Question about IBM (25P3294) Motherboard
Ibm server x3400
I have problem in the motherboard of this server
its not boot up , but
when i connect the power cord the power on for 2 sec and tottally off
  • somsak Aug 19, 2008
    When I power on IBM X3400. I had got message
    Press F1 for Configuration/Setup
    Press F12 for boot menu
    When I pressed F1, The message "Entering Setup..." appear and still that, not things happened or go on. Any suggestion for me, Please.
  • 55 Answers
You might have a problem with one of your componnents on the board. Please check LEDs on your Diagnostic Panel. It might point you to a defective componnet. It should also have LEDs beside componnents on the board. Try to replce defective componnet. Here is a list of defective componnets that would cause the above problem.
1. Power Supply
2. Defective cooling fan
3. Defective CPU
4.Heatsink is not in place
5. System board
6. Broken USB connector
Posted on May 23, 2008
How do i fix an ibm server x3400 mt 7975 that is failing to power up ?
The power supply isn't getting a good power signal from the motherboard. Sometimes unplugging the 20 pin connector and plugging it back in a few times will clean a faulty connection. Otherwise your power supply is at fault.
Jul 16, 2014 | IBM System x3400 7975 - Quad-Core Xeon...
Ibm x3400 is not powering on green led blinking continiously
Hello here is others with the same problem:
http://www.ibm.com/developerworks/forums/thread.jspa?threadID=397434&start=15&tstart=0
It looks like the power button is failing.
The fault could also be the mainboard.
Try also to talk with a autorished dealer or a repair shop.
Good luck
Dec 15, 2012 | IBM x3400 Server
I Have An IBM x3400 How do i test the smps using a voltometer
Since you haven't mentioned the type of server its unsure server has single type or dual type SMPS. This issue can due to SMPS as well Plannar (motherboard) issue. But as per post i really doubt you have bad motherboard since you see BMC and other LEDS on motherboard gets blinking..
You can troubleshoot motherboard issue this way. Press and hold server power button. Check if this makes server start. If it starts, then its confirmed you have bad motherboard.. You may also inspect whether motherboard has bulged capacitors inside..
Thanks
Oct 05, 2012 | IBM x3400 Server
IBM server x3400 not starting
This is a Planner issue (Mother Board) . Open side cover and investigate capacitor status . Probably some capacitors are bulged . Check it and replace if necessary .
Good Luck
May 16, 2012 | IBM x3400 Server
IBM System x3400 M3 7379 not booting displays orange colour (!), hangs at EFI Initialization what might be the problem. Thanks in advance.
check the indicators on the right side of the front panel for more detail of the error. search online for the manual.
Nov 28, 2011 | IBM System x3400 M3 7379 Server tower 5U...
Question: I have one server for IBM X3400. this con't booting that problem was Fatal error: controller monitor failed conterollre not started . .
I have one server for IBM X3400. this can't booting that problem was controller monitor failed controller not started
Dec 15, 2010 | IBM x3400 Server
IBM X3400 Server Power Led Blinking and Pressing power SW, Machine not power up.
hi,
Welcome to Fixya
1: Check whether the power switch has any problem 2: Check Ac and DC led on smps is glowing 3: If it glows , probably the planner(Motherboard ) has the problem
Thanks
Nov 23, 2010 | IBM x3400 Server
Firmware update interupted, server out
If you have jumpered for BIOS recover it should be able to boot from floppy. I think you will have to install a floppy drive, boot from floppy. Jump the MB for BMC update (if ness) and flash the BIOS and BMC that way.
Jan 16, 2010 | IBM x3400 Server
Replace the flat cable on the motherboard of SAS1 to SAS2. Resolved.
Dec 09, 2009 | IBM x3400 Server
Ibmserver x3400 fatal error
Have you checked the IBM website for BIOS and any firmware to download and update for the controller? It can get to be a maze with server cards.
Jul 07, 2009 | IBM x3400 Server
IBM (25P3294) Motherboard Logo
633 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
