Can't say for sure it is a bad ground but does sound like you have a intermittant connection some where. So I would start by taking the fuse out at the battery terminal, then disconnect and reconnect your power cable to the amp, disconnect the ground wire to the amp then reattach, then do the same on the chasssis side. Do the same with the remote wire. Put the fuse back in and test .
