next power outage then back to the heat gun.
Also the spec sheet indicates max humidity at 80% so keep the TV in a space with lower humidity.
The Toshiba 37LX96 is a quality TV, not a throw away if you can keep it running.
Schmidty
Aug 25, 2011 | Toshiba 37LX96 37 in. LCD TV/DVD Combo
Unit won't cool. Unit is set on is on cool, but warm air comes out. Is there a reset button on the unit ? Unit is 21 1/2 years old.
Some of those old Mach 3's have a manual reset pressure switch, but you will have to take the cover off to find it. Most manual resets have a red button to push to reset. The unit may be low on refrigerant or the condenser coil stopped up with dirt.
May 13, 2011 | Coleman Mach III Air Conditioner
Air conditioner compressor runs for about 1-2 min, then cuts off
well when u have outages the voltage drops obviously, the one that suffers are the capacitors the capacitor for the compressor might need to change, change it with the same capacity as the old one example if labels say 55 microfarady ( mf ) ( 55 mf ) get one of the same I am not saying it is a 55 mf capacitor vary depending on motor and brand. So check the label
Jul 23, 2009 | Danby Portable Air Conditioner
Outside unit will not start...while inside unit blows warm air
probably a.c. was left with out a gas,and compressor will not start and there is no cooling.
Jul 04, 2009 | Heating & Cooling
Viking professional induction cooktop large burners defective
Throw your circuit breaker that leads to this unit for a few seconds, then reset the breaker This unit is very sensitive to power fluctuations.
Mar 07, 2009 | Viking 37 in. VECU165 Electric Cooktop
My AC is not cooling the air
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, it is not blowing cool air after you emptied the tank.
Turn the unit off and unplug it for 5 minutes.............
Then back in with the plug and turn it on max cool.
Give it 5 or 10 minutes to get cold, and we will see if this procedure has reset the system.
Then get back to me and let me know it's working!
How old is the unit?
Please remember to leave a rating before you go!
Thank you Huuum
Aug 04, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Viking 42 in Built In Professional Integrated Side by Side Refrigerator - VISB423 Logo
304 people viewed this question
Top Viking Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
